#31
![]() Are you familiar with what Derrik Piggott has written about some peoples sensitivity to reduced G forces? It used to be on-line but I can't find a copy anymore. I haven't heard of this study but will suggest a technique recommended by an instructor who was also a downhill skiier -- instead of tensing up and "backing away" from the "fall", lean forward and go with it. As Dudley said, prepare for it in your head. The physical corollary is to lean forward a tiny bit. Try it next time you're on a roller coaster. Dan |
#32
On Feb 16, 2:08 pm, "Private" wrote:
"Ken S. Tucker" wrote in ... As much as I like the "dud" his post is the most completely idiotic thing I had to read. On Feb 16, 12:10 pm, Dudley Henriques wrote: It's interesting to note that although stall recovery should be thought of as something done with a minimum loss of altitude, the emphasis on recovery should always be placed on the regaining of angle of attack as PRIME to recovery. NUTZ. You need airspeed, it's called kinetic energy that is needed to suck off, using the wings (you know, those little things that protude out the side of airplanes). I am one instructor who strongly believes that instructors should consider altering their approach to teaching stall to focus more strongly on recovering angle of attack than recovering in minimum altitude. See KIAS, Dud, you'd last 2 minutes in the RHS of my plane, after that you'd be lickin' pavement, from my shoe on your ass. Stalls entered at low altitude have many times resulted in secondary stall entry or a mushed recovery followed by ground impact by pilots who COULD have lowered the nose and held it down there a bit longer than they did, using the air under them to better advantage and giving themselves the needed time to regain angle of attack and smooth airflow as they attempted a recovery. But because they had been taught that ALTITUDE rather than AOA was the killer, they recovered trying to save altitude, when in reality what was needed was to USE THE AVAILABLE ALTITUDE CORRECTLY....and save the airplane. Toward this goal, I strongly encourage all CFI's to reference AOA in stall recovery. This doesn't mean INSTEAD of altitude, but it does mean that to recover the airplane, you absolutely HAVE to restore AOA, and at low altitude that might very well mean using available altitude to the last foot of air to do that. I have always taught stall recovery both with and without power. The FAA requires power. I want the student to see the difference and at the same time be able to stress that it's the ANGLE OF ATTACK that saves your butt. The strong lesson here is that you USE altitude......you don't try to minimize it at the expense of angle of attack. Dud, you're clueless, you have not a clue about KIAS, spiral dives or g-force recovery's. In short I see NO evidence you have even been in an airplane with your focus on AoA. I can get a good AoA at 10 KIAS or 200 KIAS, what are going to do? Regards Ken Ken, With respect, I think you must have missed my reply in another thread. I am enclosing it here for your convenience and consideration. "Private" wrote in message ... "Ken S. Tucker" wrote in message ... I was out paying taxes, to get some coin for the piggy bank, I shook it 3 times and still didn't hear any rattling, that's simple accounting to tell me when I'm broke, works every time! Ken Some here would suggest that you apply the same strategy to your head before posting. I am somewhat embarrassed to be entering this thread, but I just can't resist swinging at a soft pitch like that. Happy landings, To elaborate, my suggestion was that before posting you should give your head a shake to determine if there is anything inside and to consider whether you really wished to make the fact public. Happy landings, If I were you, I'd ****-off and read. You're swinging at screw-balls... Me and the "dud" ****ed your mush mind. Get a ****in life, crack a book. Best Regards Ken xxxx |
#33
#34
#35
"Private" wrote in :
"Dudley Henriques" wrote in message ... It's interesting to note that although stall recovery should be thought of as something done with a minimum loss of altitude, the emphasis on recovery should always be placed on the regaining of angle of attack as PRIME to recovery. Agreed, I have always thought of myself as flying a wing to which is attached a fuselage rather than the reverse. Xactly right IMO. All you need is a wing to fly, after all. Bertie |
#37
"Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way D0t C0m wrote in message
news:nfWdnZsrSOkXpiranZ2dnUVZ_g2dnZ2d@wideopenwest .com... "Dudley Henriques" wrote in message ... ... You're right. Power on stalls have a natural tendency to make newbies more nervous than power off. The nose attitude is generally higher, it's louder, (this is a factor BTW), the break is cleaner and more sudden, and the recovery can seem hurried to a newbie who is experiencing the recovery under stress. Are you familiar with what Derrik Piggott has written about some peoples sensitivity to reduced G forces? It used to be on-line but I can't find a copy anymore. But his theory is that some people react very poorly to reduced G and will can attempt to "brace" themself to avoid falling which can result in an accident when stalling at a low altitude... I'll have to keep looking - it was an interesting read for me since my youngest just HATES even things like elevators or driving over a bit of a hill (reduced G situations) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. I think that Google found it for me and the spelling of the author's first name is Derek The article is at: http://www.danlj.org/~danlj/Soaring/Clues/SDO.html Peter |
