I have recently purchased a DG-300, and am in the process of getting it ready to fly this next season. If you have any equipment you are looking to sell, Please forward me pictures and price.
I need a wing wheel, one man rigging unit, tow bar. Send to jschaffer at techno-mation dot com. |
I don't have any gear to sell you, but I do have some well meaning
advice - don't buy a Cobra one man rigger. I found the Cobra rigger to not only be expensive, but also clumsy and awkward to use. It was difficult to get it close enough to the fuselage of my ASW-19B when loading the wing from my Cobra trailer; it was very hard to move the wing from side to side between the wheels when rigging the second wing; and the little kickstands did not properly lock in position. My comparison rigger was a homebuilt unit called the Lewis Loader. The Lewis Loader was lent to Tool-Tech, and they now produce one man riggers based upon its design features. This is most probably the rigger that I'll be buying. Hope this is helpful to you. -John Note: I have absolutely no connection with Tool-Tech or its distributor. |
Is this the same Tool-Tech rigging aid that Wings and Wheels sells? I
am trying to compare the 3 riggers that I can find available in the US (Wings and Wheels, Udo, and M&M) and really cannot make a decision. The wing holding cradle on the Wings and Wheels model seems like it might be less good on a flapped wing because it appears to grab the wing on the trailing edge. The Udo and M&M models seem to be almost identical in that regard, but the M&M does not have the horizontal adjustment option. Shipping from M&M is about half of what Udo asks. Anyone have any advice here? I cannot find anyone at my club who knows about these, and the only thing keeping me from ordering today is that I really cannot figure out which to order! Wish that I could go to the SSA convention to look for myself.... Thanks. |
Yes, Wings & Wheels sells the Tool-Tech rigger I referred to. I can't
speak to its use on a flapped wing, as Standard class machines were all I rigged. In use, the only force from the trailing edge grip would occur if the wing tried to twist or slide out of the holder. For a flapped machine you'd definitely want to know if the grip extended far enough forward to bear on the top surface of your wing. I have heard that minor modifications are planned for the Tool-Tech rigger - maybe this is one of them, you'd have to ask Tim Mara. For me, horizontal adjustment is important. Udo's rigger uses brass inserts riding on a square shaft, while the Tool-Tech uses linear bearings on a rod. The Lewis Loader proved to me that metal on metal makes it hard to adjust precisely, so the linear bearings are a definite plus. Also, the Tool-Tech appears to offer a larger horizontal adjustment range than Udo's, which is also useful to me. As you can see, I've pretty well made up my mind on the Tool-Tech. FYI, there is another rigger available in the USA, the WingMate from Chip Bearden. Check out his site: http://members.aol.com/wingstand/alternatives.htm Be sure to check out his link "Other Ways to Do It" for additional input on pros and cons. -John P.S. - I don't know the M&M model - do you have a link? |
I should have said MM Fabrication. I have seen one of the trailers
that they have made and it appears to be very well done. Thanks for your help. http://www.mmfabrication.com/ |
I met Mark Mocho at M&M last week. I, too, am looking for a 1-man
rigger. I was impressed with everything I saw. He has an option for the fore/aft adjustment, I believe. Outstanding workmanship and a good guy. I wouldn't hesitate to order one, except that my son is now building one for me for a ... very ... late Christmas present. Gotta wait and see how that comes out. I looked at his wing wheels and tow dollies, too. All of it is first rate. Jack Womack |
Mark Mocho's (MM Fabrication) wing wheels and tow-out bars are the best
in the business too. |
Saratoga Gear Retract Problem | Yahoo! News | Owning | 16 | November 29th 05 11:17 PM |
Jet engines vs. leaf blowers | 01-- Zero One | Soaring | 6 | September 8th 05 01:59 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
