Mxsmanic wrote:
writes: What does it matter since you don't really fly? I use them in simulation. Clue #2: Real VFR pilots of real airplanes can go through real class B airspace without using VFR corridors. If they are cleared to do so, but they may not be. I hereby grant you simulated clearance into all simulated Class B airspace. |
Mxsmanic wrote:
writes: What does it matter since you don't really fly? I use them in simulation. Clue #2: Real VFR pilots of real airplanes can go through real class B airspace without using VFR corridors. If they are cleared to do so, but they may not be. Then simulate yourself a clearance, twit. Since you don't really fly, it doesn't matter what happens in the real world. -- Jim Pennino Remove .spam.sux to reply. |
On Fri, 01 Feb 2008 16:50:12 +0100, Mxsmanic
wrote in : A Guy Called Tyketto writes: Idiot. But then again, I wouldn't trust any children to learn English from you, let alone French. The answer is on the same site you glorify and probably smoke choads from. I quote from the Phoenix TAC: The *VFR TRANSITION ROUTE* over Phoenix Sky Harbor Int'l Airport is based on Runway in use. 7s/8: use the West route. 25s/26, use the East route. A transition route isn't a corridor. A corridor is outside the Class B; a transition route goes through it. Look at KSAN to see a true VFR corridor. As long as we're on the subject, let's mention the LAX Special Flight Rules Area directly over the airport between 3,500' and 4,500': http://skyvector.com/perl/code?id=KLAX&scale=3 . It is a VFR route through KLAX Class B surface area that doesn't require ATC authorization nor communication with ATC! There's an explanation of how to use it on the lower left hand corner of the KLAX Terminal Control Area chart. |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 Mxsmanic wrote: A Guy Called Tyketto writes: Idiot. But then again, I wouldn't trust any children to learn English from you, let alone French. The answer is on the same site you glorify and probably smoke choads from. I quote from the Phoenix TAC: The *VFR TRANSITION ROUTE* over Phoenix Sky Harbor Int'l Airport is based on Runway in use. 7s/8: use the West route. 25s/26, use the East route. A transition route isn't a corridor. A corridor is outside the Class B; a transition route goes through it. Look at KSAN to see a true VFR corridor. Wrong. SFRA at LAX is a corridor and *IN THE CLASS B*. Either get your facts straight, or plan to have a size 15 boot shoved up your ass every time you open your moouth. BL. - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.8 (GNU/Linux) iD8DBQFHo9+AyBkZmuMZ8L8RAnjsAKCENgvaAGBgPskC7ZUh8r 4gYU5oEgCg5IpI DWaoyhSFTQaQIJUJY4OEYjc= =qV4d -----END PGP SIGNATURE----- |
Wrong. SFRA at LAX is a corridor and *IN THE CLASS B*. The SFRA at LAX is a SFRA, and so it is neither a corridor nor a transition route. |
Hash: SHA1 Mxsmanic wrote: A Guy Called Tyketto writes: Wrong. SFRA at LAX is a corridor and *IN THE CLASS B*. The SFRA at LAX is a SFRA, and so it is neither a corridor nor a transition route. Your play on words does you no good, Anthony. It is a corridor, as it handles both north and southbound traffic, as does the Shoreline route and Hollywood park mini route. All of which in the Los Angeles Class B. So for the sake of everyone here, shut up and stop splitting hairs. BL. - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.8 (GNU/Linux) iD8DBQFHo+smyBkZmuMZ8L8RApJ2AJ9uL918nmnodMdwcSOyPp Q2mSdxawCg/A/2 Fr2o2ty+bMZlBM1sjMBCOp4= =Gzmd -----END PGP SIGNATURE----- |
It is a corridor, as it handles both north and southbound traffic, as does the Shoreline route and Hollywood park mini route. A Special Flight Rules Area is just that: an area where the normal rules don't apply. |
Mxsmanic wrote:
A Guy Called Tyketto writes: It is a corridor, as it handles both north and southbound traffic, as does the Shoreline route and Hollywood park mini route. A Special Flight Rules Area is just that: an area where the normal rules don't apply. My god, you are such an idiot. -- Jim Pennino Remove .spam.sux to reply. |
Mxsmanic wrote in
: A Guy Called Tyketto writes: Wrong. SFRA at LAX is a corridor and *IN THE CLASS B*. The SFRA at LAX is a SFRA, and so it is neither a corridor nor a transition route. Nope Bertie |
Mxsmanic wrote in
: A Guy Called Tyketto writes: It is a corridor, as it handles both north and southbound traffic, as does the Shoreline route and Hollywood park mini route. A Special Flight Rules Area is just that: an area where the normal rules don't apply. Nope Bertie |
Controller screwed up? | Paul Tomblin | Piloting | 51 | September 14th 07 09:59 PM |
PSS 747 Depature Route from KPHX | Thomas | Simulators | 0 | July 19th 04 11:52 AM |
Don't Want to be Screwed | [email protected] | Home Built | 5 | May 22nd 04 06:58 AM |
Screwed by Helicopter Support Inc. | Becky DeWind | Owning | 3 | May 18th 04 01:14 PM |
Changes At KPHX | Jay Beckman | Piloting | 5 | April 6th 04 03:31 PM |
