			#321
			#322
On Apr 4, 4:27 pm,  wrote:
	OTOH I wonder how long a 150 could remain in a maximum effort slip without hitting the ground before a noticable/detectable fuel imbalance developed? Saw some-one once do a local with the 'ability' to fly one wing low in a C150. He lost about a third of his fuel through the low tank overflow  |
			#323
On Sat, 5 Apr 2008 17:51:27 +0000 (UTC), Bertie the Bunyip
	wrote: wrote in : On Fri, 4 Apr 2008 08:03:59 +0000 (UTC), Bertie the Bunyip wrote: wrote in news:21bbv3tlno484t5qe9krlvo19av0g23b5o@ 4ax.com: On Mon, 3 Mar 2008 21:56:54 +0000 (UTC), Bertie the Bunyip wrote: All things considered, I wonder how long you'd have to circle in a coordinated turn at 60, or 45 degrees before there was a fuel imbalance? :-)) Pattern turns ARE STILL supposed to be coordinated aren't they?cough OTOH I wonder how long a 150 could remain in a maximum effort slip without hitting the ground before a noticable/detectable fuel imbalance developed? with. Well, i know someone who unported a Bird-dog slipping and ended up deadsticking. They have no both selection, though. I've unported the Deb too, but it wasn't due to fuel running to the other side:-)) No baffels in the tanks. So, you were slipping towards the feeding tank, or was it turbulence or Tis limited in POH (but not placarded) to 20 seconds in any one direction. I was just out doing some steep slips practicing to see which method would get me down fastest in an emergency. I just held a wing down a tad too long. It started as soon as I rolled it level. It'll un port toward either tank regardless of which is feeding. Go to the POH emergency let down, (power off, gear down, flaps up) and then add a max effort slip and the rate of descent can get pretty impressive. I'd probably scare the crap out of any passengers, but if something requires an emergency descent that would be the least of my worries. something? Bertie  |
			#324
			#325
george  wrote in news:1423eebd-6a80-40dd-b045-1138d02653c5
	@q10g2000prf.googlegroups.com: On Apr 4, 4:27 pm, wrote: OTOH I wonder how long a 150 could remain in a maximum effort slip without hitting the ground before a noticable/detectable fuel imbalance developed? Saw some-one once do a local with the 'ability' to fly one wing low in a C150. He lost about a third of his fuel through the low tank overflow He would have done, OK. Bertie  |
			#326
On Sat, 5 Apr 2008 22:37:03 +0000 (UTC), Bertie the Bunyip
	wrote: wrote in : On Sat, 5 Apr 2008 17:51:27 +0000 (UTC), Bertie the Bunyip wrote: wrote in news:nfaev3hid96amp30ivek5impbs4pei6l55@ 4ax.com: On Fri, 4 Apr 2008 08:03:59 +0000 (UTC), Bertie the Bunyip wrote: wrote in news:21bbv3tlno484t5qe9krlvo19av0g23b5o@ 4ax.com: On Mon, 3 Mar 2008 21:56:54 +0000 (UTC), Bertie the Bunyip wrote: All things considered, I wonder how long you'd have to circle in a coordinated turn at 60, or 45 degrees before there was a fuel imbalance? :-)) Pattern turns ARE STILL supposed to be coordinated aren't they?cough OTOH I wonder how long a 150 could remain in a maximum effort slip without hitting the ground before a noticable/detectable fuel imbalance developed? with. Well, i know someone who unported a Bird-dog slipping and ended up deadsticking. They have no both selection, though. I've unported the Deb too, but it wasn't due to fuel running to the other side:-)) No baffels in the tanks. So, you were slipping towards the feeding tank, or was it turbulence or Tis limited in POH (but not placarded) to 20 seconds in any one direction. I was just out doing some steep slips practicing to see which method would get me down fastest in an emergency. I just held a wing down a tad too long. It started as soon as I rolled it level. It'll un port toward either tank regardless of which is feeding. ?? Really? If you slip in either direction you'll unprt regardless of which tank is feeding? I can't get my head around that. Can you exapnad a bit? Apparently it has to do with the location of the feeds in the tanks. I've never tried it with full tanks or worked at finding out just how low I could get before it'd do that or compared the feeding tank level Vs the other so there must be a specific fuel level the tanks must be down and I'd not doubt it'd be different between the one feeding and the other. Maybe I can go out and to the occasional slip each way to see how much each tank has to be down before it quits. Go to the POH emergency let down, (power off, gear down, flaps up) and then add a max effort slip and the rate of descent can get pretty impressive. I'd probably scare the crap out of any passengers, but if something requires an emergency descent that would be the least of my worries. Well, exactly. Whether they're there to praise you or damn you , they're there to do it. That's the point for every one to shut up and say put except the pilot. Unless the see a potential collision. bertie Roger (K8RI) ARRL Life Member N833R (World's oldest Debonair) www.rogerhalstead.com  |
| Thread Tools | |
| Display Modes | |
| flaps again | Kobra | Piloting | 107 | January 5th 08 05:31 PM |
| flaps again | Kobra | Owning | 84 | January 5th 08 05:32 AM |
| flaps | Kobra[_4_] | Owning | 85 | July 16th 07 07:16 PM |
| Flaps on take-off and landing | Mxsmanic | Piloting | 397 | September 22nd 06 10:02 AM |
| FLAPS | skysailor | Soaring | 36 | September 7th 05 06:28 AM |
