Extending shelf life of two part epoxy chemicals
Old August 26th 07, 01:42 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Extending shelf life of two part epoxy chemicals
Folks - I've read where you can stretch the pot life of two part
you've already mixed, but my concern is stretching the shelf life of
the individual chemicals once they are open.
I'd like to begin spraying 2 part over some of my smaller fittings.
I'll also have other parts preped so that if I have extra epoxy, I can
use it up ,. however, I'll still be left with more work to do in
three-six months and now, chemicals on the shelf which have been
exposed to air and probably will start to go downhill.
Anyone have suggestions for stretching the shelf life of the
individual chemicals? - Mike
Old August 26th 07, 03:58 PM posted to rec.aviation.homebuilt
Dave[_16_]
Keep them in the fridge.
I've done this with proseal and it still works two years after the
expiration date.
Old August 26th 07, 07:54 PM posted to rec.aviation.homebuilt
Fred the Red Shirt
expiration date.
Keep them well-sealed, especially in the fridge, presuming
that you also keep food in the fridge.
I'm not aware of a specific airborne contamination issue
with epoxy chemicals and food, but, as I recall from my
days as a lab tech, some chemicals kept in a refrigerator
will contaminate some foods that way.
More likely this is an issue with volotile sovents, but
why take a chance? Sealing the containers well is
sure to minimize oxidation and condensation also.
FF
Old August 26th 07, 11:20 PM posted to rec.aviation.homebuilt
Dennis Johnson
I keep my supply of epoxies at room temperature and I believe they will have
a very long shelf life; years if not decades. Of course, for any critical
bonding application, you should do a simple adhesive test to confirm it's
still good before proceeding. Using epoxy before its expiration date is
always the safest course, if not the cheapest.
Keeping some types of epoxy at cold temperature, such as in a refrigerator,
will cause them to crystallize. The crystallization should be reversed by
slowly heating the jug of epoxy in a pan of water until the crystals
dissolve before the epoxy is used.
Dennis Johnson
Old August 27th 07, 04:00 AM posted to rec.aviation.homebuilt
Ron Webb
I keep a gallon tin of West Systems epoxy in my (room temperature) basement,
for general purpose use. It usually lasts about 5 years. I have never
noticed any degradation in performance as it gets older. The only change is
that the hardener gets a mahogany color after a year or so, but it still
works fine.
I've got some cheap ($30/gal on EBay) stuff down there now that's several
years old. It's still clear and works fine.
"Dennis Johnson" wrote in message
have a very long shelf life; years if not decades. Of course, for any
critical bonding application, you should do a simple adhesive test to
confirm it's still good before proceeding. Using epoxy before its
expiration date is always the safest course, if not the cheapest.
refrigerator, will cause them to crystallize. The crystallization should
be reversed by slowly heating the jug of epoxy in a pan of water until the
crystals dissolve before the epoxy is used.
Dennis Johnson
Old August 27th 07, 03:30 PM posted to rec.aviation.homebuilt
Evan Carew
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Mike,
Here's a neat trick. When I purchase a new epoxy kit, I always go to
Krogers (or similar low end food market) and get two rubber maid juice
containers with snap top lids. You've probably seen these on the
shelves, you know, the one where the actual top of the container screws
off, and there's a little snap top port off center attached by a loop of
plastic so it can't be lost. Then, I go to my local camera shop and get
one of those cheaper cans of dust off. These are the ones that have a
light, liquefied hydrocarbon under pressure in the can. This hydrocarbon
is heavier than air, and when sprayed into the juice container, will act
as an inerter (I just made that word up) for your epoxy and hardener.
Evan
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (GNU/Linux)
iD8DBQFG0uAGpxCQXwV2bJARAhWkAKDC7f3u9xpjMyovLB9L21 mvnvrSqACgsvT1
urxSKdbG+DA8oHcmNyA5G3o=
=pTAr
-----END PGP SIGNATURE-----
Old August 27th 07, 05:37 PM posted to rec.aviation.homebuilt
Orval Fairbairn
works fine.
That mahogany color is moisture that gets into the hardener. For best
results, heat it to remove the water -- the water reduces strength of
the bonds.
Old August 27th 07, 09:13 PM posted to rec.aviation.homebuilt
Blueskies
"Orval Fairbairn" wrote in message
news
works fine.
the bonds.
What would be a good temperature?
Old August 28th 07, 01:33 AM posted to rec.aviation.homebuilt
Orval Fairbairn
news
basement,
is
works fine.
the bonds.
I'm not sure. A friend who used to work at SRI and researched epoxies
told me about it. I would suggest trying a few samples and temperatures.
Old August 28th 07, 07:51 PM posted to rec.aviation.homebuilt
I may be the one misunderstanding the OP's request, but I thought he
was asking about 2 part epoxy - Paint - not laminating resin. If so
there isn't much that can be done about extending the shelf life once
the hardner has been opened. Maybe blow some argon from the TIG in
the can and do the same with a zip-lock bag around it for storage?
The last place to store it is in the fridge with food. (been there,
done that, and the fridge made the food taste strange for more than a
year) The stuff reacts with moisture and the innards of a fridge is a
very moist place.
Leon McAtee
Requirement to paint over 2-part epoxy? Michael Horowitz Home Built 3 May 29th 07 11:59 PM
Steel prep for two part epoxy? Michael Horowitz Home Built 8 May 21st 07 02:55 AM
Europe Tests Established Chemicals on Millions of Animals TONY Piloting 1 February 15th 07 01:39 AM
Shelf Life of [Spare] Tires? [email protected] Soaring 8 November 16th 05 07:03 PM
Off the shelf gear in military a/c Bill Silvey Military Aviation 18 October 8th 03 11:28 AM
