On Nov 29, 3:31 pm, "Maxwell" wrote:
I haven't flown one, so I can't be certain, but I'm guessing it would at least seriously hamper the engines ability to windmill during a temporary fuel starvation, or carb ice situation. If a Lyc or Continental dies due to carb ice, it isn't going to restart either. It needs air and fuel to generate heat to get the ice out, and a pilot who lets things deteriorate until the thing is dead is faced with a forced landing whether it's a direct-drive engine or a geared engine. Continental has built geared engines: The GO-300, GO-480, the Tiara (not too successful), and there are many geared radials. Most have some RPM range where they're not comfortable, and some direct- drive setups have the same due to prop resonance. The Cherokee 180 was one of them. There's a yellow arc on the tach: pass through it, don't linger there. All will be well. Geared engines are more efficient in terms of weight/HP ratio. HP is a function of torque times RPM, so raising RPM gets more jam for a small weight increase in the form of a reduction of some sort. Gears, V-belts, timing belts, chains; they've all been employed. In some engines it improves safety by taking the thrust and gyroscopic forces off the crankshaft and putting them onto something more suitable. If it hadn't been for geared engines we wouldn't have had the P-51, P-40, Spitfire, P-38, Lancaster, and many more. On the other hand, the other side wouldn't have been such a threat. Dan |
Matt Whiting schrieb:
Why do you want it to windmill? there is no vacuum system. Quicker restart. In the only situation that I can think of in which a quick engine restart may matter, you really wouldn't want to dive for windmill. Besides, using the starter yields the desired result at least as quickly. |
On Nov 30, 9:34 am, Thomas Borchert
wrote: Phil, I don't think anyone really knows the reliability of this engine and gearbox. It hasn't been in service long enough. Are you kidding? These have been in service in huge numbers for well over a decade. The original Diamond Katana was introduced with them. These engines are VERY proven. It may have happened outside the US (and thus outside the advertising range of "Flying" and thus outside their editorial coverage), but trust me, it still happened. -- Thomas Borchert (EDDH) I thought the 912 was fairly new. I can't find a history of the engine. Anybody know when they first came out? Phil |
Thomas Borchert wrote:
Paul, Does it really run at 4300rpm? Yes (no offense, but in what hole have you been hiding all those years? ;-)) It is geared down. It is a very, very quiet engine, much quieter than any Lycosaurus or TCM. Thanks to water cooling which also ends the shock cooling debate. Welcome to 1990s technology. Really? http://www.zenoswarbirdvideos.com/P-51_Variants.html Seems like water cooling has been around just a little longer than that. Matt |
#28
![]() "Stefan" wrote in message ... Matt Whiting schrieb: Why do you want it to windmill? there is no vacuum system. Quicker restart. In the only situation that I can think of in which a quick engine restart may matter, you really wouldn't want to dive for windmill. Besides, using the starter yields the desired result at least as quickly. You don't need to dive on a direct drive, the engine continues to windmill from the time it stalls. In Cessna's you have to slow to very near stall speed to actually stop the prop. I would suspect the same for all the Lycoming and Continental powered aircraft. |
#29
![]() wrote in message ... If a Lyc or Continental dies due to carb ice, it isn't going to restart either. It needs air and fuel to generate heat to get the ice out, and a pilot who lets things deteriorate until the thing is dead is faced with a forced landing whether it's a direct-drive engine or a geared engine. Not true, been there and done it. |
#30
![]() "Maxwell" wrote in message ... I'm guessing it would at least seriously hamper the engines ability to windmill during a temporary fuel starvation, or carb ice situation. A windmilling propeller significantly increases your sink rate when your engine stops making noise. Do you really want that? ...or would you rather have more time to sort things out, and/or more landing options within gliding range? I know my choice! Vaughn |
For Morgans ...Rotax (x 2) | Montblack | Home Built | 12 | April 28th 06 07:19 AM |
Rotax vs. Jabiru | Cal Vanize | Home Built | 30 | January 23rd 06 08:15 PM |
80 hp Rotax Falke as Tug | [email protected] | Soaring | 4 | December 28th 05 10:08 AM |
Rotax 912 Preheaters | Willard | Home Built | 2 | November 13th 05 12:02 AM |
Ellison TBI and ROTAX 582 | Bill Elliott | Aerobatics | 0 | December 22nd 03 05:58 PM |
