Stick Shake When Firing Guns
Old September 27th 03, 07:38 PM
Howard Austin
John Kunkel wrote:
Is this Hollywood or did the firing of the guns carry through to the
controls and cause stick shake as the movies depict?
FWIW, Robert S. Johnson (well, Martin Caidin in RSJ's name*)
claimed that on the occasion of his first kill, the noise of all 8 of
the Jug's fifties firing together scared (or at least startled) him to
the point that he let go of the trigger. Up 'til that point, he'd only
fired one at a time, at towed socks.
*note that Johnson left that part of the tale in when he revised
and re-released Thunderbolt!
Jeff
I can't imagine that, while firing all eight of those .50's in a P-47, that the
whole plane wasn't shaking....much less just the stick. Anybody with shooting
experience in that plane care to detail their experience?
Dave
Never flew the P-47 but firing the six guns in the Mustang created a
lot of noise but little if any vibration. Certainly didn't shake the
stick.
Howard Austin
Old September 28th 03, 12:41 PM
Richard Brooks
Howard Austin wrote:
the controls and cause stick shake as the movies depict?
of
to
only
Jeff
P-47, that the whole plane wasn't shaking....much less just the
stick. Anybody with shooting experience in that plane care to detail
their experience?
Dave
stick.
I suppose it's quite difficult to portray vibration that can only be felt,
without resorting to subtitles.
One piece I read was of a Lancaster pilot who said that on full revs as the
Lanc' lurched forward at the start of its take-off run, the control column
felt like you were holding a hive full of angry bees.
Richard.
Old September 28th 03, 05:36 PM
Michael Williamson
M. J. Powell wrote:
I've noticed that on the camera gun film shown on some TV programmes
sometimes the whole picture vibrates and at other times it is quite steady.
Mike
Depends largely on the installation of the gun camera, and its
position relative to the guns. In the P-38, the camera was
initially installed in the nose, pretty much just below the 20mm
cannon. The result was very poor to unusable footage. The camera
was later moved to one of the underwing pylons, and the result was
very steady gun footage, if from a somewhat unusual perspective.
Mike
Old September 29th 03, 05:41 AM
Regnirps
Mike
Mostly what you are seeing is easily explained. The cameras in many of the
fighters in the ETO had a seperate switch for turning it on and off. You can
sometimes see a little flag in the uper left or right of the frame that
indicates trigger pull. On some the flag means firing and some its absence
means firing! So a single film shot can have firing and nonfiring portions and
sound affects are often added to match the vibrating portion. You also get some
shots of enemy pilots under their chutes. This is done with the camera switch,
uhm, most of the time.
A good example is the famous very long chase at treetop level by Harry Dayhuff
(or someone in the 78th) in a P47 that culminates in his blowing the left wing
off a German plane.
On the P47 the camera is mounted in the wing and you see a lot of vibration,
mostly due to the low shutter speed of about 1/30 sec. Since the P47 was very
heavy and double skinned, the pilots I have talked to never mentioned feeling
much in the way of vibration.
-- Charlie Springer
Old October 2nd 03, 12:39 AM
Matthew G. Saroff
In the case of the A-10, I would figure that everything
in the immediate vicinity of the cannon would shake when it was
fired.
--Matthew Saroff
Shrub stole the election, and all I got was this lousy T-shirt
http://www.pobox.com/~msaroff/liar
post vs stick hangar construction Joa Home Built 25 November 1st 03 01:03 PM
The F-16 control stick? Christopher Military Aviation 13 September 22nd 03 10:18 AM
P-47/51 deflection shots into the belly of the German tanks,reality ArtKramr Military Aviation 131 September 7th 03 09:02 PM
RAC grip (Formerly MAC) Ed Wischmeyer Home Built 7 August 26th 03 03:44 PM
