I'm reading the specs for the Remos G-3. Looks like a nice plane. But
one thing that gobsmacked me was the note that "Max endurance: 6hrs at 4300rpm". Does it really run at 4300rpm? Is the prop geared down from that? I mean, I normally fly a Lance with a 300hp IO-540, and it's pretty damn noisy at 2650 rpm. I shudder to think what a prop spinning at 4300 rpm sounds like. -- Paul Tomblin http://blog.xcski.com/ "All life is transitory. A dream. We all come together in the same place at the end of time. If I don't see you again here, I will see you in a little while in the place where no shadows fall." - Delenn |
Paul Tomblin wrote:
I'm reading the specs for the Remos G-3. Looks like a nice plane. But one thing that gobsmacked me was the note that "Max endurance: 6hrs at 4300rpm". Does it really run at 4300rpm? Is the prop geared down from that? I mean, I normally fly a Lance with a 300hp IO-540, and it's pretty damn noisy at 2650 rpm. I shudder to think what a prop spinning at 4300 rpm sounds like. I believe all Rotax 912's have a prop gear reduction, with ratios of 2:1, 2.24:1 and 2.58:1 available. I couldn't see any specs for what the G-3 comes with, but would bet it was either the 2.24 or 2.58. |
Paul Tomblin wrote:
I'm reading the specs for the Remos G-3. Looks like a nice plane. But one thing that gobsmacked me was the note that "Max endurance: 6hrs at 4300rpm". Does it really run at 4300rpm? Yes and yes. |
A quick Google search yielded this info on the engine used in the
Remos: http://www.rotaxservice.com/rotax_en...ax_912ULSs.htm |
![]() "Paul Tomblin" wrote in message ... In a previous article, said: A quick Google search yielded this info on the engine used in the Remos: http://www.rotaxservice.com/rotax_en...ax_912ULSs.htm Ok, I'm a little embarassed that I couldn't find that info myself. Is a reduction gearbox seen as a reliability problem, or isn't that such a big deal any more? -- I haven't flown one, so I can't be certain, but I'm guessing it would at least seriously hamper the engines ability to windmill during a temporary fuel starvation, or carb ice situation. |
On Nov 29, 3:47 pm, (Paul Tomblin) wrote:
In a previous article, said: A quick Google search yielded this info on the engine used in the Remos: http://www.rotaxservice.com/rotax_en...ax_912ULSs.htm Ok, I'm a little embarassed that I couldn't find that info myself. Is a reduction gearbox seen as a reliability problem, or isn't that such a big deal any more? -- Paul Tomblin http://blog.xcski.com/ "Oh my G'Quan, they killed Koshi!" - Citizen G'kyle, Babylon Park I don't think anyone really knows the reliability of this engine and gearbox. It hasn't been in service long enough. I have been training behind one in a Flight Design CT, and it is not a noisy engine at all. When I watch a CT take off I am really struck by how quiet the airplane is. Also the engine has altitude-compensating carbs, so there is no mixture to mess with. In flight the engine is very responsive and smooth. I know a lot of people are put off by the high rpms, but if the engine is designed to run at those speeds I am not sure that is really a problem. My one comment on the gearbox is it has a harmonic resonance vibration at about 1800-1900 rpm (taxi speeds) which is very noticeable. I try to avoid that, and bump it up to about 2000, and it's nice and smooth there. Phil |
Phil wrote in
: On Nov 29, 3:47 pm, (Paul Tomblin) wrote: In a previous article, said: A quick Google search yielded this info on the engine used in the Remos: http://www.rotaxservice.com/rotax_en...ax_912ULSs.htm Ok, I'm a little embarassed that I couldn't find that info myself. Is a reduction gearbox seen as a reliability problem, or isn't that such a big deal any more? -- Paul Tomblin http://blog.xcski.com/ "Oh my G'Quan, they killed Koshi!" - Citizen G'kyle, Babylon Park I don't think anyone really knows the reliability of this engine and gearbox. It hasn't been in service long enough. It's been around almost twenty years now! Bertie |
Phil wrote:
On Nov 29, 3:47 pm, (Paul Tomblin) wrote: In a previous article, said: A quick Google search yielded this info on the engine used in the Remos: http://www.rotaxservice.com/rotax_en...ax_912ULSs.htm Ok, I'm a little embarassed that I couldn't find that info myself. Is a reduction gearbox seen as a reliability problem, or isn't that such a big deal any more? -- Paul Tomblin http://blog.xcski.com/ "Oh my G'Quan, they killed Koshi!" - Citizen G'kyle, Babylon Park I don't think anyone really knows the reliability of this engine and gearbox. It hasn't been in service long enough. I have been training behind one in a Flight Design CT, and it is not a noisy engine at all. When I watch a CT take off I am really struck by how quiet the airplane is. Also the engine has altitude-compensating carbs, so there is no mixture to mess with. In flight the engine is very responsive and smooth. I know a lot of people are put off by the high rpms, but if the engine is designed to run at those speeds I am not sure that is really a problem. I'd like to get some more information on this. The Rotax 912 has been in production since around 1992 and the 912ULS since 1999. Should be information somewhere. I've heard that thousands of them have been sold for drones and unmanned aircraft of various types. My one comment on the gearbox is it has a harmonic resonance vibration at about 1800-1900 rpm (taxi speeds) which is very noticeable. I try to avoid that, and bump it up to about 2000, and it's nice and smooth there. Yup. That's why there's a yellow band on the tach. I try to never run my engine there. |
Jim Stewart wrote in
: Phil wrote: On Nov 29, 3:47 pm, (Paul Tomblin) wrote: In a previous article, said: A quick Google search yielded this info on the engine used in the Remos: http://www.rotaxservice.com/rotax_en...ax_912ULSs.htm Ok, I'm a little embarassed that I couldn't find that info myself. Is a reduction gearbox seen as a reliability problem, or isn't that such a big deal any more? -- Paul Tomblin http://blog.xcski.com/ "Oh my G'Quan, they killed Koshi!" - Citizen G'kyle, Babylon Park I don't think anyone really knows the reliability of this engine and gearbox. It hasn't been in service long enough. I have been training behind one in a Flight Design CT, and it is not a noisy engine at all. When I watch a CT take off I am really struck by how quiet the airplane is. Also the engine has altitude-compensating carbs, so there is no mixture to mess with. In flight the engine is very responsive and smooth. I know a lot of people are put off by the high rpms, but if the engine is designed to run at those speeds I am not sure that is really a problem. I'd like to get some more information on this. The Rotax 912 has been in production since around 1992 and the 912ULS since 1999. Should be information somewhere. I've heard that thousands of them have been sold for drones and unmanned aircraft of various types. There's been quite a lot of them on certified airplanes in Europe as well as thousands on homebuilts round the world for quite some time. It's pretty easy to check how well they work in the real world. Look for airplanes for sale with the engine installed. If most of the airplanes with around 1,000 hours on them have engines with about 500 hours on them, well, you have your answer. But afaik, they work well and last a long time. Bertie |
For Morgans ...Rotax (x 2) | Montblack | Home Built | 12 | April 28th 06 07:19 AM |
Rotax vs. Jabiru | Cal Vanize | Home Built | 30 | January 23rd 06 08:15 PM |
80 hp Rotax Falke as Tug | [email protected] | Soaring | 4 | December 28th 05 10:08 AM |
Rotax 912 Preheaters | Willard | Home Built | 2 | November 13th 05 12:02 AM |
Ellison TBI and ROTAX 582 | Bill Elliott | Aerobatics | 0 | December 22nd 03 05:58 PM |
