DESCRIPTION
AIRCRAFT ON TAKEOFF, SANK DOWN ONTO RUNWAY WITH GEAR RETRACTED, FORT LAUDERDALE, FL Is this an example of putting the gear lever up before advancing the throttle for takeoff? |
john smith wrote:
DESCRIPTION AIRCRAFT ON TAKEOFF, SANK DOWN ONTO RUNWAY WITH GEAR RETRACTED, FORT LAUDERDALE, FL Is this an example of putting the gear lever up before advancing the throttle for takeoff? My father was an B-25 instructor in CA during WWII. He said some of the cadets would do this and the CO would be real mad when the B-25 settled back to earth. -- Regards, Ross C-172F 180HP KSWI |
("Ross" wrote)
My father was an B-25 instructor in CA during WWII. He said some of the cadets would do this and the CO would be real mad when the B-25 settled back to earth. B-25 ....BOMBER! I'm with the CO on this one. :-) Paul-Mont |
"Montblack" wrote: ("Ross" wrote) My father was an B-25 instructor in CA during WWII. He said some of the cadets would do this and the CO would be real mad when the B-25 settled back to earth. B-25 ....BOMBER! I'm with the CO on this one. :-) Paul-Mont Bombers have an advantage over other types on these types of takeoffs. When you feel the aircraft starting to settle, you can just hit the button and drop your load. The sudden decrease in aircraft weight will give you the extra performance boost you need to start climbing. |
"Roy Smith" wrote in message ... I'm with the CO on this one. :-) Paul-Mont Bombers have an advantage over other types on these types of takeoffs. When you feel the aircraft starting to settle, you can just hit the button and drop your load. The sudden decrease in aircraft weight will give you the extra performance boost you need to start climbing. I'm sure that's very comforting to the folks aft of the bomb bay. : -c |
"Roy Smith" wrote Bombers have an advantage over other types on these types of takeoffs. When you feel the aircraft starting to settle, you can just hit the button and drop your load. The sudden decrease in aircraft weight will give you the extra performance boost you need to start climbing. But, even IF the bombs were hot, it would be helpful if the bomb bay doors were opened, first. g -- Jim in NC |
On Tue, 17 Jul 2007 21:37:07 -0400, "Morgans" wrote:
"Roy Smith" wrote Bombers have an advantage over other types on these types of takeoffs. When you feel the aircraft starting to settle, you can just hit the button and drop your load. The sudden decrease in aircraft weight will give you the extra performance boost you need to start climbing. But, even IF the bombs were hot, it would be helpful if the bomb bay doors were opened, first. g IIRC, the B-17 (and probably all other US bombers) had a safety cable across the lower part of the bomb bay which would open the doors if a bomb inadvertently dropped. Ron Wanttaja |
On Jul 17, 5:10 pm, Roy Smith wrote:
In article , "Montblack" wrote: ("Ross" wrote) My father was an B-25 instructor in CA during WWII. He said some of the cadets would do this and the CO would be real mad when the B-25 settled back to earth. B-25 ....BOMBER! I'm with the CO on this one. :-) Paul-Mont Bombers have an advantage over other types on these types of takeoffs. When you feel the aircraft starting to settle, you can just hit the button and drop your load. The sudden decrease in aircraft weight will give you the extra performance boost you need to start climbing. When you say "drop your load" do you mean drop the bombs? Is it the decrease in weight or the exploding bombs that gave that "extra performance boost you need to start climbing?" Ricky |
On Thu, 19 Jul 2007 05:00:45 -0000, Ricky
wrote: On Jul 17, 5:10 pm, Roy Smith wrote: In article , "Montblack" wrote: ("Ross" wrote) My father was an B-25 instructor in CA during WWII. He said some of the cadets would do this and the CO would be real mad when the B-25 settled back to earth. B-25 ....BOMBER! I'm with the CO on this one. :-) Paul-Mont Bombers have an advantage over other types on these types of takeoffs. When you feel the aircraft starting to settle, you can just hit the button and drop your load. The sudden decrease in aircraft weight will give you the extra performance boost you need to start climbing. When you say "drop your load" do you mean drop the bombs? Is it the decrease in weight or the exploding bombs that gave that "extra performance boost you need to start climbing?" They shouldn't travel far enough for the fuses to be armed. That's what that little propeller does. Ricky |
"Ross" wrote in message ... Is this an example of putting the gear lever up before advancing the throttle for takeoff? My father was an B-25 instructor in CA during WWII. He said some of the cadets would do this and the CO would be real mad when the B-25 settled back to earth. Some/all B-17s will do that too. When Evergreen turned me loose in their bird (flipped on the battery and open the bomb bay for some visiting WWII vets) I was specifically briefed NOT to bump the landing gear lever or it would be a very bad day at the hangar. I've had more than one nightmare of doing just that since. When I started flying retractables, it really spooked me out all over again for a bit. -c |
| Thread Tools | |
| Display Modes | |
| Gear Up, pt 4 - Crashed He 111 with balloon cable cutting gear - July 1940.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | April 13th 07 02:50 PM |
| Crashing on takeoff... how odd | [email protected] | Piloting | 165 | August 31st 06 05:30 AM |
| seaplane takeoff | Lets Fly | Owning | 1 | December 5th 05 11:18 PM |
| Takeoff with a problem? | Rocky | Piloting | 14 | January 23rd 04 03:26 PM |
| Jet takeoff performance | karl gruber | Piloting | 6 | November 21st 03 06:59 PM |
