Weight and balance, ballast, trim when flying alone
Old January 18th 08, 01:04 AM posted to rec.aviation.piloting
Default Weight and balance, ballast, trim when flying alone
On Jan 15, 9:20 pm, Mxsmanic wrote:
John writes:
How much does it pitch to the side if you don't put offsetting weight into
the passenger seat and how does it compare to the normal variation caused by
fuel burn from a single side at a time?
I never burn fuel from a single side at a time, so I cannot comment on that.
Both the Bonanza and the Baron let you draw fuel from both tanks, and that's
how I leave it set.
No, they don't.
If you are heavy and alone in the plane, it has a distinct tendency to bank
towards the heavy side. The Bonanza does this, anyway, so it's harder to
notice, but the Baron will do it, only not as obviously. When I first started
flying these aircraft I noticed odd banking tendencies and it took a while for
it to dawn on me that the aircraft was simply loaded unevenly.
Neither Bonanza (35 or A36) exhibits banking tendency with me solo in
the airplane (I weigh 195). How many tons is this pilot?
Dan
  #112
Old January 18th 08, 02:50 AM posted to rec.aviation.piloting
Judah
Jim Stewart wrote in
Or sex with a real mate instead of your hand...
Are you Australian?
  #113
Old January 18th 08, 02:54 AM posted to rec.aviation.piloting
Judah
Bertie the Bunyip wrote in news:Xns9A272A818BAC****upropeeh@
207.14.116.130:
Lead's better. It doesn't argue.
Sheesh! I hope sinc eAnthony is my chew toy he's not toxic!
It's OK - he's in France, not China.
  #114
Old January 18th 08, 02:57 AM posted to rec.aviation.piloting
Judah
Bertie the Bunyip wrote in news:Xns9A27DEC24AFBD****upropeeh@
207.14.116.130:
Bob Moore wrote in
46.128:
Bob Moore wrote
I have lots of time in YAK-52s, no tank selector at all, just
a fuel ON/OFF switch. Works very well.
Must have some system to get around the problem. It has wing tanks?
Or dos it feed to the engine out of a header tank which is in turn fed
by the wing tanks?
Yes, two wing tanks and a header tank in the engine compartment.
And how does it shift fuel to the header? Elec pumps?
Bertie
S-Turns?
  #115
Old January 18th 08, 03:00 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Judah wrote in news:Xns9A28D910727F5Judahnospamnet@
209.197.15.254:
207.14.116.130:
Whew, he probably just tastes of snails then.
Bertie
  #116
Judah wrote in news:Xns9A28D948D763EJudahnospamnet@
209.197.15.254:
207.14.116.130:
Bob Moore wrote in
46.128:
by the wing tanks?
Bertie
S-Turns?
k
Bertie
  #117
Old January 18th 08, 01:10 PM posted to rec.aviation.piloting
JB
On Jan 17, 9:47*am, Bertie the Bunyip wrote:
Andy Hawkins wrote :
Hi,
* * * * * wrote:
It's extremely difficult to walk without spending anything.
Another one to add to the list that includes 'Flying has nothing to do
with being in the air' perhaps?
This is all gold. we should start a special archive.
Bertie
I gave up responding to MX's stupid, argumentative posts long ago but
I continue to lurk...just for daily laughs. But I have to come out of
the shadows to say that you are right...this one is absolutely 100%
pure gold!! Between the single pilot ballast question and the "I
can't leave my mommy's apt and walk because I might spend money", its
all too much to take. Pure gold.
--Jeff
  #118
Old January 18th 08, 02:04 PM posted to rec.aviation.piloting
Mxsmanic
Judah writes:
One sure method is to walk without any money in your pocket.
In many jurisdictions, you can be cited or even arrested for vagrancy if you
have no money on your person.
  #119
Old January 18th 08, 02:05 PM posted to rec.aviation.piloting
Mxsmanic
writes:
No, they don't.
Yes, they do, on my sim, which is what I had in mind (actually the Baron draws
fuel for each engine from its respective tank).
  #120
Old January 18th 08, 02:29 PM posted to rec.aviation.piloting
Gig 601XL Builder[_2_]
Mxsmanic wrote:
writes:
No, they don't.
See there's your problem. This isn't a group about sims.
L23 weight and balance Tony Verhulst Soaring 5 December 31st 05 01:54 AM
Weight & Balance DVD jon Home Built 0 October 8th 05 05:39 PM
Weight and Balance Dale Larsen Home Built 2 June 23rd 04 05:11 PM
Weight and Balance JP Piloting 2 January 13th 04 10:54 AM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 02:57 AM
