"Vicente Vazquez" wrote in message ... I've only seen pics of P-47's with the 75 , 108 or 150 gallon drop-tank, but never seen this one ... http://www.aviacaomilitar.com.br/webkits/hc001.jpg Just a guess ... is it a ASR inflateable "life raft" ? ~=~ John Ding (UK) |
never seen this one ... http://www.aviacaomilitar.com.br/webkits/hc001.jpg |
Possible a field modified tank. I've not seen this before either. Thx.
VL |
I've only seen pics of P-47's with the 75 , 108 or 150 gallon drop-tank, but never seen this one ... http://www.aviacaomilitar.com.br/webkits/hc001.jpg Could be either a 200 gallon tank or possibly a cardboard tank: "Following the early conformal 758 liter (200 US gallon) ferry tank and the lozenge-shaped flat 758 liter belly tank, teardrop-shaped 284 liter (75 US gallon) and 568 liter (150 US gallon) metal wing drop tanks were adopted. The P-47 also used British-designed 409 liter (108 US gallon) and 758 liter tanks made of plastic-impregnated paper. These tanks were cheap and were useless to the enemy if found after being dropped, though they could not store fuel for an extended period of time." www.vectorsite.net/avp47.html Brooks |
"Dingo" wrote in message ...
"Vicente Vazquez" wrote in message ... I've only seen pics of P-47's with the 75 , 108 or 150 gallon drop-tank, but never seen this one ... http://www.aviacaomilitar.com.br/webkits/hc001.jpg I'm not even going to try and guess... but I will tell you that the P-47s used many other drop tanks including: 100, 110, even 165 gallon types... in adition to the napalm ones. Maybe this will lead you to the right one. BTW, is the "hc" in the URL refer to a Hobby Craft kit? If so, look up a HC P-47 kit with drop tank. Just a suggestion. Rob Sorry I couldn't answer your question directly; if it were German drop tanks the answer would be easy! |
"Vicente Vazquez" wrote in message ... I've only seen pics of P-47's with the 75 , 108 or 150 gallon drop-tank, but never seen this one ... http://www.aviacaomilitar.com.br/webkits/hc001.jpg My guess is a field modification. A standard 75 gallon tank split at the joint with a plug inserted. |
"Vicente Vazquez" wrote: I've only seen pics of P-47's with the 75 , 108 or 150 gallon drop-tank, but never seen this one ... http://www.aviacaomilitar.com.br/webkits/hc001.jpg Looks like one of the ferry tanks that they used. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
... "robert arndt" escreveu na mensagem om... BTW, is the "hc" in the URL refer to a Hobby Craft kit? If so, look up a HC P-47 kit with drop tank. Actually, I used "hc" on the file name referring to the source of the image, a book in Portuguese called "Heróis dos Céus", about the Brazilian Fighter Squadron that fought in Italy. The image of the belly tank is actually just a "close up" of part of this image: http://www.aviacaomilitar.com.br/webkits/hc002.jpg Vicente That's an artistic roundel on the plane in the rear. Cheers Dave Kearton |
om... BTW, is the "hc" in the URL refer to a Hobby Craft kit? If so, look up a HC P-47 kit with drop tank. Actually, I used "hc" on the file name referring to the source of the image, a book in Portuguese called "Heróis dos Céus", about the Brazilian Fighter Squadron that fought in Italy. The image of the belly tank is actually just a "close up" of part of this image: http://www.aviacaomilitar.com.br/webkits/hc002.jpg Vicente |
"Dave Kearton" escreveu na
mensagem ... That's an artistic roundel on the plane in the rear. Cheers Dave Kearton Nope. That's the Brazilian AF's insignia painted over USAAC's insignia. This had to be done because of ID problems, inclusing some of our P-47's almost being attacked by RAF Spitfires in one occasion. When the Brazilian P-47's arrived at Tarquinia, they had only the Brazilian markings painted on four positions on the wings and none on the fuselage, as seen in this pictu http://www.aviacaomilitar.com.br/jam...26777_01_g.jpg Then, because of these ID problems, it was decided to apply the US "Star and Bars" following the standart of american P-47's and paint the Brazilian "Star" over them. Cheers. Vicente |
| fuel tank plumbing | pwm | Home Built | 18 | January 27th 05 05:54 AM |
| Building a gas tank | Lou Parker | Home Built | 11 | September 13th 04 10:16 PM |
| FS: or trade - Scott "Executive II" O2 tank assembly near ATL | Mike Patterson | Aviation Marketplace | 0 | January 27th 04 05:07 PM |
| Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 03:57 AM |
| Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 10:14 AM |
