Has anyone got an appreciation of the RAC (formerly Menzimer Aircraft
Corporation) stick grips? I am particularely interested in the multiple switch model. Don't know which one that is, but there's a lot of very bad human factors that goes into stick grips with lots of switches. Attributes of things you want on the switch: * You use 'em a lot * You need 'em in a hurry * If you push 'em by mistake, no big deal A disadvantage of things on the stick is that they're usually not labeled, and if they are, you may have to remove your hand to [try to] read the label. Best examples of things that may belong on the stick are electric trim and push to talk. Things you should *not* have on the stick are starter, flaps, and cowl flaps. Some folks do that, but... Ed Wischmeyer |
Attributes of things you want on the switch: * You use 'em a lot * You need 'em in a hurry * If you push 'em by mistake, no big deal Agreed. There's on grip I see advertised frequently that has a bat wing toggle switch which can be easily knocked by accident. Not a good idea. Dan, U. S. Air Force, retired |
A agree too. My intented usage is:
PTT, of course, Aileron trim (my pitch trim is mechanical) AutoPilot Engage/Disengage Argus Moving map select/Info modes Approach timer (although this is not absolutely necessary there) It is hard to imagine that someone would put the starter and other things on the baseball bat as stated in another post. Here's what I am talking about, particularely the model G7: http://www.aircraftspruce.com/catalo...stickgrips.php Francois Ed Wischmeyer wrote: Has anyone got an appreciation of the RAC (formerly Menzimer Aircraft Corporation) stick grips? I am particularely interested in the multiple switch model. Don't know which one that is, but there's a lot of very bad human factors that goes into stick grips with lots of switches. Attributes of things you want on the switch: * You use 'em a lot * You need 'em in a hurry * If you push 'em by mistake, no big deal A disadvantage of things on the stick is that they're usually not labeled, and if they are, you may have to remove your hand to [try to] read the label. Best examples of things that may belong on the stick are electric trim and push to talk. Things you should *not* have on the stick are starter, flaps, and cowl flaps. Some folks do that, but... Ed Wischmeyer |
Francois,
IMO there is nothing wrong with multiple switches on a control stick as long as they are done properly. You would not want to have a 1" long switch hanging out the side of a control stick that is very prone to accidental activation. I fly OH-58D Kiowa Warrior helicopter in the Army and our co-pilot cyclic stick has about 10 switches to control a wide variety of systems.. The pilot cyclic stick has a few less, but they still more than the maximum number on a Ray Allen stick. I have flown briefly with the exact stick grip you are talking about. It was very comfortable....in fact I ordered one last week for my plane directly from the manufacturer. Go to http://www.rayallencompany.com/index.html and you will find all the details. I ordered the G207 and opted for switch #3 and #5 to be used in place of the extra 2 push-button switches found on the 207. I will use the 4 small push button switches for elevator and aileron trim. The #3 switch will be used to operate my speed brake and the #5 switch will control my reflexor. Included with the control are some really nice labels so you can identify the switch functions. The stick can be mounted on a 3/4", 7/8", or 1" tube. The real advantage of directly ordering from Ray Allen is you can specify 4 different types of switches that will be used for those 2 extra switches on the G207. Jeff Dragonfly N1277W - http://fly-raptor.org/~jeff/ Tandem Wing Fly-In web site - http://www.fidnet.com/~letempt/ "Francois Marquis" wrote in message ... A agree too. My intented usage is: PTT, of course, Aileron trim (my pitch trim is mechanical) AutoPilot Engage/Disengage Argus Moving map select/Info modes Approach timer (although this is not absolutely necessary there) It is hard to imagine that someone would put the starter and other things on the baseball bat as stated in another post. Here's what I am talking about, particularely the model G7: http://www.aircraftspruce.com/catalo...stickgrips.php Francois Ed Wischmeyer wrote: Has anyone got an appreciation of the RAC (formerly Menzimer Aircraft Corporation) stick grips? I am particularely interested in the multiple switch model. Don't know which one that is, but there's a lot of very bad human factors that goes into stick grips with lots of switches. Attributes of things you want on the switch: * You use 'em a lot * You need 'em in a hurry * If you push 'em by mistake, no big deal A disadvantage of things on the stick is that they're usually not labeled, and if they are, you may have to remove your hand to [try to] read the label. Best examples of things that may belong on the stick are electric trim and push to talk. Things you should *not* have on the stick are starter, flaps, and cowl flaps. Some folks do that, but... Ed Wischmeyer |
That reminds me of an incident over Cape Coral Fl, a new pilot was flying a
moskito spray chopper and instead of the push to talk he pushed the wrong button on the stick and dumped his bug killer over a couple of houses, killed the landscape plants and ****ed the owner too. Ray "Ed Wischmeyer" wrote in message ... Has anyone got an appreciation of the RAC (formerly Menzimer Aircraft Corporation) stick grips? I am particularely interested in the multiple switch model. Don't know which one that is, but there's a lot of very bad human factors that goes into stick grips with lots of switches. Attributes of things you want on the switch: * You use 'em a lot * You need 'em in a hurry * If you push 'em by mistake, no big deal A disadvantage of things on the stick is that they're usually not labeled, and if they are, you may have to remove your hand to [try to] read the label. Best examples of things that may belong on the stick are electric trim and push to talk. Things you should *not* have on the stick are starter, flaps, and cowl flaps. Some folks do that, but... Ed Wischmeyer |
Yep - that was a "Oh, ****!
