Weight and balance, ballast, trim when flying alone
Old January 17th 08, 11:09 AM posted to rec.aviation.piloting
Andy Hawkins
Default Weight and balance, ballast, trim when flying alone
Hi,
It's extremely difficult to walk without spending anything.
Another one to add to the list that includes 'Flying has nothing to do with
being in the air' perhaps?
Andy
  #102
Old January 17th 08, 11:11 AM posted to rec.aviation.piloting
Thomas Borchert
Bertie,
Why aren't you dsigning airplanes
It would involve work.
Thomas Borchert (EDDH)
  #103
Old January 17th 08, 12:05 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Tue, 15 Jan 2008 18:53:57 +0100, Mxsmanic
What is your method for handling weight and balance when you are piloting a
small aircraft alone? Do you just trim to adjust for the lateral imbalance,
or do you put something on the other side of the plane (ballast, luggage,
etc.) to balance it out, or what?
hey stupid.
I'll give you a serious answer to your question.
the reason why no real pilot of a real aircraft has ever to worry
about this contrived situation in real life is an aerodynamic trick
called dihedral. it automatically compensates.
ok stupid. down to the local library. borrow all the books you can on
aircraft, aerodynamics and mechanical engineering. read them!
with years of superhuman effort you might just pass as intelligent.
Stealth Pilot
  #104
Old January 17th 08, 02:07 PM posted to rec.aviation.piloting
Gig 601XL Builder[_2_]
Mxsmanic wrote:
Gig 601XL Builder writes:
Where would you place a fuel pump in a low wing plane with a tank in
each wing that would not suck air from the empty tank?
In a common sump that is lower than either tank.
sorry, won't work
  #105
Old January 17th 08, 02:46 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Thomas Borchert wrote in
Bertie,
Silly me!
Bertie
  #106
Old January 17th 08, 02:47 PM posted to rec.aviation.piloting
Andy Hawkins wrote in
Hi,
with being in the air' perhaps?
This is all gold. we should start a special archive.
Bertie
  #107
Old January 17th 08, 02:48 PM posted to rec.aviation.piloting
Gig 601XL Builder wrote in news:13ouoa9j6fss5a5
@news.supernews.com:
sorry, won't work
Well, to be fair, it would work, but it would be pointless, complicated,
more dangerous, heavier and less reliable.
Just like Anthony!
Bertie
  #108
Old January 17th 08, 03:24 PM posted to rec.aviation.piloting
sorry, won't work
Just like Anthony!
Bertie
Unless the pump is also a gasolator it runs the chance of pumping as
much water as it does fuel.
  #109
Old January 18th 08, 12:41 AM posted to rec.aviation.piloting
Judah
Mxsmanic wrote in
writes:
Walking is still free. It's the stopping for a latte that's costing
you.
One sure method is to walk without any money in your pocket.
  #110
Old January 18th 08, 12:48 AM posted to rec.aviation.piloting
Judah
Mxsmanic wrote in
I've seen pictures of selectors with a "both" position, although
apparently they don't come that way from the factory. Odd that such a
position isn't standard.
It's odd to non-pilots.
Even pilots who fly planes with a "Both" position understand why some planes
don't have one.
L23 weight and balance Tony Verhulst Soaring 5 December 31st 05 01:54 AM
Weight & Balance DVD jon Home Built 0 October 8th 05 05:39 PM
Weight and Balance Dale Larsen Home Built 2 June 23rd 04 05:11 PM
Weight and Balance JP Piloting 2 January 13th 04 10:54 AM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 02:57 AM
