Requirement to paint over 2-part epoxy?
Old May 20th 07, 03:44 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Requirement to paint over 2-part epoxy?
I know that primer(over steel) is designed to provide a base for a top
coat, and (allegedly) you should not leave steel with only a zinc
chromate coating (although I've seen steel fuselages zinc chromated
only and they appear in good condition).
I have read that if you appy a 2-part epoxy primer, you don't need a
top coat. Anyone else read that? - Mike
Old May 21st 07, 01:35 AM posted to rec.aviation.homebuilt
stol
If you like the color of the primer then a top coat will only add
extra weight. IMHO
Ben
Old May 21st 07, 04:26 AM posted to rec.aviation.homebuilt
Orval Fairbairn
In article . com,
extra weight. IMHO
Ben
The paint companies around here (PPG, for instance) say that primers
will not protect the steel long-term -- you need to apply a top coat to
seal it.
Check with a good auto/marine paint company -- they have a wealth of
information at their disposal.
Old May 29th 07, 11:59 PM posted to rec.aviation.homebuilt
kevmor[_3_]
I've heard that most primers are porous (maybe not epoxy as much, though)
and will not completely seal as a paint would.
"Orval Fairbairn" wrote in message
news
In article . com,
extra weight. IMHO
Ben
seal it.
Steel prep for two part epoxy? Michael Horowitz Home Built 8 May 21st 07 02:55 AM
T-88 epoxy Lou Home Built 1 December 4th 06 11:15 PM
Part 135 Question - Weather Reporting requirement G Farris Instrument Flight Rules 5 October 21st 04 11:05 PM
EPOXY GLUES minot piper e Restoration 0 January 30th 04 01:13 AM
epoxy aircraft seats? Lpmcatee356 Home Built 26 December 3rd 03 11:16 PM
