Preheat / Pre-Oiler
Old November 11th 04, 07:24 AM
Fastglasair
Default Preheat / Pre-Oiler
So is this the type that is externally mounted, and driven by a belt?
Not sure what you mean by this. Mine is a cylinder shape with a shuttle inside.
It is charged with nitrogen. When the engine is running the oil is forced (3
quarts) into the accumulator until equilibrium is reached. Before shutting down
the engine a manual valve is closed. It could also be done remotely using an
electric normally closed solenoid valve. I typically have a 70+ psi charge of
oil to use when starting my engine. I can also easily remove the accumulator, I
have it mounted on my seat back. When really cold I can remove it, I have used
hydraulic quick disconnects which do not leak. I can take it to my hotel room
and keep it warm by a heater. My mounts are also useful for an Oxygen tank as
well for high altitude flights
Old November 11th 04, 05:11 PM
Jay Honeck
inside.
(3
down
an
charge of
accumulator, I
used
room
as
THAT is too cool.
And, sadly, it would NEVER be approved for flight in a certificated
aircraft...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Preheat / Pre-Oiler Fastglasair Home Built 6 November 13th 04 05:40 AM
Preheat PaulaJay1 Owning 22 November 13th 04 03:51 AM
Preheat PaulaJay1 Owning 0 November 10th 04 11:40 PM
BRAC - The Preheat Mode Yofuri Naval Aviation 17 May 24th 04 12:47 PM
PIREP - Reiff Preheat Systems Joe Young Owning 19 December 14th 03 06:38 PM
