Garmin 430 rquestion- does the approach always have to be activated via "activate approach"?
Old February 16th 08, 06:50 PM posted to rec.aviation.ifr
Sam Spade
Default Garmin 430 rquestion- does the approach always have to be activatedvia "activate approach"?
Thomas Borchert wrote:
Terence,
Well suppose I am enroute and approaching the SGD VOR. At this point I
am getting close to my destination and want to setup the KCCR VOR
approach which starts at the CCR IAF. If I load and activate the
approach a megenta line will immediately be drawn from my present
position to CCR. Want I want is the route SGD, CCR ... KCCR.
I see. In that case, what's wrong with loading the procedure and then
waiting with activation until passing SGD.
Also, upon rereading the 430 manual I noticed that activating
vectors-to-final will always get you to the FAF. I could find no mention
of the automatic activation mentioned by someone. However, automatic CDI
switching (to VLOC) will only happen on an activated procedure, it
seems.
VLOC is only for ILS and LOC, not RNAV
Old February 16th 08, 07:20 PM posted to rec.aviation.ifr
Mark Hansen
On 02/16/08 10:46, Thomas Borchert wrote:
Terence,
seems.
... and the localizer frequency must be in the active window -FYI.
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Old February 16th 08, 07:21 PM posted to rec.aviation.ifr
Thomas Borchert
Default Garmin 430 rquestion- does the approach always have to be activated via "activate approach"?
Sam,
I know. However, procedure activation is treated as standard in the
manual, contrary to what you alluded to. There is no mention of
"automatic activation" I could find. Could you kindly point me to it?
Thomas Borchert (EDDH)
Old February 16th 08, 07:23 PM posted to rec.aviation.ifr
Terence Wilson
On Sat, 16 Feb 2008 19:46:19 +0100, Thomas Borchert
Terence,
Not really biggie, but it seems redundant. Why am I activating? What
does it do? I just passed SGD and I'm en route to CCR with a nice
magenta line plotted between the two. Activating the approach will
redraw a magenta line from my current position to CCR.
As I said, I'm confused about what "activate" actually does. Is it
just a shortcut to get me on the approach or does it put the 430 into
some sort of magical approach mode? Or to put it another way, if I
load but don't activate, am I missing something?
One of the annoyances of VTF is that it erases all the waypoints
before the FAF. I'm not that experienced, but when ATC has given me
vectors, it's usually to a fix before the FAF. The bottom line is I
don't use VTF, it's safer to pick an IAF, and then activate the
appropriate leg manually once ATC has issued vectors onto the
published approach.
seems.
I'll have to read about that. I wasn't aware that the unit
automatically switches from VLOC to GPS or vice versa.
Old February 16th 08, 07:24 PM posted to rec.aviation.ifr
Thomas Borchert
Mark,
Yep, but the unit will remind you to put it there 3 (?) miles from the
FAF.
Old February 16th 08, 07:31 PM posted to rec.aviation.ifr
Thomas Borchert
Terence,
Me neither ;-)
It switches from GPS to VLOC only, on the condition that the VLOC
frequency is active, once you are kind of established on the final
approach course. Also, it switches "gradually", so as to not make the
autopilot go berserk.
Old February 16th 08, 08:02 PM posted to rec.aviation.ifr
Sam Spade
Sam,
No, there is no approach activation for ILS or LOC. Approach
activation, as defined for *RNAV* occurs 2 miles from the FAF. When you
select a LOC or ILS, you instead receive an advisory message cautioning
you that RNAV is for monitoring only.
Old February 16th 08, 09:15 PM posted to rec.aviation.ifr
Thomas Borchert
Sam,
When you
Yes, but you can (and should, per the manual) activate them. So the
question remains, what exactly does that do? In my experience, it starts
both sequencing of the waypoints in the procedure and the change in CDI
sensitivity. And from my experience, same goes for an RNAV approach. The
430 just continues to fly the original flightplan if you don't make it fly
the approach - by activating it.
Old February 16th 08, 10:17 PM posted to rec.aviation.ifr
Sam Spade
Sam,
When you
I agree that the manual says to activate a previously loaded approach.
But, it is overkill and unnecessary.
En route to terminal sensitivity occurs when passing within 30 miles of
the airport reference approach, whether or not an approach is loaded.,
*provided* the destination airport is the final waypoing in the flight plan.
Once flying an approach it will activate (approach sensitivity and
approach RAIM) when reasonably on course and passing inbound 2 miles
prior to the FAF.
You can hit the "activate approach" option all day long once on an
approach flight plan and inside the IAF, and nothing will happen until
you reach 2 miles from the FAF. And, the same will happen at 2 miles
from the FAF without ever pressing the "activate approach" option.
Try it in the trainer on any RNAV (GPS) IAP (or overlay IAP).
Old February 16th 08, 10:52 PM posted to rec.aviation.ifr
Terence Wilson
On Sat, 16 Feb 2008 14:17:02 -0800, Sam Spade
prior to the FAF.
Thanks Sam. Your response agrees with my simulator observations and
clears up my confusion.
Video clip of an "interesting" final approach & landing Elmo von Thud Aviation Photos 3 October 7th 07 12:54 AM
Friday 072707 in Oshkosh Pt 1 - the Raptor [06/30] - "F22 Flyby approach close 2.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 29th 07 06:36 AM
Friday 072707 in Oshkosh Pt 1 - the Raptor [05/30] - "F22 Flyby approach close 1.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 29th 07 06:36 AM
Has Anyone Used The "Approach Sport Hub Avionics Wiring Systems"? three-eight-hotel Owning 7 June 1st 06 03:28 PM
"End of an era: USN's Tomcats make their final approach before decommissioning" Mike Naval Aviation 15 April 5th 06 03:45 AM