But, better bug spray than the same thing happening with some of the milatary stuff that flies in that area. "Sir, you know how the egg heads were wondering how the earthquake bomb would work in a populated area? Well...." I used to be pretty casual about flying up and down just off the west coast of Florida and also using the Gulf direct route VFR to Key West even if it meant being out far enough to deal with customs. Lots quicker than going all the way East and following the Keys down. However, I attended a "Rain Check" and they had invited guys from the Navy and Airforce to talk about the Warning Areas. They showed "gun camera" footage and radar tracks. Now, that was a real eye opener! J "Ray Romeu" wrote in message ... That reminds me of an incident over Cape Coral Fl, a new pilot was flying a moskito spray chopper and instead of the push to talk he pushed the wrong button on the stick and dumped his bug killer over a couple of houses, killed the landscape plants and ****ed the owner too. Ray "Ed Wischmeyer" wrote in message ... Has anyone got an appreciation of the RAC (formerly Menzimer Aircraft Corporation) stick grips? I am particularely interested in the multiple switch model. Don't know which one that is, but there's a lot of very bad human factors that goes into stick grips with lots of switches. Attributes of things you want on the switch: * You use 'em a lot * You need 'em in a hurry * If you push 'em by mistake, no big deal A disadvantage of things on the stick is that they're usually not labeled, and if they are, you may have to remove your hand to [try to] read the label. Best examples of things that may belong on the stick are electric trim and push to talk. Things you should *not* have on the stick are starter, flaps, and cowl flaps. Some folks do that, but... Ed Wischmeyer |
Jeff,
Thanks for the info. This is literally what i'd call *first hand* information! But as you mentioned, if the stick is incident prone (like inadvertently droping a map on it, for exemple) I'd, for my part, would be reluctant to have speed brakes, or anything other than system related switches on that stick, unless there was a safety device to prevent accidental activation. I'd nightmired myself accidently activating speed brakes while *fighting* in a xwind flare in gusty winds... But I guess that flying Helios have a different human interface than fixed wing. You have both hands tied, so to say, so all is left are your fingers! Francois Jeff wrote: Francois, IMO there is nothing wrong with multiple switches on a control stick as long as they are done properly. You would not want to have a 1" long switch hanging out the side of a control stick that is very prone to accidental activation. I fly OH-58D Kiowa Warrior helicopter in the Army and our co-pilot cyclic stick has about 10 switches to control a wide variety of systems.. The pilot cyclic stick has a few less, but they still more than the maximum number on a Ray Allen stick. I have flown briefly with the exact stick grip you are talking about. It was very comfortable....in fact I ordered one last week for my plane directly from the manufacturer. Go to http://www.rayallencompany.com/index.html and you will find all the details. I ordered the G207 and opted for switch #3 and #5 to be used in place of the extra 2 push-button switches found on the 207. I will use the 4 small push button switches for elevator and aileron trim. The #3 switch will be used to operate my speed brake and the #5 switch will control my reflexor. Included with the control are some really nice labels so you can identify the switch functions. The stick can be mounted on a 3/4", 7/8", or 1" tube. The real advantage of directly ordering from Ray Allen is you can specify 4 different types of switches that will be used for those 2 extra switches on the G207. Jeff Dragonfly N1277W - http://fly-raptor.org/~jeff/ Tandem Wing Fly-In web site - http://www.fidnet.com/~letempt/ "Francois Marquis" wrote in message ... A agree too. My intented usage is: PTT, of course, Aileron trim (my pitch trim is mechanical) AutoPilot Engage/Disengage Argus Moving map select/Info modes Approach timer (although this is not absolutely necessary there) It is hard to imagine that someone would put the starter and other things on the baseball bat as stated in another post. Here's what I am talking about, particularely the model G7: http://www.aircraftspruce.com/catalo...stickgrips.php Francois Ed Wischmeyer wrote: Has anyone got an appreciation of the RAC (formerly Menzimer Aircraft Corporation) stick grips? I am particularely interested in the multiple switch model. Don't know which one that is, but there's a lot of very bad human factors that goes into stick grips with lots of switches. Attributes of things you want on the switch: * You use 'em a lot * You need 'em in a hurry * If you push 'em by mistake, no big deal A disadvantage of things on the stick is that they're usually not labeled, and if they are, you may have to remove your hand to [try to] read the label. Best examples of things that may belong on the stick are electric trim and push to talk. Things you should *not* have on the stick are starter, flaps, and cowl flaps. Some folks do that, but... Ed Wischmeyer |
