AVGAS 80 & MOGAS
Old November 1st 07, 04:27 PM posted to rec.aviation.piloting
Morgans[_2_]
Default AVGAS 80 & MOGAS
m...
Morgans wrote:
Also, it is VERY important to have dividers in a large tanker, so when
you are putzing about with a third of a load, that you don't have the
whole load shift to the front at one time, or back, or whatever.
The tanks will have baffles in ADDITION to the tank segregation. Even
2000 gallons is more than you want to slosh around uncontrolled.
Of course. Baffles will still let all of the liquid flow to one part of the
tank, or the other. It does let it flow much more slowly, and predictably,
so it is not as much of a problem, though.
Jim in NC
Old November 8th 07, 01:39 AM posted to rec.aviation.piloting
Dana M. Hague
Back in the 1980's when I still had my 1941 T-Craft (which had an A-65
and ran fine on the leaded regular mogas which was still available at
a few stations then), I looked at the type certificate and all it said
was "73 octane minimum". Never was clear whether that meant mogas was
legal even without an STC.
-Dana
If replying by email, please make the obvious changes.
Southern DOS: Y'all reckon? (Yep/Nope)
Old November 8th 07, 03:51 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Dana M. Hague d(dash)m(dash)hague(at)comcast(dot)net wrote in
Well, kinda. Avgas was only relatively new when tha airplane was made. Most
antiquers today shy away from avgas if at all possible (I'm talking about
guys running early Wrights and Kinners and so on now) My LeBlond specifies
a minimum of 60 octane, which is basically carrot juice and doesn't like
lead at all..There was an Avgas, before my time, that was a levle below 80.
90 was still available, though scare, when I started and I have seen
115/145 not all that long ago in places that DC7s and what not were still
frequenting and any place the US Navy was still operating P-2 s in earnest
like Keflavik.
IIRC the 115/145 was purple, the 90/98 was blue and the 70ish octane stuff
was brownish yellow, but never having seen it I only knew that from
whatever books or lists still carried that info.
But the little pre-war designed flat fours were widely run on mogas after
80 started getting scarce, STC or no STC. The FAA doesn't seem to be too
bothered about it.
Bertie
Old November 8th 07, 05:43 PM posted to rec.aviation.piloting
Big John
Go to:
http://books.google.com/books?id=QhE...eKUVPA#PPP1,M1
Checked this URL and works for me from this posting.
Good info on aircraft fuels from 30's on.
Big John
On Thu, 8 Nov 2007 03:51:48 +0000 (UTC), Bertie the Bunyip
like Keflavik.
bothered about it.
Bertie
Old November 8th 07, 10:34 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
Hey, you left out 100/130 green gas. I actually found an FBO in Montana
selling this stuff a few years ago. They said they carried it mostly for
supplying old, turbocharged radials on the firebombers in the summertime.
Whenever I'd tell the desk to top me off with avgas, they'd ask, "Blue or
green?".
Message posted via http://www.aviationkb.com
Old November 9th 07, 12:39 AM posted to rec.aviation.piloting
"JGalban via AviationKB.com" u32749@uwe wrote in
news:7aed1bb2bf956@uwe:
stuff was brownish yellow, but never having seen it I only knew that
from whatever books or lists still carried that info.
Montana
for supplying old, turbocharged radials on the firebombers in the
summertime.
"Blue or
green?".
Yeah, that's right. The blue 100LL didn;t come around until the late 70s.
The early atches had some serious problems with hygroscopy and I nearly met
my end from this as did a friend of mine.
Also it smells like hell.
Bertie
"Over time, Mogas deteriorates faster than Avgas" Jay Honeck Piloting 32 September 18th 07 07:41 PM
Mogas for an O-320 with 160 HP? jls Home Built 3 December 31st 04 07:48 PM
Water/Avgas/Gasahol/Mogas Corky Scott Home Built 12 August 17th 04 04:25 AM
Water/Avgas/Gasahol/Mogas jc Owning 11 August 17th 04 04:25 AM
Water/Avgas/Gasahol/Mogas Corky Scott Owning 0 August 11th 04 01:27 PM
