#31
Blueskies wrote:
"Richard Riley" wrote in message ... On Fri, 28 Dec 2007 19:46:57 -0800 (PST), " wrote: On Dec 28, 2:57 pm, wright1902glider wrote: the author seems to think that 4130 cro-mo steel can't be welded with an oxy- acetylene torch. -------------------------------------------------------------------------------- Pure bull****. Indeed, for the stresses encountered in bicycles (which is what he's talking about) there are any number of BRAZING compounds that yield joints stronger than than normalized 4130. O/A does just fine airframes... and for bike frames. If brazing gives stronger joints that normalized 4130, why aren't we brazing airframes? (I'm not saying it's an incorrect statement - I know better than to disagree with VD on something like this. I just figure there must be a reason, like the brazing compounds are more expensive.) Won't withstand high temperatures? Structural brazing works just fine - if done correctly. But too much heat causes the brass to migrate into the grain of the 4130 - resulting in cracks. It HAS to be done right. And there is no way to tell afterwards if it was or not - until it breaks. Richard |
#32
#33
Pure bull****. *
Yep. That's what I was thinking. Funny how many OA welded steel aircraft are still flying. I've been up in a few. My only real question is wether they were built of 4130 in 1942, or something more mild. Wasn't Mike Horowitz using 4130 and an HF torch on his Dyke delta? In any case, I thought that website was really quite humorous. Its amazing how much wiz-dum there was on a site dedicated to building... a bicycle. Well, bicycle-thingie. Convention be damned when I get my OA cylinders (and if the snow ever melts)! I'll weld it, test it to distruction, beat the hell out of it, run over it with my truck, pump it full of air, and if it still looks good, seek the comments and experiences of you folks. And then I'll probably beat on it some more and report my results. Boulder, CO is getting boring. The Kenetic sculpture race was cancelled this year. Time for me to take up the torch (ha) and reintroduce a little whackiness... oh yea, and practice my welding for that homebuilt project. Happy New Year Everyone, Harry "90% mad scientist" Frey |
#34
"cavelamb himself" wrote in message ... Structural brazing works just fine - if done correctly. But too much heat causes the brass to migrate into the grain of the 4130 - resulting in cracks. It HAS to be done right. And there is no way to tell afterwards if it was or not - until it breaks. Richard I meant while the part was in service. If an engine mount was brazed, and there was an engine fire, would the braze joint fail (come apart) where a welded one would hold? |
#35
On Jan 2, 9:58 am, wright1902glider wrote:
I thought that website was really quite humorous. Its amazing how much wiz-dum there was on a site dedicated to building... a bicycle. Well, bicycle-thingie. --------------------------------------------------------------------- The website's attitude is fairly common among folks who have just discovered the practicality of human-power as a mode of transportation. Even Henry Ford considered the use of automobiles for 'personal transportation' as a deeply flawed philosophy, pointing out that no society could afford it (circa 1885) which was why his initial interest was in using internal combustion to power farm machinery rather than cars. Bikes are an interesting engineering challenge, especially in the area of strength-to-weight. The market for light-weight, efficient chain- driven 'safety' bicycles provided the financing -- and the intellect -- for the materials developed for the one to be applied to aviation, as proven by a couple of brothers from Dayton, Ohio. But most modern- day re-discoverers of pedal power fail to do their home-work, inflicting those who have with a constant stream of absurdities. Anyone who has never built a bike probably should. At the very least it will add years to your life :-) -R.S.Hoover |
#36
On Jan 2, 9:20 am, Charles Vincent wrote:
wrote: Didn't say it wasn't heat-treatable. Said it wasn't hardenable. Hardness is usually linked to crack tendencies. Tensile strength can be changed with heat-treat, I know, but cracking on aircraft tube structures, as I understand it, is more due to the cooling and shrinking of the local area and consequent rise of tension in that area. Dan 4130 is indeed hardenable by heat treatment or cold working. And 4135 even more so. I have hardened them both using both water and oil quenches, though if you took the time to read one of the metallurgical tomes on the subject, you would find they are spec'd as an oil hardening alloy. Water has worked fine for me on small sections, though my default quench (i.e. the bucket next to the forge) is water with a layer of olive oil floating on the top. I used to use used ATF or motor oil as it was cheap, but burning olive oil is more friendly. Charles OK. Must be that the chrome or molybdenum adds to the hardenability. All my resources say that .4% carbon is necessary to harden steels. Dan |
