Holding Pattern Question
Old September 24th 07, 06:42 PM posted to rec.aviation.ifr
Dennis Johnson
Default Holding Pattern Question
I'm probably over-thinking holding patterns and have become confused.
When given instructions to hold at a non-published holding pattern, ATC will
specify:
1. The direction from the fix, such as north, north-east, etc.
2. The name of the holding fix.
3. The radial, course, or airway on which the aircraft is to hold.
4. The leg length and direction of turns if they are not standard.
5. The expect further clearance time.
Here's my question: If I'm told to hold on a radial (as opposed to a
course), does that mean that I'm flying away from the station when I'm "on
course" in the holding pattern?
For example, I'm given the instruction, "Hold south of the VOR on the 180°
radial, expect further clearance in 15 minutes." Once I get established in
the holding pattern, do I track inbound to the station on the 180° radial or
do I track outbound on the 180° radial?
How would that be different if I were given the same instructions, except
hold on the 180° course (instead of the 180° radial)?
Dennis
Old September 24th 07, 06:57 PM posted to rec.aviation.ifr
Dan Luke[_2_]
No. It means that you fly to the fix *on* the radial. IOW you are to be on
the radial when inbound to the fix.
or do I track outbound on the 180° radial?
Inbound.
You won't be given that instruction, at least not by a controller who knows
what he's doing.
Dan
T-182T at BFM
Old September 24th 07, 07:06 PM posted to rec.aviation.ifr
B A R R Y[_2_]
Inbound. The fix and radial define the inbound side of a hold.
Dave Butler
what he's doing.
The only context in which "course" might be used, that I can think of,
is where you might be cleared to hold on a "final approach course".
DB
Old September 24th 07, 07:08 PM posted to rec.aviation.ifr
Mark Hansen
specify:
You always hold at the fix. You are on the holding course when flying to
the fix.
For example, I'm given the instruction, "Hold south of the VOR on the 180�
the holding pattern, do I track inbound to the station on the 180� radial or
do I track outbound on the 180� radial?
You fly toward the fix (the VOR in this case) on the holding radial (180
in this case). If you remember that you always fly to the fix, you won't
be able to mix these up.
hold on the 180� course (instead of the 180� radial)?
I would ask the controller for a clarification. Have a look at the 7110.65
to see what they will do for holding instructions.
Dennis
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Old September 24th 07, 07:36 PM posted to rec.aviation.ifr
Bob Gardner
You have received excellent answers, but that won't keep me from piling
on....when inbound to the fix, you have navigational guidance; on the
outbound leg you are using dead reckoning. You never fly outbound with
navigational guidance.
Bob Gardner
"Dennis Johnson" wrote in message
will specify:
in the holding pattern, do I track inbound to the station on the 180°
radial or do I track outbound on the 180° radial?
Dennis
Old September 24th 07, 08:47 PM posted to rec.aviation.ifr
Dennis Johnson
Thanks so much for the speedy and excellent answers to my question about
holding! I have returned to flying after a decades-long absence and am
going to start flying with an instructor tomorrow to prep for the IPC. It's
amazing how much I've forgotten. At least this is one mistake I won't make.
Dennis
Old September 24th 07, 11:50 PM posted to rec.aviation.ifr
Steven P. McNicoll
will specify:
An EFC is not issued if no delay is expected.
Old September 25th 07, 12:32 AM posted to rec.aviation.ifr
Matt Whiting
will specify:
If no delay is expected, why issue a hold?
Matt
Old September 25th 07, 12:37 AM posted to rec.aviation.ifr
Bonehenge (B A R R Y)
On Mon, 24 Sep 2007 23:32:00 GMT, Matt Whiting
Because people who write written exams need a reason to ask a
question? G
Bose X - $995 and holding... [email protected] Piloting 23 November 30th 05 12:57 AM
Holding pattern reporting Yossarian Instrument Flight Rules 14 July 4th 05 10:57 AM
Stupid Newbie Pattern Question Lakeview Bill Piloting 76 June 11th 05 02:54 PM
Holding at CHS Stuart King Instrument Flight Rules 3 November 10th 03 07:52 PM
Holding Pattern Entries Dan Luke Instrument Flight Rules 17 July 11th 03 05:18 AM
