#21
![]() "Ron Natalie" wrote in message m... Morgans wrote: Also, it is VERY important to have dividers in a large tanker, so when you are putzing about with a third of a load, that you don't have the whole load shift to the front at one time, or back, or whatever. The tanks will have baffles in ADDITION to the tank segregation. Even 2000 gallons is more than you want to slosh around uncontrolled. Of course. Baffles will still let all of the liquid flow to one part of the tank, or the other. It does let it flow much more slowly, and predictably, so it is not as much of a problem, though. -- Jim in NC |
Back in the 1980's when I still had my 1941 T-Craft (which had an A-65
and ran fine on the leaded regular mogas which was still available at a few stations then), I looked at the type certificate and all it said was "73 octane minimum". Never was clear whether that meant mogas was legal even without an STC. -Dana -- -- If replying by email, please make the obvious changes. ------------------------------------------------------------------------------- Southern DOS: Y'all reckon? (Yep/Nope) |
Dana M. Hague d(dash)m(dash)hague(at)comcast(dot)net wrote in
: Back in the 1980's when I still had my 1941 T-Craft (which had an A-65 and ran fine on the leaded regular mogas which was still available at a few stations then), I looked at the type certificate and all it said was "73 octane minimum". Never was clear whether that meant mogas was legal even without an STC. Well, kinda. Avgas was only relatively new when tha airplane was made. Most antiquers today shy away from avgas if at all possible (I'm talking about guys running early Wrights and Kinners and so on now) My LeBlond specifies a minimum of 60 octane, which is basically carrot juice and doesn't like lead at all..There was an Avgas, before my time, that was a levle below 80. 90 was still available, though scare, when I started and I have seen 115/145 not all that long ago in places that DC7s and what not were still frequenting and any place the US Navy was still operating P-2 s in earnest like Keflavik. IIRC the 115/145 was purple, the 90/98 was blue and the 70ish octane stuff was brownish yellow, but never having seen it I only knew that from whatever books or lists still carried that info. But the little pre-war designed flat fours were widely run on mogas after 80 started getting scarce, STC or no STC. The FAA doesn't seem to be too bothered about it. Bertie |
Go to:
http://books.google.com/books?id=QhE...eKUVPA#PPP1,M1 Checked this URL and works for me from this posting. Good info on aircraft fuels from 30's on. Big John ******************************************** On Thu, 8 Nov 2007 03:51:48 +0000 (UTC), Bertie the Bunyip wrote: Dana M. Hague d(dash)m(dash)hague(at)comcast(dot)net wrote in : Back in the 1980's when I still had my 1941 T-Craft (which had an A-65 and ran fine on the leaded regular mogas which was still available at a few stations then), I looked at the type certificate and all it said was "73 octane minimum". Never was clear whether that meant mogas was legal even without an STC. Well, kinda. Avgas was only relatively new when tha airplane was made. Most antiquers today shy away from avgas if at all possible (I'm talking about guys running early Wrights and Kinners and so on now) My LeBlond specifies a minimum of 60 octane, which is basically carrot juice and doesn't like lead at all..There was an Avgas, before my time, that was a levle below 80. 90 was still available, though scare, when I started and I have seen 115/145 not all that long ago in places that DC7s and what not were still frequenting and any place the US Navy was still operating P-2 s in earnest like Keflavik. IIRC the 115/145 was purple, the 90/98 was blue and the 70ish octane stuff was brownish yellow, but never having seen it I only knew that from whatever books or lists still carried that info. But the little pre-war designed flat fours were widely run on mogas after 80 started getting scarce, STC or no STC. The FAA doesn't seem to be too bothered about it. Bertie |
IIRC the 115/145 was purple, the 90/98 was blue and the 70ish octane stuff was brownish yellow, but never having seen it I only knew that from whatever books or lists still carried that info. Hey, you left out 100/130 green gas. I actually found an FBO in Montana selling this stuff a few years ago. They said they carried it mostly for supplying old, turbocharged radials on the firebombers in the summertime. Whenever I'd tell the desk to top me off with avgas, they'd ask, "Blue or green?". John Galban=====N4BQ (PA28-180) -- Message posted via http://www.aviationkb.com |
"JGalban via AviationKB.com" u32749@uwe wrote in
news:7aed1bb2bf956@uwe: Bertie the Bunyip wrote: IIRC the 115/145 was purple, the 90/98 was blue and the 70ish octane stuff was brownish yellow, but never having seen it I only knew that from whatever books or lists still carried that info. Hey, you left out 100/130 green gas. I actually found an FBO in Montana selling this stuff a few years ago. They said they carried it mostly for supplying old, turbocharged radials on the firebombers in the summertime. Whenever I'd tell the desk to top me off with avgas, they'd ask, "Blue or green?". Yeah, that's right. The blue 100LL didn;t come around until the late 70s. The early atches had some serious problems with hygroscopy and I nearly met my end from this as did a friend of mine. Also it smells like hell. Bertie |
"Over time, Mogas deteriorates faster than Avgas" | Jay Honeck | Piloting | 32 | September 18th 07 07:41 PM |
Mogas for an O-320 with 160 HP? | jls | Home Built | 3 | December 31st 04 07:48 PM |
Water/Avgas/Gasahol/Mogas | Corky Scott | Home Built | 12 | August 17th 04 04:25 AM |
Water/Avgas/Gasahol/Mogas | jc | Owning | 11 | August 17th 04 04:25 AM |
Water/Avgas/Gasahol/Mogas | Corky Scott | Owning | 0 | August 11th 04 01:27 PM |
