Fuel Level Sight Gauges
Old August 6th 06, 01:21 AM posted to rec.aviation.homebuilt
DonMorrisey
Default Fuel Level Sight Gauges
I am building a BushCaddy which is very much like a Cub in appearance.
I have been searching for good quality Fuel Sight Gauges that get
mounted in the cabin through the wing root. have been unable to locate
anything so far. Does anybody have a source or lead? Thanks. Don...
Old August 6th 06, 04:18 AM posted to rec.aviation.homebuilt
Dave S
http://home.comcast.net/~nostromo56/
Vance Atkinson Sight Gauges.. common in Cozy/Long/Vari Eze type aircraft..
OR you can use 90 degree barbed fittings arranged vertically and use
clear tubing between the two fittings in order to visualize fuel levels.
OR..
http://www.aircraftspruce.com/catalo...fuel_gauge.php
for a mechanical float style gauge as I've seen mounted in taildragger
cessnas..
There have been some recent reports of problems with the Vance gauges in
the homebuilding community that relates to the orfices "plugging" or
sealing up... which while not PROVEN to be related to alcohol in fuel,
is suspicious for such.
The guys with the Vance Atkinson gauges in their planes swear by them,
otherwise.
Dave
Old August 9th 06, 05:37 PM posted to rec.aviation.homebuilt
You can buy FAA/PMA sight gauges from Dakota Cub but they are super
pricey. Same for Univair. I was able to buy the sight gauges that are
used in the Smith Cubs. Excellent quality and less than half the price
of others. They were listed on Koz Aero's website but I see they are
no longer there. Go to www.supercub.org and do a search on "sight
gauges" for more suggestions.
Old August 9th 06, 11:51 PM posted to rec.aviation.homebuilt
My Savannah kit came with a preformed nylon tube used for this purpose.
I like it because it is simple and effective, and only has two joints;
the points of attachment to the tank. The bends were heat formed, I
guess. I don't know what grade of nylon is used, but it is sort of
miky white, but gas is easy to see in it. Nylon is used in lots of
fuel system parts in automobiles, so this seems like a good choise.
tom
fuel leak or auxiliary fuel pump malfunction? [email protected] Owning 7 December 17th 06 12:57 PM
Q for Jim Weir or others: solid state fuel level probes? Charlie England Home Built 11 March 12th 04 12:35 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Hot weather and autogas? Rich S. Home Built 33 July 30th 03 11:25 PM
