Weight and balance, ballast, trim when flying alone
Old January 16th 08, 01:45 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Default Weight and balance, ballast, trim when flying alone
Mxsmanic wrote in
Robert M. Gary writes:
What a very, very odd question. I don't believe I've ever been asked
such a question by a student before.
Is that why you haven't answered it?
No, it's probably because you're a tit .
Bertie
Old January 16th 08, 02:20 AM posted to rec.aviation.piloting
Mxsmanic
John writes:
How much does it pitch to the side if you don't put offsetting weight into
the passenger seat and how does it compare to the normal variation caused by
fuel burn from a single side at a time?
I never burn fuel from a single side at a time, so I cannot comment on that.
Both the Bonanza and the Baron let you draw fuel from both tanks, and that's
how I leave it set.
If you are heavy and alone in the plane, it has a distinct tendency to bank
towards the heavy side. The Bonanza does this, anyway, so it's harder to
notice, but the Baron will do it, only not as obviously. When I first started
flying these aircraft I noticed odd banking tendencies and it took a while for
it to dawn on me that the aircraft was simply loaded unevenly.
If you do the math I think you will
see that the moment caused by the fuel burn changes is much higher then the
moment caused by the weight of the passengers so close to the centerline.
No doubt, but I don't alternate tanks.
Old January 16th 08, 02:21 AM posted to rec.aviation.piloting
Mxsmanic
WingFlaps writes:
Will wonders never cease, he admits it at last! The answer is that
MSFS simulation is nothing like really flying.
I didn't say it was nothing like really flying, which would be an absurd
exaggeration. I simply said that I don't know how accurately it simulates
weight and balance issues. They aren't difficult to simulate, so I imagine
it's pretty close.
Mxsmanic
I hope not because I still can't land the Cessna 150 in MSFS.
Trust your instruments.
Old January 16th 08, 02:24 AM posted to rec.aviation.piloting
Mxsmanic wrote in
John writes:
into the passenger seat and how does it compare to the normal
variation caused by fuel burn from a single side at a time?
You never burn anything , fjukkwit.
Bertie
Mxsmanic wrote in
WingFlaps writes:
It isn't anything like flying.
Bertie
  #28
Old January 16th 08, 02:25 AM posted to rec.aviation.piloting
Mxsmanic wrote in
Nope.
Bertie
  #29
Tina
I'm not sure, but would guess the outer edges of fuel tanks on
something like a Mooney centered about 8 feet from the centerline. If
there's a 10 gallon differential in the tanks -- 60 pounds -- that's
480 foot pounds of unbalance. That's about the same as a 300 pounder
sitting 1.5 feet from the centerline. We tend to burn an hour's worth
out of the takeoff wing (10 gallons easy) before switching, and the
airplane does not fly especially wing heavy.
Bertie, MX may not be overqualified as ballast. If, for example, I was
PIC (about 130 pounds) with a center of gravity (watch it now, if you
comment on the location of my center of gravity) 18 inches to the left
of centerline, a 260 pound ballast sitting in the back 9 inches to
the right of center would bring things into left and right balance.
There should be enough trim for fore and aft balance. You might assume
I would not invite ballast to sit in front.
On Jan 15, 1:03 pm, Bertie the Bunyip wrote:
Mxsmanic wrote :
What is your method for handling weight and balance when you are
piloting a small aircraft alone?
Do you just trim to adjust for the
lateral imbalance, or do you put something on the other side of the
plane (ballast, luggage, etc.) to balance it out, or what?
Why, you thinking of becoming ballast?
you're overqualified.
Bertie
  #30
Old January 16th 08, 02:35 AM posted to rec.aviation.piloting
Tina wrote in
OK, he's perfect. I can't imagine any box of lead doing a better job.
Wel, you put ballast where it does the most good!
In anthony's case that would be in the Dumpster behind the airport cafe.
BTW, on big ones, there is a L/R loading issue, but it's only for floor
strength issues. It's only on widebody AC, though.
Bertie
L23 weight and balance Tony Verhulst Soaring 5 December 31st 05 01:54 AM
Weight & Balance DVD jon Home Built 0 October 8th 05 05:39 PM
Weight and Balance Dale Larsen Home Built 2 June 23rd 04 05:11 PM
Weight and Balance JP Piloting 2 January 13th 04 10:54 AM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 02:57 AM
