Tow out gear for KA7
Old March 24th 08, 01:21 PM posted to rec.aviation.soaring
Default Tow out gear for KA7
Any ideas for tow out gear, for this, or other wood and fabric winged
gliders? Photo's of workable arangements greatly appreciated.
Regards
John
Old March 24th 08, 02:10 PM posted to rec.aviation.soaring
vontresc
On Mar 24, 8:21*am, " wrote:
Any ideas for tow out gear, for this, or other *wood and fabric winged
Regards
John
Actually I am in the same boat. I just bought a Ka-6 without tow out
gear. I was thinking of cobbling together my own, but I'd love to see
some examples first.
Peter
Old March 24th 08, 02:31 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
There's a Ka-6 in my club. Its tow-out gear looks remarkably like the
stuff I use on my Libelle. He has a fairly broad tail dolly collar, at
least 3/4 as wide as its diameter, with the usual clip-on tow-bar, which
has a U-shaped platform for the tail skid. I don't recall anything unusual
about the wing dolly.
martin@ | Martin Gregorie
gregorie. |
org | Zappa fan & glider pilot
Old March 26th 08, 03:55 PM posted to rec.aviation.soaring
vontresc
On Mar 24, 9:31*am, Martin Gregorie
martin@ * | Martin Gregorie
gregorie. |
org * * * | Zappa fan & glider pilot
Sounds like something that could be built. anyone got any suggestions
on making your own tail dolly? I was thinking of using the fuse as a
mold for some fiberglass (with a layer of plasic as a release of
course).
any input?
thanks
Peter
Old March 26th 08, 07:13 PM posted to rec.aviation.soaring
Simon Waddell
"vontresc" wrote in message
On Mar 24, 9:31 am, Martin Gregorie
gregorie. |
course).
any input?
thanks
Peter
Did it myself; but use a layer of thick felt rather than a sheet of plastic
since you'll want felt inside the finished dolly to protect the fuselage.
Also helps to have access to a vibrating saw to cut the dolly off -
hospitals use them to remove plaster casts.
Simon
Old March 26th 08, 11:04 PM posted to rec.aviation.soaring
Frank Whiteley
gregorie. |
course).
any input?
thanks
Peter
Simon
www.mcmaster.com for felt. Use the synthetic 1/8 or 3/16. 1/8 is
plenty thick for glass ships, but you might want 3/16 for wood
Frank Whiteley
Old March 27th 08, 12:27 AM posted to rec.aviation.soaring
Pete,
Talk to Mike Reyes. I think he built a wing wheel thingy for his K6.
As I remember it was a lot of work. I'd say screw it and spend the
time flying.
Matt
Regards
John
Peter
Old March 27th 08, 01:29 AM posted to rec.aviation.soaring
Frank Whiteley
Both the wing and tail dollys that came with my Libelle are lined with
6 mm (1/4") thick carpet. That works pretty well. The wing dolly has a
light frame made from steel strap on the underside to support the
struts. The main strut is a T piece welded from tube and with an old
bicycle fork welded on the end to take an ordinary 16" cycle wheel. The
cross bar of the T pivots near the trailing edge of the wing cuff. There's
a light gas strut running from the top of the fork to a pivot near the LE
of the cuff for suspension. Its 20 mm (3/4") in diameter and about 500 mm
(18") long. Its off a car body - supported a BMW's trunk lid at a guess.
One word of warning: DON'T build up the swivel wheel platform under your
tail dolly with car body filler and try gluing the wheel mount to it. The
tow bar applies a lot of force to the wheel, especially if you're braking.
If it sheers off you *will* wreck your rudder when it hits the back of
your car. I've seen that happen and analysed the dolly failure afterwards:
that dolly was an accident waiting to happen.
Better to build up the platform from laminated up 6 mm ply. Use
at least 4.5 mm (3/16" bolts to attach the wheel to the ply assembly and
both epoxy and more bolts to attach the ply to the fuselage cuff.
Finishing the job with one layer of 100 gsm (3 oz/yd) twill weave glass
cloth over the ply will weatherproof it and give a nice finish.
HTH
gregorie. |
Gear UP Jens Averbeck Aviation Photos 2 April 20th 07 11:27 PM
Gear Up, pt 6 - p-40.jpg (1/1) Mitchell Holman Aviation Photos 0 April 19th 07 03:31 AM
Gear Up, pt 4 - Crashed He 111 with balloon cable cutting gear - July 1940.jpg (1/1) Mitchell Holman Aviation Photos 0 April 13th 07 01:50 PM
Gear Up, pt 2 - B-26.jpg (1/1) Mitchell Holman Aviation Photos 0 April 11th 07 12:58 PM
Tow Out Gear Gadget Guy Soaring 6 January 11th 06 04:51 AM