Francois,
I just got my very own G207 from the UPS man yesterday. $112 delivered to my doorstep directly from the manufacturer with the 2 non-standard switches installed. My speed brake will be controlled by an on-off-on switch and I will have a deployment light on the instrument panel.. If I should happen to accidentally bump the switch I would have an idiot light come on in front of my face and I suspect I will fell that 13" x 15" hanging out in the breeze http://www.fly-raptor.org/~jeff/Latest.htm My reflexor will be controlled by a (on)-off-(on) switch and a accidental momentary activation would have little or no effect. As far as your nightmare goes.....(I am an Aviation Safety Officer by profession) most fixed wing accidents happen within a mile of so of the airport, most during take-off or landing. When you are within a few miles of the airport you attention has to be on flying the airplane. At this point of your flight the cockpit should be a sterile environment and all activities should be limited to what it takes to safely operate the airplane. Your scenario is not very likely with the Ray Allen stick grip. If you are flying the plane, you would have to want to activate one of the 2 special switches. They are not located in a position where your thumb would naturally be located. Jeff "Francois Marquis" wrote in message ... Jeff, Thanks for the info. This is literally what i'd call *first hand* information! But as you mentioned, if the stick is incident prone (like inadvertently droping a map on it, for exemple) I'd, for my part, would be reluctant to have speed brakes, or anything other than system related switches on that stick, unless there was a safety device to prevent accidental activation. I'd nightmired myself accidently activating speed brakes while *fighting* in a xwind flare in gusty winds... But I guess that flying Helios have a different human interface than fixed wing. You have both hands tied, so to say, so all is left are your fingers! Francois Jeff wrote: Francois, IMO there is nothing wrong with multiple switches on a control stick as long as they are done properly. You would not want to have a 1" long switch hanging out the side of a control stick that is very prone to accidental activation. I fly OH-58D Kiowa Warrior helicopter in the Army and our co-pilot cyclic stick has about 10 switches to control a wide variety of systems.. The pilot cyclic stick has a few less, but they still more than the maximum number on a Ray Allen stick. I have flown briefly with the exact stick grip you are talking about. It was very comfortable....in fact I ordered one last week for my plane directly from the manufacturer. Go to http://www.rayallencompany.com/index.html and you will find all the details. I ordered the G207 and opted for switch #3 and #5 to be used in place of the extra 2 push-button switches found on the 207. I will use the 4 small push button switches for elevator and aileron trim. The #3 switch will be used to operate my speed brake and the #5 switch will control my reflexor. Included with the control are some really nice labels so you can identify the switch functions. The stick can be mounted on a 3/4", 7/8", or 1" tube. The real advantage of directly ordering from Ray Allen is you can specify 4 different types of switches that will be used for those 2 extra switches on the G207. Jeff Dragonfly N1277W - http://fly-raptor.org/~jeff/ Tandem Wing Fly-In web site - http://www.fidnet.com/~letempt/ "Francois Marquis" wrote in message ... A agree too. My intented usage is: PTT, of course, Aileron trim (my pitch trim is mechanical) AutoPilot Engage/Disengage Argus Moving map select/Info modes Approach timer (although this is not absolutely necessary there) It is hard to imagine that someone would put the starter and other things on the baseball bat as stated in another post. Here's what I am talking about, particularely the model G7: http://www.aircraftspruce.com/catalo...stickgrips.php Francois Ed Wischmeyer wrote: Has anyone got an appreciation of the RAC (formerly Menzimer Aircraft Corporation) stick grips? I am particularely interested in the multiple switch model. Don't know which one that is, but there's a lot of very bad human factors that goes into stick grips with lots of switches. Attributes of things you want on the switch: * You use 'em a lot * You need 'em in a hurry * If you push 'em by mistake, no big deal A disadvantage of things on the stick is that they're usually not labeled, and if they are, you may have to remove your hand to [try to] read the label. Best examples of things that may belong on the stick are electric trim and push to talk. Things you should *not* have on the stick are starter, flaps, and cowl flaps. Some folks do that, but... Ed Wischmeyer |
| Thread Tools | |
| Display Modes | |
