Portable XM Radio receiver in the cockpit?
Old September 1st 04, 03:39 PM
Peter R.
Default Portable XM Radio receiver in the cockpit?
I have made the jump to satellite radio for my car, choosing XM Radio as
my provider. Wow, am I in love now that I am free of the canned format
of commercial radio!
I was wondering if anyone has taken the portable version of the XM radio
receiver, in my case called the Delphi Roadie or Roadie 2, and used it
in the cockpit?
It seems like it would be pretty straight forward to do, placing the
antenna inside the cockpit forward of the glare shield, then interfacing
the radio to the AUX input of the audio panel. Just wondering about
others' experiences.
Peter
Old September 1st 04, 04:39 PM
Newps
in the cockpit?
Very easy, I did it last October. I have a 182 and the Ski Fi. The
bracket gets attached to the windshield on the copilots side, just
forward of the forward door post. The antenna sits on top of the panel
at the base of the windshield magnet mounted to a little metal strip
attached to the top of the panel. Antenna wire tucked along the side of
the windshield. I use the cigarette lighter plug behind the copilots
yoke for power. The audio out is a simple double ended mini stereo
plug. One end into radio, other end into audio in of intercom. Works
great, never ever a dropped signal thru the plexi. Only problem you may
run into is low audio. If so you can get the Boostaroo from Radio Shack
that goes inline to bring the level up. They came out with a new
version of the Roady and it will broadcast to an FM radio channel. I
will be replacing my Ski Fi with this in the plane and car soon, so we
can have sat radio in the tower too, although the audio in in the plane
will remain the same with a cable.
Old September 1st 04, 05:45 PM
Peter R.
in the cockpit?
Thanks for your experiences.
Only problem you may run into is low audio.
While awaiting for the delivery of the Roadie 2, I took the opportunity
to read through the owner's manual (made available at their web site).
There is a feature of the radio that allows the user to control the
level of the output, so low audio should be a non-issue.
Peter
Old September 1st 04, 06:03 PM
Newps
All the radios allow you to control the output level now. In the plane
I have to set my Ski Fi to the highest level and I still have to turn
the intercom volume up to a setting higher than I would otherwise. This
makes the intercom volume too high for the people speaking in the plane.
When I take the unit and put it in the car I have to lower the output
level because it is overdriving my trucks radio, causing distortion. So
do not dismiss this out of hand because they tell you that you can
adjust the level. You won't know if you have a problem until you
install it. There are extensive threads about this topic on the Cessna
Pilots Assoc website. The two factors involved are your audio panel and
your intercom and how they were set up when they were installed.
Old September 1st 04, 06:09 PM
Peter R.
snip
Oh, OK. Thank you for the follow-up.
Peter
Old September 1st 04, 06:01 PM
Jim Weir
I did it just before Oshkosh. The 182 has a carpet covering the dash, and the
little antenna fits under that carpet just fine, about as far forward as you can
get it without having it stick out the front end of the carpet. Don't forget to
take the magnets out of the base or your compass will follow the antenna quite
nicely.
Somebody said that they had used the cigarette lighter for power. Just remember
that the little bugger needs SIX volts and that the regulator is in the ciggie
lighter plug. Connect the Roadie directly to 12 volts and you have an expensive
lump of silicon in your hand.
I powered it from a version of the GPS adapter panel, put a 6 volt regulator on
the backside of the panel, the GPS antenna connector on the same panel, and it
looks like a factory install.
Coming soon to a Kitplanes column near you.
Peter R.
-I have made the jump to satellite radio for my car, choosing XM Radio as
-my provider.
http://www.rst-engr.com
Old September 1st 04, 06:18 PM
Peter R.
Whoa. Thank you, Jim, for the warning.
As someone who only has the basics of electronic knowledge, I am
confused. The cigarette lighter plug shipped with the Roadie is not
designed to reduce the voltage to the correct six volts?
If not, what parts would I need (the GPS is an IFR-certified panel
mounted model) to power the Roadie in the aircraft? Is there an off-
the-shelf solution?
Peter
Old September 2nd 04, 02:12 AM
Mark Manes
The reason for the loss of audio is that there is a impedance mismatch.
Freemar sells an impdance matcher that will plug into the Roadie and the Aux
audio input in the audio panel (Garmin 340 in my case). I usually set the
Roadie audio output to 2 or 3 and have plenty of XM audio.
http://www.fremarllc.com/accessories/index.html
Aeromedix also sells a 28v to 6v cig plug adapter that will fit the Roadie.
http://www.aeromedix.com/index.php?_...3893f0567f32d9
The one from Radio Shack is cheaper. The Radio Shace catgalogue shows the
adapter to be 12 to 24v input and 6v output. It works just fine. I tried
both.
Mark Manes
N28409
WC5I
"Peter R." wrote in message
remember
ciggie
expensive
regulator on
and it
the-shelf solution?
Peter
Old September 2nd 04, 12:57 PM
john smith
both.
That was my first thought. I was suprised Jim Weir didn't mention it.
Old September 1st 04, 06:53 PM
Newps
Jim Weir wrote:
Don't forget to
nicely.
The compass may or may not. My compass is mounted on the windshield and
is unaffected by the magnet in the antenna. I have to move the antenna
to within a few inches to get the compass to flicker.
(sorta OT) Free Ham Radio Course RST Engineering Home Built 51 January 24th 05 08:05 PM
Portable GPS: receiver and laptop/palm or selft contained unit picopirate Owning 11 May 16th 04 11:37 PM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 10:57 PM
Radio silence, Market Garden and death at Arnhem ArtKramr Military Aviation 4 February 12th 04 12:05 AM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
