engine pre-oiler
Old December 23rd 07, 08:13 PM posted to rec.aviation.homebuilt
Stuart & Kathryn Fields
Default engine pre-oiler
I'm thinking about using an electric diesel fuel pump to pressurize my 0320
with engine oil to pre-lube before starting. Have any of you tried that?
The accumulator method is heavier than I want to use.
Old December 24th 07, 02:50 AM posted to rec.aviation.homebuilt
jerry wass
Get a used fuel pump from an older VW CFI (constant fuel injection) auto
--they put up 70 psi constantly---ought to last a long time pumpin oil--
just draw up high enough to not get any of the settlin's outa the sump.--
the older ones were frame mounted just ahead of the gas tank in a big
rubber jacket--about 4"x4"x8"---or you could just put quick disconnect
fittings on the plane & leave the pump in the hangar. (that's what I did
with my 855 Cummins.
Old December 24th 07, 04:06 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
What's it going to weigh, Stuart?
Old December 24th 07, 10:09 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Mon, 24 Dec 2007 02:50:23 GMT, Jerry Wass
what aeroplane did you have powered by an 855 Cummins?
it must have handled like a truck.
just curious.
Stealth Pilot
Old December 24th 07, 12:17 PM posted to rec.aviation.homebuilt
oilsardine[_2_]
Why not manually operated? Thought about the pump of my hydraulic jack (2
tons). The pump is very small.
"cavelamb himself" schrieb im Newsbeitrag
0320 with engine oil to pre-lube before starting. Have any of you tried
that? The accumulator method is heavier than I want to use.
Old December 24th 07, 07:22 PM posted to rec.aviation.homebuilt
stol
with engine oil to pre-lube before starting. *Have any of you tried that?
The Accusump accumulator set up is very simple and can't weigh that
much. Used them is alot of racecars and they are bulletproof.
Ben
www.haaspowerair.com
Old December 24th 07, 08:25 PM posted to rec.aviation.homebuilt
Ben
Oh no - the dreaded, "it can't weigh that much" syndrome!
Old December 25th 07, 04:52 AM posted to rec.aviation.homebuilt
stol
Ben
Yup.... afraid so.. :)
Old December 26th 07, 02:36 AM posted to rec.aviation.homebuilt
jerry wass
Ben
Like I said--one each male & female quick disconnect fitting doesn't
weigh as much as anything else that's been talked about so far---Then
you can use any kind of pump that satisfies your expectation, even a
quart reservoir with an electric heater in it--if need be. 'cause all
this stuff stays in the hangar anyhow. When you're through, plug the
disconnected hoses together & everything is all sealed up ,ready for the
next time. Jerry
Old December 27th 07, 05:37 PM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe
"Stuart & Kathryn Fields" wrote in message
I'm thinking (never a good thing, eh?) that your objective is to prolong the
life of the engine?
Rather than a pre-oiler, what about grabbing the smog pump off that '78
Chevy you have up on blocks and putting it on your engine with the pump
outlet plumbed into the crankcase some distance away from the existing
breather? (Inlet goes to the clean air side of the air cleaner Note: IIRC
some air pumps have an inlet you can attach a hose to, some don't.)
Keeping the crankcase clean and dry would likely do more good than
pre-oiling...
Geoff
Engine-out procedures and eccentric forces on engine pylons Mxsmanic Piloting 18 May 26th 07 01:03 AM
Saturn V F-1 Engine Testing at F-1 Engine Test Stand 6866986.jpg [email protected] Aviation Photos 1 April 11th 07 04:48 PM
F-1 Engine for the Saturn V S-IC (first) stage depicts the complexity of the engine 6413912.jpg [email protected] Aviation Photos 0 April 9th 07 01:38 PM
Preheat / Pre-Oiler Fastglasair Home Built 6 November 13th 04 05:40 AM
Preheat / Pre-Oiler Fastglasair Owning 1 November 11th 04 05:11 PM
