#21
Jay Honeck wrote in news:1194537883.203290.75060
@e9g2000prf.googlegroups.com: Do a search for Lockheed Electra, Tell City Crash, 1960 I believe. Reference that with propeller whirl mode, and you should come up with all you'll ever need to know about resonant frequency as relates to destructive force. Hmmm. If it happened to another Electra in 1960, that says a lot. The crash I'm talking about happened in 1938. Two completely different airplanes. You've obviously been drinking the tidy bowl as well as sniffing the furntiure polish. Bertie |
Jay Honeck wrote in
oups.com: A coast-to-coast flight originating from Spokane? Spokane is in eastern Washington, not far from the Idaho border. Must be nearly 400 miles from the Pacific coast. My mistake. The author called the flight "trans-continental" and "across America" -- which my brain translated into "coast-to-coast" for some reason... Oven cleaner is my bet Bertie |
![]() "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message ... Would you count KSEA to KJFK as Trans-continental? Yes. |
Out of physics curiousity, can anyone point to any references on induced
vibrations in aircraft (or any other mechanical) structures associated with or caused by parametrically induced induced *subharmonic* or *parametric* oscillations? ["Parametric oscillation" = a phenomena well known in electronics and optics, in which if a structure has natural resonances with resonant frequencies f1 and f2, and the structure is then excited or "pumped" with a periodic force at a "pump" frequency fp = f1 + f2, this can cause coupled oscillations to occur and grow at the "signal" and "idler" frequencies f1 and f2.] |
Tina wrote:
Jay, somewhere I had seen a film of a flight test of a glider whose wings started a distructive vibration. http://www.youtube.com/watch?v=mxFOHoy-UNQ -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200711/1 |
Tina wrote:
I don't remember the details but the frequency might have been the order of a couple of hertz -- so the wingtip went up a little, down a little more, up even more, and after a few such cycles as I remember it left the airplane. http://www.youtube.com/watch?v=8D7YCCLGu5Y -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200711/1 |
Jay
After the two crashes they found the problem and fixed it but then they didn't sell good to airlines due to crash history. Navy bought a large number (with MAD gear) after fix, that are now configured to the P-3C Orion (ASW) configuration and many P-3's were sold around the world in ASW confguration. Navy is still using them while waiting for a new bird. There is a request out to industry for a new bird??? Big John **************************************** On Thu, 08 Nov 2007 06:09:52 -0800, Jay Honeck wrote: I've just finished reading the tale of the first round trip coast-to- coast flight (which was accomplished by mid-air refueling, occasionally from milk cans) from Spokane, WA to the east coast and back, way back in 1929. They flew a distance of 10,000 miles (they circled over airports whilst refueling) without landing. A fascinating story, printed in a terrific magazine, "Aviation History". One of the pilots, Nick Mamer, went on to a career with Northwest Air Lines. The author of the article states that he was killed in 1938 flying a Lockheed 14 Super Electra over Montana when the plane crashed after suffering structural failure due to harmonic vibration. All passengers and crew were killed. This is something I've never heard much about. I understand harmonic vibration can destroy any structure, given enough time and amplitude -- but wouldn't a pilot be aware of such an event occurring in flight? I picture something similar to flying a twin without synching the props -- the noise and vibration will just about drive you crazy. I don't have any further information on this crash, so I suppose the vibration could have destroyed the engine mounts, causing the engines to depart the airframe. This would probably be impossible to detect from the cockpit before disaster struck. Does anyone have any more information on this phenomenon, and this crash specifically? Also, are there any Super Electras still flying and, if so, how did they solve this problem? |
#28
The T-28A had a bad problem. At normal cruise RPM the vibrations of
the big wide paddle bladed prop would cause the crank to fail at a square cut corner on it. They restricted constant operation in a wide band of RPM ![]() undercut the square corner (where prop shaft met the crank throw) and bird still lost props and became a glider. Navy in their T-28B put a new engine and prop on it and no problems. Some times it pays to go sloppy seconds ![]() Big John On Thu, 8 Nov 2007 17:25:08 +0000 (UTC), Bertie the Bunyip wrote: "F. Baum" wrote in news:1194534592.304042.93710 : On Nov 8, 7:46 am, Dudley Henriques wrote: Does anyone have any more information on this phenomenon, and this crash specifically? Also, are there any Super Electras still flying and, if so, how did they solve this problem? -- Do a search for Lockheed Electra, Tell City Crash, 1960 I believe. Reference that with propeller whirl mode, and you should come up with all you'll ever need to know about resonant frequency as relates to destructive force. DH Dud, Isnt Harmonics and Whirl Mode Flutter two diferent things ? I used to fly a turboprop that had Whirl Mode issues (And a crash resulting from this), but not any resonance restrictions. On the other hand, I flew Scouts that when equiped with a certain propeller (For banner towing) had restrictions on certain RPM ranges because of resonance issues. They were traeted as two entirely different restrictions. KFB That's right. The whirl mode thing is a bit different, but there's a common thread in that they both rely on frequency. I've flown quite a few airplanes that had veboten RPM bands for various reasons. Lots of old Radials with steel props had rather large bands because of the probablity of turning the prop into a rather large piano string and thereby putting too much stress on either the blade or the crank. AFAIK prop inspection/replacement was the only AD ever put on a Stearman 75 on account of this problem. Generally it isn't an issue with wood props, BTW, since their resonancy is intricate and wide rather than narrow and focused. Which is why you don't see a lot of stainless steel violins. I'm not familiar with the tail problem on the Lockheed 10/12 so don;'t even know if was related to harmonics from the prop. It's probable that buffeting from the props could cause a resonant flutter in tail surfaces, though. That airplane was rght at th eleading edge of technology in it;s day, when cantilever aluminum structures were all the rage. Beech had problems with their similar model 18 in that they fjukked up the design of the center section leading, eventauly, to a few shed wings and a nasty and seriously ugly AD to strap the outer panel spars to each other to relieve it. Bertie Bertie |
#29
Jay Honeck wrote:
Hmmm. If it happened to another Electra in 1960, that says a lot. The crash I'm talking about happened in 1938. I guess maybe they DIDN'T address the problem...? Lockheed reused the Electra name. The 1930s Electra (think Amelia Earhart) was a piston twin. The 1950s Electra was a 4 engine turboprop airliner. http://www.constable.ca/sd076a.jpg http://www.spain4uk.co.uk/images/wil...tra_G-LOFE.jpg John Galban=====N4BQ (PA28-180) -- Message posted via http://www.aviationkb.com |
#30
High wings and structural strength | Mxsmanic | Piloting | 21 | November 23rd 06 11:54 PM |
Looking for a DER/Structural | mhorowit | Home Built | 3 | June 25th 06 04:33 AM |
structural adhesive | circio0 | Home Built | 5 | May 30th 06 09:34 AM |
Any Lockheed Structural Repair Manuals out there? | Robert Murray | Restoration | 3 | December 2nd 04 05:59 AM |
Structural adhesive question | BD5ER | Home Built | 1 | August 3rd 03 06:03 AM |
