Hi all,
A recurring theme seems to be that one should should not rely in fuel gauges. I can understand that from a safety point of view (I always dip the tank before start), but I get the feeling that they are considered just plain inaccurate. Why is that, every car I've driven has a fuel gauge that seems accurate. Am I missing something? A connected point is that I was taught that if you start to worry about low fuel you switch to the lowest tank (2 tanks) and note the time. When the engine splutters you know what time/range you have left to find a good landing spot (after switching tanks). But if a gauge can't be trusted is that the best thing to do? Cheers |
WingFlaps wrote:
Why is that, every car I've driven has a fuel gauge that seems accurate. Am I missing something? Ah, grasshopper. But how often do you get to actually look at the fuel in your car's gas tank? How many cars do you think are on the road that have bunk gas gauges (I have one, for example; my friend has another)? Many older aircraft use float-type gauges, and no matter how hard you try, most floats will develop a slow leak and indicate improperly (or worse, get stuck or bent and refuse to indicate at all. Newer electric gauges rely on the fuel to act as a dielectric between two charged plates (like in a capacitor); except that fuel at different temperatures, in different climates, from different sources, or different formulations all have varied dielectric constants, meaning that the gauge could indicate 22 gallons one day and 18 the next; do you want to bet your life that there's four extra gallons in the tank? TheSmokingGnu |
We have a lot of
problems with them in jets too, believe it or not. Bertie Doesn't that mean there's a certain fudge factor in landing weight calculations? Given the lack of apparent crashes due to inadequate flap settings I guess that ya'll pretty much have the innacuracies under control. |
that the gauge could indicate 22 gallons one day and 18 the next; do you want to bet your life that there's four extra gallons in the tank? TheSmokingGnu Ye Olde E6B and zeroing in on real fuel consumption at cruise gleaned from actual flight should save the day (older planes not up to chart performance, usually). IIRC on similar thread(s) the idea was put forth that the regs only require the indicator to indicate properly when full and when empty ... don't know where that would be in the regs (if in fact it is); maybe part 23? |
On Feb 23, 9:49*am, wrote:
IIRC on similar thread(s) the idea was put forth that the regs only require the indicator to indicate properly when full and when empty ... don't know where that would be in the regs (if in fact it is); maybe part 23? That's an unfortunate myth. (The usual form of the myth is to say that the gauges only have to be correct when the tanks are empty.) Pilots who belive it are likely to underestimate the importance of the fuel- gauge airworthiness requirement. The myth was just debunked on the other fuel-gauge thread: There's an urban legend that the fuel gauge is only required to be correct for an empty tank. The legend apparently arises from a bizarre misreading of 23.1337b1. What 23.1337b1 actually says is just clarifying that the 'empty' reading must correspond to zero USABLE fuel, as opposed to zero TOTAL fuel. There is nothing whatsoever to suggest that non-empty readings needn't be correct--that would be absurd. (If it were true, a gauge that ALWAYS says 'empty' would be legal! You could just write 'empty' on a piece of paper and call that your fuel gauge!) The requirement for indications of a tank's fuel level (not just on empty) is stated in 91.205b9, 23.1305a1, and 23.1337b. |
On 2008-02-22 20:24:47 -0800, WingFlaps said:
Hi all, A recurring theme seems to be that one should should not rely in fuel gauges. I can understand that from a safety point of view (I always dip the tank before start), but I get the feeling that they are considered just plain inaccurate. If an airplane does not have accurate fuel gauges then it is not airworthy. Knowingly climbing into an aircraft that you know has inaccurate fuel gauges is both dangerous and illegal. That is why you check them during preflight. From FAR 91.205: (a) General. Except as provided in paragraphs (c)(3) and (e) of this section, no person may operate a powered civil aircraft with a standard category U.S. airworthiness certificate in any operation described in paragraphs (b) through (f) of this section unless that aircraft contains the instruments and equipment specified in those paragraphs (or FAA-approved equivalents) for that type of operation, and those instruments and items of equipment are in operable condition. (b) Visual-flight rules (day). For VFR flight during the day, the following instruments and equipment are required: (1) Airspeed indicator. .... (9) Fuel gauge indicating the quantity of fuel in each tank. -- Waddling Eagle World Famous Flight Instructor |
correct for an empty tank. The legend apparently arises from a bizarre misreading of 23.1337b1. What 23.1337b1 actually says is just clarifying that the 'empty' reading must correspond to zero USABLE fuel, as opposed to zero TOTAL fuel. There is nothing whatsoever to suggest that non-empty readings needn't be correct--that would be absurd. (If it were true, a gauge that ALWAYS says 'empty' would be legal! You could just write 'empty' on a piece of paper and call that your fuel gauge!) The requirement for indications of a tank's fuel level (not just on empty) is stated in 91.205b9, 23.1305a1, and 23.1337b. Thank you! What you say makes perfect sense. I'll go look at the regs too. |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
Russian Airplane Instrument Gauges | Steve | Restoration | 1 | October 2nd 06 10:50 PM |
Fuel Level Sight Gauges | DonMorrisey | Home Built | 5 | August 10th 06 05:00 AM |
Need the temp and oil pressure gauges for a J3, where do I get them? | Eduardo B. | Restoration | 0 | December 5th 03 12:59 PM |
FA: Vintage aircraft gauges | Randal Peterson | Aviation Marketplace | 0 | November 13th 03 02:05 AM |
