4130 can't be OA welded?
Old December 28th 07, 10:57 PM posted to rec.aviation.homebuilt
wright1902glider
Default 4130 can't be OA welded?
While browsing a bit more of that "good 'ole internet wizdom", I ran
accross this page:
http://www.ihpva.org/com/PracticalIn...materials.html
Its a human-powered vehicle website, but on this page, the author
seems to think that 4130 cro-mo steel can't be welded with an oxy-
acetylene torch. Does this sound right? It was always my belief that
we've been OA welding airplanes out of the stuff for decades. Who is
wrong on this point?
Harry "I'm still stuck in the wood-age" Frey
Old December 28th 07, 11:09 PM posted to rec.aviation.homebuilt
Bill Daniels
"wright1902glider" wrote in message
accross this page:
It's BS
IMHO 4130 is easier to weld with OA than mild steel.
Old December 29th 07, 12:05 AM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe
accross this page:
Last airplane I rode in was Oxyen Acetylene welded 4130...
Geoff
Old December 29th 07, 01:28 AM posted to rec.aviation.homebuilt
Anyolmouse
| accross this page:
For many years that was the only approved method. Then along came TIG
welding.
Anyolmouse
---- Posted via Pronews.com - Premium Corporate Usenet News Provider ----
http://www.pronews.com offers corporate packages that have access to 100,000+ newsgroups
Old December 29th 07, 04:38 AM posted to rec.aviation.homebuilt
welding.
American Champion has been using MIG for years now. Quicker
and easier than TIG. But their tubing tends to be heavier, too, which
makes MIG an easy option.
Dan
Old December 29th 07, 03:09 PM posted to rec.aviation.homebuilt
Anyolmouse
TIG
| welding.
| Dan
I didn't know that it was approved for aircraft.
Anyolmouse
Old December 29th 07, 05:27 PM posted to rec.aviation.homebuilt
TIG
| welding.
| Dan
It's approved by manufacturer's drawings. The manufacturer
will call for welds as per their own welding specs, and those specs
plus the airframe drawings are approved by the FAA. We sometimes find
industrial hardware or other "uncertified" parts on airplanes, and
they're approved by their presence on the drawings. For example,
American Champion uses a cheap industrial clip nut on their cowling
installations that has no locking feature and it's really soft so it
cross-threads easily. And is forever falling off or sliding out of
place. This is fixed using the minor modification provisions of the
applicable country's aircraft maintenance laws, replacing those stupid
things with real aircraft hardware.
Dan
Old December 29th 07, 08:13 PM posted to rec.aviation.homebuilt
Anyolmouse
| wrote in message
came
| TIG
| | welding.
Quicker
which
| | Dan
| Dan
Anyolmouse
Old December 29th 07, 03:46 AM posted to rec.aviation.homebuilt
On Dec 28, 2:57 pm, wright1902glider wrote:
the author
acetylene torch.
Pure bull****. Indeed, for the stresses encountered in bicycles
(which is what he's talking about) there are any number of BRAZING
compounds that yield joints stronger than than normalized 4130.
O/A does just fine airframes... and for bike frames.
Old January 2nd 08, 12:45 PM posted to rec.aviation.homebuilt
Phil
Several years ago a EAA member was building a four place experimental with
4130 as the airframe , the gentleman either couldn't or wouldn't learn to do
GAS welding and he ask the FAA if he could braze the structure together ,
FAA said that as it was under the experimental category and they could not
prevent him from brazing his four place bird together but they would like
him to make some samples to proof test his idea , samples proved his concept
and FAA gave him a green light , I think the filler rod was Eutectic FC16 ,
I did get a couple samples of the filler and made my own samples of 5/8 X
..035 4130 , tubing bent and finally broke after great load was applied , no
failure in the filler , only adjacent to it , the problem with this material
is that it uses a Flux coating and some of it is going to get inside the
tube and the stuff will corrode.
Phil
the author
acetylene torch.
4130 sheet log Home Built 4 September 1st 04 01:42 AM
4130 - bad news... Richard Lamb Home Built 28 May 17th 04 04:08 PM
IS the US out of 4130 Steel? mallakka Owning 0 April 21st 04 10:48 AM
Why 4130 tube? Leon McAtee Home Built 31 March 28th 04 03:04 PM
4130 frame? Steve Thomas Home Built 23 August 27th 03 05:50 PM
