#31
However it is done the one thing I agree on is that it needs to be
very simple so everyone understands it. I like JJ's plan and it is simlar to what was done at Region 8. IIRC it was something like 1 to 100 feet low = 5 point penalty 101 to 200 feet = 10 point penalty 201 to 300 feet = 15 point penalty 301 to 400 feet = 20 point penalty 401 to 500 feet = 25 point penalty etc. The plan has a lot going for it. 1. It is simple 2. it or variations of the penalty make it only a small penalty to finish a little low and a larger penalty to finish lower. 3. There is no racing in the finish cylinder. One you enter the cylinder you can concentrate on landing safely. 4. The penalty is not so severe that there is little incentive to scratch around low outside the cylinder since unless it is a reasonable thermal it will be more advantagous to take the penalty than to take a weak thermal. Brian CFIIG/ASEL. |
#32
On Jul 29, 4:01 pm, Marc Ramsey wrote:
The SN10 also does a pretty good job at this (mine is better, of course), what's the issue? The issue is that the the altimeter setting is usually unknown at the time of landing but it is almost certainly different for the altimeter setting at takeoff time. The altmeter error on landing, if still using the takeoff altimeter setting, may exceed 100 feet even if there is no significant weather change. Andy |
#33
I don't find this to be true, Andy. Altimeters need
to be re-set primarily when landing at a destination 1000's of miles away from the takeoff location. I find my altimeter to be surprisingly accurate when landing at my takeoff location after a 4 hour flight. This is true with the SN10 altineter, also. JJ The issue is that the the altimeter setting is usually unknown at the time of landing but it is almost certainly different for the altimeter setting at takeoff time. The altmeter error on landing, if still using the takeoff altimeter setting, may exceed 100 feet even if there is no significant weather change. Andy |
#34
#35
I think if you have a 'zero penalty' band pilots will
tend to use it. I can't figure the difference between and 700' finish with a 200' band and a 500' finish. Andy, My point is that the current system encourages you (the racing pilot) to shave the 500' limit as close as you can, but at the risk of losing a lot if you miscalculate - or opt for a low altitude dash to a rushed landing to minimize your losses. Plus it encourages expensive gadgets/ software (as I now realize that my SN10 will show the info I need, for example - priced one lately?) and clock watching at the finish. Providing an "altitude-neutral" band to finish in should remove the incentive to aim for the bottom, since there would no longer be a benefit to be gained, while the risk of losing a lot would be a strong incentive to aim for the top of the finish band. The band should be big enough to hit easily with a properly set regular altimeter (I think 200' would work) without being so big the adjustment for altitude becomes "gameable". Heck, how about adding one second for every 2 feet below the top - that works out to a 1.2 knot final climb - which wouldn't hurt you much if you were 20 ft low, but would still encourage not finishing 199 ft low (who wants to give away time, after all). The addition of "no racing after the finish" (i.e. if below the bottom, the "hard deck" in fighter speak, you get your finish and penalty right there and can forget about a straight in finish and concentrate on making a safe low altitude landing) would additionally discourage high risk finishes. I know, I know, enough whining, this is pretty much beat to death - time to start bashing 2-33s again... Cheers, Kirk |
#36
![]() kirk.stant wrote: .... My point is that the current system encourages you (the racing pilot) to shave the 500' limit as close as you can, but at the risk of losing a lot if you miscalculate - Kirk, Doesn't the old fashioned system encourage you to finish at 50 ft altitude and 70-90 knots airspeed (whatever was MC speed for your last thermal) ? Each pilot added extra margin for their own comfort, but the scoring encouraged them to leave no margin. Todd Smith 3S |
#37
On Jul 30, 9:23 am, toad wrote:
kirk.stant wrote: ... My point is that the current system encourages you (the racing pilot) to shave the 500' limit as close as you can, but at the risk of losing a lot if you miscalculate - Kirk, Doesn't the old fashioned system encourage you to finish at 50 ft altitude and 70-90 knots airspeed (whatever was MC speed for your last thermal) ? Each pilot added extra margin for their own comfort, but the scoring encouraged them to leave no margin. Todd Smith 3S Absolutely. But the big difference is that I can SEE 50'. And depending on the field conditions and approaches, you either added a big pad (small field, no options if too low) or could push it lower (lots of available runways, landable fields on the approaches). Since these decisions affected all the pilots competing, they really even out - since the penalty for landing just short are really extreme! But move that up to 500' and you cannot eyeball the finish anymore - so you either have to throw in a big pad (bogus from a racing standpoint) or take a big racing risk. Or play the rule and bypass the safety issue altogether. People keep on harping how the scoring encourages pilots to leave no margin. Uh, excuse me, but do you know of any competitive sport that doesn't? That's why it's called a race! But at the same time, you can't win by crashing - and as pilot in command it is entirely my responsibility to not exceed my skill and equipment performance while completing the task - as close to the margin as rules allow. Heck, in boat racing, some of the rules encourage collisions (try being on the start boat end of a Laser start - I've been right-of- wayed right into the boat by a serious competitor - and properly so)! Thankfully we aren't that aggressive in soaring (although a limited altitude start gaggle gets pretty close!). Now before you accuse me of being a daredevil (I've been called worse) let me say that I have no problem with rules that encourage a safe finish by not requireing a dangerous finish. But the rule has to consider the Race aspect as much as the Safety aspect. Our current finish cylinder rule does not, IMO. Sorry, I promise to get help... Kirk |
