How did KPHX Class B get so screwed up?
Old February 1st 08, 08:31 PM posted to rec.aviation.piloting
Larry Dighera
Default How did KPHX Class B get so screwed up?
On Fri, 01 Feb 2008 16:50:12 +0100, Mxsmanic
wrote in :
A Guy Called Tyketto writes:
Idiot. But then again, I wouldn't trust any children to learn
English from you, let alone French.
The answer is on the same site you glorify and probably smoke
choads from. I quote from the Phoenix TAC:
The *VFR TRANSITION ROUTE* over Phoenix Sky Harbor Int'l Airport is
based on Runway in use. 7s/8: use the West route. 25s/26, use the East
route.
A transition route isn't a corridor. A corridor is outside the Class B; a
transition route goes through it. Look at KSAN to see a true VFR corridor.
As long as we're on the subject, let's mention the LAX Special Flight
Rules Area directly over the airport between 3,500' and 4,500':
http://skyvector.com/perl/code?id=KLAX&scale=3 . It is a VFR route
through KLAX Class B surface area that doesn't require ATC
authorization nor communication with ATC!
There's an explanation of how to use it on the lower left hand corner
of the KLAX Terminal Control Area chart.
Old February 2nd 08, 03:12 AM posted to rec.aviation.piloting
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
route.
Wrong. SFRA at LAX is a corridor and *IN THE CLASS B*.
Either get your facts straight, or plan to have a size 15 boot
shoved up your ass every time you open your moouth.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.wizard.com/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.8 (GNU/Linux)
iD8DBQFHo9+AyBkZmuMZ8L8RAnjsAKCENgvaAGBgPskC7ZUh8r 4gYU5oEgCg5IpI
DWaoyhSFTQaQIJUJY4OEYjc=
=qV4d
-----END PGP SIGNATURE-----
Old February 2nd 08, 03:41 AM posted to rec.aviation.piloting
Mxsmanic
The SFRA at LAX is a SFRA, and so it is neither a corridor nor a transition
route.
Old February 2nd 08, 04:01 AM posted to rec.aviation.piloting
Hash: SHA1
route.
Your play on words does you no good, Anthony. It is a corridor,
as it handles both north and southbound traffic, as does the Shoreline
route and Hollywood park mini route.
All of which in the Los Angeles Class B. So for the sake of
everyone here, shut up and stop splitting hairs.
BL.
iD8DBQFHo+smyBkZmuMZ8L8RApJ2AJ9uL918nmnodMdwcSOyPp Q2mSdxawCg/A/2
Fr2o2ty+bMZlBM1sjMBCOp4=
=Gzmd
Old February 2nd 08, 06:30 AM posted to rec.aviation.piloting
Mxsmanic
It is a corridor,
A Special Flight Rules Area is just that: an area where the normal rules don't
apply.
Old February 2nd 08, 07:05 AM posted to rec.aviation.piloting
It is a corridor,
apply.
My god, you are such an idiot.
Jim Pennino
Remove .spam.sux to reply.
Old February 2nd 08, 09:49 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Mxsmanic wrote in
transition route.
Nope
Bertie
Mxsmanic wrote in
It is a corridor,
Shoreline route and Hollywood park mini route.
rules don't apply.
Nope
Bertie
Controller screwed up? Paul Tomblin Piloting 51 September 14th 07 09:59 PM
PSS 747 Depature Route from KPHX Thomas Simulators 0 July 19th 04 11:52 AM
Don't Want to be Screwed [email protected] Home Built 5 May 22nd 04 06:58 AM
Screwed by Helicopter Support Inc. Becky DeWind Owning 3 May 18th 04 01:14 PM
Changes At KPHX Jay Beckman Piloting 5 April 6th 04 03:31 PM
