Mogas for an O-320 with 160 HP?
Old December 28th 04, 01:13 AM
jls
Default Mogas for an O-320 with 160 HP?
Just wondering what the collective experience is, if any. I know of
several people with the 160 HP O-320 using mogas, but they're careful about
vapor lock in summer. Used in experimental aircraft, of course, not in a
certified aircraft. Keep in mind too that the CR is 8.5 to 1.
A friend wants to do it and I told him I thought it was ok as long as he
monitored his CHT and EGT on all 4 cylinders, used 92 octane only, and took
off and landed on 100 LL.
What do YOU think?
Old December 28th 04, 03:12 AM
Orval Fairbairn
What do YOU think?
The O-320 160 hp was originally certificated on Grade 91/96, so the
above operation sounds conservative.
Old December 28th 04, 02:15 PM
Orval Fairbairn wrote:
of
careful about
not in a
as he
and took
What do YOU think?
I mix about 15 - 20 % 100 LL with in my tank of mogas and get leaded
gas like the Lyc. was designed for. EAA had some research on this
years ago and found that the octane rating was higher with this
mixture. I have used it for years with no more problems than 80/87 or
100 LL. I have seen vapor lock with all of them - no one more than any
other. When you park in the hot sun and the fuel gets hot, you need to
run the boost pump until it cools down.
Old December 31st 04, 07:48 PM
Dale Larsen
Used to have a 'Super Colt' with an O320, 160HP. It had an STC for mogas,
and ran just fine on it. Never any problems even on 100+ degree days. Most
of the time I ran a mixture of 100LL and mogas, anywhere from 50/50 to 100%
100LL. The only difference I noticed was the plugs were less likely to foul
with the mogas or mogas/avgas mixture.
Based on my experience, I wouldn't hesitate to use mogas in a high wing
airframe, but wouldn't feel comfortable using it in a low wing.
Just an opnion. . .
Grandmother Goes Down at the Pole BJ Home Built 66 January 13th 04 04:10 PM
Lubricating the primer shaft Michael Horowitz Home Built 9 November 20th 03 12:26 AM
Hot weather and autogas? Rich S. Home Built 33 July 30th 03 11:25 PM
