#31
Larry Dighera wrote:
On Tue, 29 Jan 2008 09:26:13 -0800, NW_Pilot wrote in : most modern headsets can be wired one to one to the radio.. I was under the impression that aviation headset microphones were made to electrically look like a carbon mic, and that most ham communications gear used dynamic mics. Do you have information that refutes this notion? Nope, I know it works great with the LightSpeed and David Clark Mic. Set Mic Gain to 1 on the radio or will sound like crap. |
#32
OK, I am in the testing Faze!!!!
I will tell you I am really upset at Icom at this point!!! I Split the separation cable to find out that all the wires are coated with epoxy even under the shielding like stranded magnet wire.... Ok, 3 hours later i was able to solder an 8 pin connector to one side, About an hour later I gave it a go on the other side it took about 2 hours very very tinny wires. Icom just killed any repeat or future business I had with them. All and all it worked but took way longer then expected but all connection are mounted some finial routing of wires and she should be done. At nearly $50.00 a cable an average hobbyist would not be able to fix the cable if it got cut somehow. The bolts that will hold the aluminum chassis in to the case will also be rubber feet. Sorry no photos tonight.... Will Post when I can need some sleep eyes are not as good as they were few years ago and the tips of my fingers are no longer used to the hi-temps of the soldering iron. Icom BAAAAD BAAAD BAAAD!!! you deserve the Chinese or Koreans to make clones of your cables!!!! maybe now your radios!!! |
#33
Ok, the guy with the bouncing e-mail the model of Astron is N2412-24 I tried
another model that peek's @ 20amps it would not run the 706MKIIG above power level 5. Spend the money and get the model I have listed. There may be others but Astron is a good quality unit. Model N2412-24 Input Voltage 22-32 VDC Output Voltage 13.8 VDC Line/Load Regulation .04 VDC Ripple 20mVrms Continuous Current 20 Amps Peak Current 24 Amps Overvoltage Protection16 VDC Efficiency 88% Dimensions 2" x 6.2" x 7" Weight 2 Lbs Here is the factory Image http://www.astroncorp.com/images/N2412-24gif.gif Astron Site, http://www.astroncorp.com/dcdc.shtml |
#34
On 2008-01-30, NW_Pilot wrote:
I will tell you I am really upset at Icom at this point!!! I Split the separation cable to find out that all the wires are coated with epoxy even under the shielding like stranded magnet wire.... Ok, 3 hours later i was able to solder an 8 pin connector to one side, About an hour later I gave it a go on the other side it took about 2 hours very very tinny wires. Icom just killed any repeat or future business I had with them. All and all it worked but took way longer then expected but all connection are mounted some finial routing of wires and she should be done. Hm. Have you looked at the FT857? Its extension cables use standard, crimped-on modular connections, 4 pins for the control head and 8 for the mike. -- Jay Maynard, K5ZC http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net http://www.hercules-390.org (Yes, that's me!) Buy Hercules stuff at http://www.cafepress.com/hercules-390 |
#35
It's powerup and test were ok, doing finial assembly will take photos tomorrow.
Decided to not wire it for 14V as of now need to work a few issues out with switching. |
#36
Here Are The Completed Photos,
Inside Wired With Pad. I Ended up drilling a number of holes under the side edge lip for Air and under the front I routed it out behind the name plate lots of air. Fan was Wired to Radio Out 12V so when radio is on fan is on fused with a ..5 amp fuse inline. Temperature while in Use is acceptable Levels High Volume Computer Fan http://www.internationalferryflights...T/S4010621.JPG Connector Side Of Unit, http://www.internationalferryflights...T/S4010622.JPG http://www.internationalferryflights...T/S4010623.JPG Left to Right, Ground. 2 Connector Left Of Fan Bottom is Power 3 Pin, 14V, 24V, & Ground (Eliminated Need For Switch And Slaved Ground to System Ground) Top Is Remote Head Mount 8 Pins, Fan Right Of Fan Top Is Antenna, Bottom Is Tuner Locked LED Inside, Antenna, Tools, Cables, And Connectors. (Pill Bottle is For Small Parts) http://www.internationalferryflights...T/S4010624.JPG http://www.internationalferryflights...T/S4010625.JPG Radio Control Head is Mounted In Foam, 1/2" Sides 1" Back 4" Front All items except tool kit are held in with 3M wire wrap like double sided Velcro hot and glued in place.. Inside Full Padding, HF Has Velcro on the Top To Mount Mic. http://www.internationalferryflights...T/S4010627.JPG Complete Unit, http://www.internationalferryflights...T/S4010629.JPG When Closed this unit should withstand shipping as is and airport baggage handlers if checked. Now its simple to hookup, and repack should be a 5 min install on a single engine Cessna!!! The End!!! Yea, Right It's a HAM!!! |
Portable/handheld radio | Danny Deger | Piloting | 15 | February 22nd 07 05:10 PM |
Portable Radio | Waduino | Soaring | 12 | September 14th 05 06:36 PM |
Portable radio scanners | Casey Wilson | Piloting | 1 | August 1st 05 02:05 PM |
Portable XM Radio receiver in the cockpit? | Peter R. | Piloting | 13 | September 4th 04 03:46 AM |
FA OLD AIRCRAFT RADIO TRANSMITTER STANDARD RADIO | Ron | Restoration | 0 | October 26th 03 12:02 AM |