#38
Andy wrote:
On Jul 29, 4:01 pm, Marc Ramsey wrote: The SN10 also does a pretty good job at this (mine is better, of course), what's the issue? The issue is that the the altimeter setting is usually unknown at the time of landing but it is almost certainly different for the altimeter setting at takeoff time. The altmeter error on landing, if still using the takeoff altimeter setting, may exceed 100 feet even if there is no significant weather change. SSA competition rules explicitly state that the finish altitude is determined based on the most favorable (to the pilot) of the baselines established at *takeoff*, as well as landing. Guy has verified that Winscore is doing precisely that. If one leaves their glide computer at the takeoff altimeter setting, or the glide software is able to calculate a takeoff pressure altitude baseline and uses that to determine the finish arrival altitude (as mine does), altimeter error is simply not a factor... Marc |
#39
On Jul 30, 10:56 am, "kirk.stant" wrote:
On Jul 30, 9:23 am, toad wrote: kirk.stant wrote: ... My point is that the current system encourages you (the racing pilot) to shave the 500' limit as close as you can, but at the risk of losing a lot if you miscalculate - Kirk, Doesn't the old fashioned system encourage you to finish at 50 ft altitude and 70-90 knots airspeed (whatever was MC speed for your last thermal) ? Each pilot added extra margin for their own comfort, but the scoring encouraged them to leave no margin. Todd Smith 3S Absolutely. But the big difference is that I can SEE 50'. And depending on the field conditions and approaches, you either added a big pad (small field, no options if too low) or could push it lower (lots of available runways, landable fields on the approaches). Since these decisions affected all the pilots competing, they really even out - since the penalty for landing just short are really extreme! I see you point about being able to visually identify 50' altitude, but I disagree that the decisions even out. Because pilot A can choose to leave 0' margin, but pilot B chooses 500' margin. But move that up to 500' and you cannot eyeball the finish anymore - so you either have to throw in a big pad (bogus from a racing standpoint) or take a big racing risk. Or play the rule and bypass the safety issue altogether. People keep on harping how the scoring encourages pilots to leave no margin. Uh, excuse me, but do you know of any competitive sport that doesn't? Competitive and dangerous sports build the desired minimums into the rules. Car races limit engine horsepower, mandate strength standards and safety equipment, this all makes the cars slower. Sailboats require certain safety equipment, etc. Whitewater races are required to wear life jackets and helmets. Heck, in boat racing, some of the rules encourage collisions (try being on the start boat end of a Laser start - I've been right-of- wayed right into the boat by a serious competitor - and properly so)! Thankfully we aren't that aggressive in soaring (although a limited altitude start gaggle gets pretty close!). Well, you should have known there was no room in there before you barged ! Most sailboat ROW issues don't have the consequences of a short landing. Now before you accuse me of being a daredevil (I've been called worse) let me say that I have no problem with rules that encourage a safe finish by not requireing a dangerous finish. But the rule has to consider the Race aspect as much as the Safety aspect. Our current finish cylinder rule does not, IMO. I think that the details might need to be tweaked, but the rule does try to consider the racing as well as the safety. The old rule ignored safety and left that part to the pilot. Maybe we need a tethered balloon with a laser level to mark finish height ;-) Sorry, I promise to get help... Just go fly. Kirk Todd Smith 3S |
#40
On Jul 30, 7:21 am, John Sinclair
wrote: I don't find this to be true, Andy. Altimeters need to be re-set primarily when landing at a destination 1000's of miles away from the takeoff location. We have an AWOS right on the airport, so I set the mechanical and 302 to this shortly before takeoff. When I check the altimeter after 4-6 hours, the change is typically 1-200' - and usually puts me lower. Really unsettling if I'm on a marginal glide and the air looks stable ahead. -Tom |
WinScore Question | Ray Lovinggood | Soaring | 2 | June 5th 07 03:15 PM |
calculate last point of diversion | jaws | Piloting | 1 | July 5th 06 04:19 PM |
How to calculate TOC and TOD? | Andrea da lontano | Piloting | 3 | October 21st 04 09:24 PM |
Weight and Balance Formula, Can one calculate the envelope | Joe Wasik | Piloting | 12 | September 29th 04 08:15 AM |
Winscore source code now available | Guy Byars | Soaring | 0 | February 5th 04 10:43 AM |