#38
: On Feb 16, 2:08 pm, "Private" wrote: "Ken S. Tucker" wrote in messagenews:1f25eddb-4c7f-4bde-a4fa-3cc5d7844522 @e23g2000prf.googlegro ups.com... As much as I like the "dud" his post is the most completely idiotic thing I had to read. On Feb 16, 12:10 pm, Dudley Henriques wrote: It's interesting to note that although stall recovery should be thought of as something done with a minimum loss of altitude, the emphasis on recovery should always be placed on the regaining of angle of attack as PRIME to recovery. NUTZ. You need airspeed, it's called kinetic energy that is needed to suck off, using the wings (you know, those little things that protude out the side of airplanes). I am one instructor who strongly believes that instructors should consider altering their approach to teaching stall to focus more strongly on recovering angle of attack than recovering in minimum altitude. See KIAS, Dud, you'd last 2 minutes in the RHS of my plane, after that you'd be lickin' pavement, from my shoe on your ass. Stalls entered at low altitude have many times resulted in secondary stall entry or a mushed recovery followed by ground impact by pilots who COULD have lowered the nose and held it down there a bit longer than they did, using the air under them to better advantage and giving themselves the needed time to regain angle of attack and smooth airflow as they attempted a recovery. But because they had been taught that ALTITUDE rather than AOA was the killer, they recovered trying to save altitude, when in reality what was needed was to USE THE AVAILABLE ALTITUDE CORRECTLY....and save the airplane. Toward this goal, I strongly encourage all CFI's to reference AOA in stall recovery. This doesn't mean INSTEAD of altitude, but it does mean that to recover the airplane, you absolutely HAVE to restore AOA, and at low altitude that might very well mean using available altitude to the last foot of air to do that. I have always taught stall recovery both with and without power. The FAA requires power. I want the student to see the difference and at the same time be able to stress that it's the ANGLE OF ATTACK that saves your butt. The strong lesson here is that you USE altitude......you don't try to minimize it at the expense of angle of attack. Dud, you're clueless, you have not a clue about KIAS, spiral dives or g-force recovery's. In short I see NO evidence you have even been in an airplane with your focus on AoA. I can get a good AoA at 10 KIAS or 200 KIAS, what are going to do? Regards Ken Ken, With respect, I think you must have missed my reply in another thread. I am enclosing it here for your convenience and consideration. "Private" wrote in message ... "Ken S. Tucker" wrote in message news:64fb5517-76cc-49df-8db1- m... I was out paying taxes, to get some coin for the piggy bank, I shook it 3 times and still didn't hear any rattling, that's simple accounting to tell me when I'm broke, works every time! Ken Some here would suggest that you apply the same strategy to your head before posting. I am somewhat embarrassed to be entering this thread, but I just can't resist swinging at a soft pitch like that. Happy landings, To elaborate, my suggestion was that before posting you should give your head a shake to determine if there is anything inside and to consider whether you really wished to make the fact public. Happy landings, If I were you, I'd ****-off and read. Some people read 'em. Others write them.. You're swinging at screw-balls... Well, I certainly am. Bertie |
#39
On Feb 17, 11:39*am, "Ken S. Tucker" wrote:
Me and the "dud" ****ed your mush mind. Get a ****in life, crack a book. Cuniform tablets are quite outdated ... Cheers |
#40
On Feb 17, 11:41*am, Bertie the Bunyip wrote:
wrote : On Feb 15, 6:37 pm, Bertie the Bunyip wrote: "Robert M. Gary" wrote in news:ebb74b75-9910-4c50-ae86- : On Feb 15, 3:56 pm, Dudley Henriques wrote: Bertie the Bunyip wrote: Dudley Henriques wrote in : Man there are a lot of posts on this topic. Too much newsgrouping, people need to do more flying ![]() When my airplane is finished! Bertie Watchu building? A Hatz, but it's a Citabria being restored I'm waiting to fly. Are you building alone? How far along is it? Where is it -I'd like to see it if I got the chance. Cheers |
Stall Recovery | Danny Deger | Piloting | 12 | January 30th 07 01:01 AM |
stall strips ??? | Tri-Pacer | Owning | 6 | December 8th 06 06:18 PM |
Bad place to stall | Stubby | Piloting | 23 | June 21st 05 04:10 PM |
Wing Stall | PaulaJay1 | Owning | 18 | December 11th 03 07:46 PM |
Stall resistant 172? | Roger Long | Piloting | 19 | October 18th 03 11:48 PM |
