WinScore Question
Old June 5th 07, 12:09 PM posted to rec.aviation.soaring
Ray Lovinggood
Default WinScore Question
At the Albert Lea, Minnesota, USA National race for
18m and Open class sailplanes, the score sheets on
the SSA webpage list one type of Schleicher two different
ways:
ASG-29
and
ASW27-18.
(Ok, a third and a fourth way if you count the ASG
29, the one without the dash and the ASG29, the one
without a space...)
Why is that?
I believe Schleicher uses the ASW-27 type certificate
(or whatever is the term for 'experimental' in America)
for the ASG-29, but why would WinScore use two different
names for the same aircraft?
Just curious, that's all.
Ray Lovinggood
Carrboro, North Carolina, USA
Old June 5th 07, 02:37 PM posted to rec.aviation.soaring
On Jun 5, 6:09 am, Ray Lovinggood
ways:
ASG-29
and
ASW27-18.
without a space...)
Why is that?
Ray Lovinggood
I thought that if it was a ASW, ASH, or ASG depended on which engineer
at Schleicher designed it.
Old June 5th 07, 03:15 PM posted to rec.aviation.soaring
On Jun 5, 7:09 am, Ray Lovinggood
WinScore use two different names for the same aircraft?
Winscore uses whatever aircraft name the official scorer enters for
the contestant. That information is typically provided by the
contestant on the contest registration form.
This question does not relate to the Winscore program, but to what the
scorer and contestant choose to name a particular aircraft.
Guy Byars
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
Winscore source code now available Guy Byars Soaring 0 February 5th 04 10:43 AM
