Holding Pattern Question
Old September 25th 07, 01:42 AM posted to rec.aviation.ifr
Steven P. McNicoll
Default Holding Pattern Question
"Matt Whiting" wrote in message
If no delay is expected, why issue a hold?
For a variety of reasons. Let's say your destination is an uncontrolled
field and there's traffic ahead of you for that field. The controller can't
clear you for the approach because the preceding aircraft hasn't cancelled,
but he expects it to cancel before you'd experience any delay.
Old September 25th 07, 01:48 AM posted to rec.aviation.ifr
Matt Whiting
In that case, you better ask for an EFC if you haven't received further
clearance prior to arrival at the holding fix.
Matt
Old September 25th 07, 01:54 AM posted to rec.aviation.ifr
Dennis Johnson
can't clear you for the approach because the preceding aircraft hasn't
cancelled, but he expects it to cancel before you'd experience any delay.
I thought you had to get an expect further clearance time as part of the
hold instructions in case your radio failed shortly after directed to hold?
Otherwise, how would you know how many turns to make in holding before
proceeding on course? I'm not arguing, just asking,
Dennis
Old September 25th 07, 01:58 AM posted to rec.aviation.ifr
Steven P. McNicoll
Yes, but in that case the controller expects to issue an approach clearance
before you arrive at the holding fix. That's why no delay is expected.
Old September 25th 07, 02:02 AM posted to rec.aviation.ifr
Steven P. McNicoll
"Dennis Johnson" wrote in message
hold? Otherwise, how would you know how many turns to make in holding
before proceeding on course? I'm not arguing, just asking,
Why is it that comm radios fail but nav radios do not?
http://www.faa.gov/airports_airtraff...406.html#4-6-1
Old September 25th 07, 02:10 AM posted to rec.aviation.ifr
Matt Whiting
It just seems odd that they would issue the hold then. I guess it saves
a little time if you do actually have to hold, but it also seems like it
would be easy to also forget to issue the EFC.
Matt
Old September 25th 07, 02:12 AM posted to rec.aviation.ifr
Matt Whiting
Probably because com radios require a functioning microphone, PTT and
speakers or earphones. More parts to fail and thus more likelihood of
failure. Most pilots carry enough spares, but even so there is more
likelihood of a comm failure than a nav failure.
Matt
Old September 25th 07, 02:16 AM posted to rec.aviation.ifr
Mark Hansen
Dennis
The EFC is of use only if you experience communication failure. Assuming
that's the case, then with no EFC, you're expected to proceed upon reaching
the holding fix as though the EFC was zero.
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Old September 25th 07, 02:22 AM posted to rec.aviation.ifr
Steven P. McNicoll
It just seems odd that they would issue the hold then. I guess it saves a
Well, if things don't go as expected, what do you think can cause the
greater problem, not issuing the EFC, or not issuing the hold?
Old September 25th 07, 02:30 AM posted to rec.aviation.ifr
Roy Smith
I've had several lost-comms. I seem to remember:
1) Fried xmit relay in the audio panel
2) Defective headset jacks
3) Broken wire in my headset cable
None of these affected the nav radios.
Bose X - $995 and holding... [email protected] Piloting 23 November 30th 05 12:57 AM
Holding pattern reporting Yossarian Instrument Flight Rules 14 July 4th 05 10:57 AM
Stupid Newbie Pattern Question Lakeview Bill Piloting 76 June 11th 05 02:54 PM
Holding at CHS Stuart King Instrument Flight Rules 3 November 10th 03 07:52 PM
Holding Pattern Entries Dan Luke Instrument Flight Rules 17 July 11th 03 05:18 AM
