Las Vegas NV Cortez 1 VFR Arrival/Class B Airspace
Old December 21st 07, 06:43 PM posted to rec.aviation.piloting
Ron Lee[_2_]
Default Las Vegas NV Cortez 1 VFR Arrival/Class B Airspace
Does being cleared for this arrival automatically give you clearance
to enter Class B airspace or do you need to hear "Cleared to enter
Class B airspace" as well.
Ron Lee
Old December 21st 07, 07:25 PM posted to rec.aviation.piloting
Since the Cortez arrival requires you to go through class B, and
clearance is required before you start the arrival, no.
However, one wonders why go to North Las Vegas when Henderson is
much easier to get in and out of, much friendlier to GA, and is
cheaper.
Though if you do use Henderson, use their free shuttle back to the
airport, not a cab; few of the cab drivers know how to get there
and take you on a scenic and expensive tour of the Henderson area.
Jim Pennino
Remove .spam.sux to reply.
Old December 21st 07, 10:35 PM posted to rec.aviation.piloting
Dane Spearing
cheaper.
?!? The fuel prices at HND and VGT are usually very close to one
another (less than $0.05/gal difference). At this moment, according
to airnav, both of them have a self-serve price of $4.09. The nightly
tie-down fees are also the same ($6.50/night, IIRC).
I've flown in to both HND and VGT many times, and find the prices and
service levels to be comparable, if not nearly identical. Both airports
also have free shuttles that will take you to your destination.
As for dealing with the Class B airspace while flying into VGT, I've never
ever had any problems getting a clearance from approach. In my experiences,
the Las Vegas Approach controllers are some of the best I've ever dealt
with. They are very used to simultaneously dealing with both the big boys
and the propeller-heads, and always seem to be very accomodating to those
unfamiliar with the local airspace. Don't let having to deal with Class B
airspace be a deciding factor in choosing your destination in this case.
In the end, my decision to land at VGT vs HND revolves around which airport
is closer to my final destination in Las Vegas. VGT is a bit closer to the
strip.
-- Dane
Old December 21st 07, 10:40 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Ron Lee" wrote in message
"The operator must receive an ATC clearance from the ATC facility having
jurisdiction for that area before operating an aircraft in that area."
I'm not familiar with that arrival, but you don't have to hear "Cleared to
enter Class B airspace" if you're operating under another clearance that
meets the requirement above.
Old December 21st 07, 11:45 PM posted to rec.aviation.piloting
cheaper.
strip.
When's the last time you flew into HND?
They are continually improving their service.
In September HND was $5/night for singles and the premium on full service
gas was $.05 AIR.
I will continue to use HND because of the fantastic service that treats
you great whether you're in a Gulfstream or a 2-hole experimental.
Jim Pennino
Old December 22nd 07, 12:43 AM posted to rec.aviation.piloting
Larry Dighera
On Fri, 21 Dec 2007 22:35:38 +0000 (UTC),
(Dane Spearing) wrote in :
KLAS is closer than either of those.
Old December 22nd 07, 12:46 AM posted to rec.aviation.piloting
BT
A Clearance from ATC is required to fly the Cortez 1 Arrival should include
the words.. "cleared to enter Class B", if not.. ask
Most likely the phraseology will be, "N123VG, Cleared to enter Class B via
the Cortez 1 arrival to North Las Vegas Airport. Maintain VFR."
Most likely you will be restricted by ATC to maintain 3500MSL until in
contact with VGT Tower dependent on their traffic pattern operations. They
run parallel traffic patterns to 12L/30R and 12R/30L on split tower
frequencies. Pattern altitude is 3000MSL.
The Cortez Arrival is the old "Showboat" arrival, until it was imploded. It
was easy to see the Showboat.. it is harder to spot the El Cortez.
BT
VGT based
Ron Lee
Old December 22nd 07, 01:45 AM posted to rec.aviation.piloting
BT
"Larry Dighera" wrote in message
airport
You may not want to pay the fee at KLAS.
B
Old December 22nd 07, 03:27 AM posted to rec.aviation.piloting
Larry Dighera
On Fri, 21 Dec 2007 17:45:50 -0800, "BT" wrote
in :
airport
B
Not a problem at the Executive terminal; just top off the tanks. Fee
Waived. First class service; free shuttle van to and from.
Class B airspace notation BillJ Piloting 59 December 27th 07 12:48 AM
Transponders Above Class C Airspace Jim Vincent Soaring 20 May 15th 07 04:36 PM
Class F Airspace in Germany Guy Corbett Soaring 4 May 9th 07 09:25 AM
Class A airspace flying_monkey Soaring 66 October 22nd 06 03:38 PM
Tower with only Class G Airspace Jeff Saylor Piloting 8 May 10th 04 09:53 PM
