Hello.
I have a mechanical PZL vario that indicates -0.5 kts while sitting still and I would like to zero it. Does anyone know the proper adjustment procedure? When I take the glass off I cannot see a place where I could put a small drop of paint or wax to act as counterweight. Is there a "zero" screw that I am missing? I haven't been too ambitious with it since it is an extremely delicate mechanism and I don't want to mess it up. Any help would be appreciated. Thanks, -Gonzo (EE) |
On Sep 28, 4:42 pm, wrote:
Hello. I have a mechanical PZL vario that indicates -0.5 kts while sitting still and I would like to zero it. Does anyone know the proper adjustment procedure? When I take the glass off I cannot see a place where I could put a small drop of paint or wax to act as counterweight. Is there a "zero" screw that I am missing? I haven't been too ambitious with it since it is an extremely delicate mechanism and I don't want to mess it up. Any help would be appreciated. Thanks, -Gonzo (EE) I have a SZD-55-1 with a PZL variometer PR-03. To zero it you need to disconnect one of the tube from the back of the instrument. I have forgoten witch one but think it is marked with an "S". Look inside to be sure. Anyhow inside is an adjustment screw. It takes a very small flat blade screwdriver. Just a small tweek is all it will need. If you turn it the wrong way the error will increase. |
| SZD-55 Wheel Brake Adjustment | WDM | Soaring | 2 | January 20th 11 10:25 AM |
| ARC RT385A CDI Adjustment | facpi | General Aviation | 3 | October 20th 06 12:52 AM |
| KI-209 VOR/LOC/GS Indicator adjustment | kontiki | Owning | 13 | April 26th 05 12:35 AM |
| Brake adjustment on the 2-33 | GM | Soaring | 11 | April 19th 05 08:05 PM |
| Adjustment of Altimeter | Ron | Home Built | 5 | April 5th 04 04:12 AM |