#37
If you have any doubt as to the hardenability of any piece of steel , just
light up your TIG Torch and get it close enough to your steel specimen and melt a small fly speck spot , turn off the welder and touch that spot with a file , even on low carbon steel like 1018 you may find that the file will give up just about as easy as the hardened 1018 will , hardness and loss of ductility pretty much parallel each other , I have seen 4130 parts that couldn't be filed or cut with a hacksaw , not good . Best Phil wrote in message ... On Jan 2, 9:20 am, Charles Vincent wrote: wrote: Didn't say it wasn't heat-treatable. Said it wasn't hardenable. Hardness is usually linked to crack tendencies. Tensile strength can be changed with heat-treat, I know, but cracking on aircraft tube structures, as I understand it, is more due to the cooling and shrinking of the local area and consequent rise of tension in that area. Dan 4130 is indeed hardenable by heat treatment or cold working. And 4135 even more so. I have hardened them both using both water and oil quenches, though if you took the time to read one of the metallurgical tomes on the subject, you would find they are spec'd as an oil hardening alloy. Water has worked fine for me on small sections, though my default quench (i.e. the bucket next to the forge) is water with a layer of olive oil floating on the top. I used to use used ATF or motor oil as it was cheap, but burning olive oil is more friendly. Charles OK. Must be that the chrome or molybdenum adds to the hardenability. All my resources say that .4% carbon is necessary to harden steels. Dan |
#38
wrote in message ... On Dec 28, 2:57 pm, wright1902glider wrote: the author seems to think that 4130 cro-mo steel can't be welded with an oxy- acetylene torch. -------------------------------------------------------------------------------- Pure bull****. Indeed, for the stresses encountered in bicycles (which is what he's talking about) there are any number of BRAZING compounds that yield joints stronger than than normalized 4130. O/A does just fine airframes... and for bike frames. I'm not sure where this all fits in, but most lightweight bicycle frames have a reinforcing "lug" around the tubes at the joints. Are you talking bicycles or motorcycles? -- Jim in NC |
#39
"Charles Vincent" wrote 4130 is indeed hardenable by heat treatment or cold working. And 4135 even more so. I have hardened them both using both water and oil quenches, though if you took the time to read one of the metallurgical tomes on the subject, you would find they are spec'd as an oil hardening alloy. Water has worked fine for me on small sections, though my default quench (i.e. the bucket next to the forge) is water with a layer of olive oil floating on the top. I used to use used ATF or motor oil as it was cheap, but burning olive oil is more friendly. After you harden it by quenching, do you then go though the normalizing, by heating to "straw" color, and over a period of several minutes, remove the heat, a distance at a time? That was what I was taught eons ago, but only in reference to working mild "God only knows" what type of steel. I'm talking in cars and trailers and tractors and such. I hear people talking about heating up the weld and tube to "cherry" and that is not what I thought was the proper procedure, for normalizing. I was taught that "straw" was attainable, by barely seeing any color in a semi-dark area. Can anyone straighten out my conceptions, and mis-conceptions, here? g -- Jim in NC |
#40
Blueskies wrote:
"cavelamb himself" wrote in message ... Structural brazing works just fine - if done correctly. But too much heat causes the brass to migrate into the grain of the 4130 - resulting in cracks. It HAS to be done right. And there is no way to tell afterwards if it was or not - until it breaks. Richard I meant while the part was in service. If an engine mount was brazed, and there was an engine fire, would the braze joint fail (come apart) where a welded one would hold? Dunno, Mongo. I guess it would depend on how hot for how long. But remember that it takes an acetylene flame to braze in the first place. If if gets that hot in the engine room, whether the mount welds hold or not is probably going to be a secondary issue... Richard |
| Thread Tools | |
| Display Modes | |
| 4130 sheet | log | Home Built | 4 | September 1st 04 02:42 AM |
| 4130 - bad news... | Richard Lamb | Home Built | 28 | May 17th 04 05:08 PM |
| IS the US out of 4130 Steel? | mallakka | Owning | 0 | April 21st 04 11:48 AM |
| Why 4130 tube? | Leon McAtee | Home Built | 31 | March 28th 04 04:04 PM |
| 4130 frame? | Steve Thomas | Home Built | 23 | August 27th 03 06:50 PM |
