Building a gas tank
Old August 12th 04, 10:55 AM
Lou Parker
Default Building a gas tank
I'm at the point where I need to build a gas tank or 2. The sport
plane builder book shows a great way to do a custom tank but materials
it calls for are not listed (or I'm reading it wrong) so, any
recommondations on a foam core that will stand up to gas? Any
recommondations for a fiberglass system? I'm all ears, or in this case
eyes.
Lou
Old August 12th 04, 04:10 PM
Gilan
I made a custom shaped gas tank a couple years ago. I had no experience at
all doing such a project but I ended up making a nice tank for my plane.
http://www.mitchellwing.com/FLYING_F...s/MVC-340F.JPG
Have a good day and stay out of the trees!
See ya on Sport Aircraft group
http://groups.yahoo.com/group/Sport_Aircraft/
You may be an Ultralighter if........
http://www.flyinggators.com/news/Bill%20Cook/Bill.htm
Old August 13th 04, 07:02 AM
Roger Halstead
eyes.
The G-III uses Vinyl Ester Resin and foam cores for the header tank.
I don't remember as they actually tell you the chemical composition of
the foam. It is a light tan color.
The cut the sides, bottom and back from 5# 1/2 inch foam, seal the
foam with a thin micro sphere (Q-cell) mix, then give it two layers of
fiberglass and resin on each side. These lay-ups are a bit on the
resin rich side.
You don't even get Styrofoam near Vinyl Ester resin. It dissolves it.
Vinyl Ester Resin contains liquid Styrene. Let it set around too long
and it gets "chunky".
The only drawback I can see to the Vinyl Ester Resin is the short
shelf life. Supposedly only a couple of months after being promoted,
but I get 6 months to a year after promotion. I'm just finishing a
gallon that was promoted in March and it shows no sign of getting
chunky. Only a couple more lay-ups and that can will be empty. I'm
promoting a new gallon so it'll be ready to use by tomorrow night.
Contrary to the instructions in the manual. I just pour in the proper
amount, and shake the can in all axis for about 5 minutes. Let set
over night, shake again, and then run a test batch about 6 hours
later.
www.rogerhalstead.com
Lou
Old August 13th 04, 07:36 AM
On Fri, 13 Aug 2004 06:02:41 GMT, Roger Halstead
Back when I was about ten, I tried to build a styrofoam wing for a
U-Control airplane. When I was carving the airfoil, the wing broke in
half. Being both lazy and poor, I just slobbered glue over the broken
edges, put the pieces back together, and set them down on a piece of wax
paper.
When I came back a half-hour later, there was a ~1/2" gap between the
halves of the wing. "That's strange," I said. I slathered some more glue
on the two pieces, jammed them back together, and set it on the wax paper.
A half hour LATER...well, there *still* was a 1/2" gap. Right about then,
I started to figure it out. :-)
Ron "Nod's as good as a wink to a blind bat" Wanttaja
Old August 14th 04, 09:56 PM
Charlie England
eyes.
Lou
If it's a relatively simple shape & you aren't just addicted to resin
fumes, aluminum works great & stands up to just about any fuel. If you
don't have access to a bending brake, most sheet metal shops can do the
bends for you. If flanges are external to the tank volume, you can seal
the joints with 'proseal' & rivet it with 'pulled' rivets.
Charlie
Old August 15th 04, 07:19 AM
Richard Lamb
eyes.
Lou
Charlie
Gotta agree with Charlie on this one.
Aluminum is way mo betta.
I haven't tried this myself (no guts?) but one of my builders
reported good results using a novel technique.
Flange the end pieces, and make a wrapper skin.
Etch both using the green stuff (phosphate etch from Home Depot?)
Prime with something like Epibond.
Then assemble using PL-1 urethane adhesive (i believe) and pop rivet
the tank together.
Hey, that's why the cal it experimental!
Richard
Old August 15th 04, 04:59 PM
Lou Parker
Richard Lamb wrote in message ...
eyes.
Lou
Charlie
the tank together.
Richard
These have been great responses. But what about places to attatch fuel
sending units, gas caps, and drain plugs? How do they attatch and
where? Do you glass in a peice of wood to screw to? or better yet, a
peice of corian that can hold screws but not be affected by wood? What
about support flanges to fiberglass? With enough bouncing around,
screws will rip through fiberglass.
Loiu
Old August 15th 04, 10:01 PM
B2431
Wouldn't a composite fuel tank be a static electricity risk?
Dan, U.S. Air Force, retired
Any good web sites for instructions for building fiberglass items? [email protected] Home Built 0 July 7th 04 03:02 AM
Looking for small header tank Rob Turk Home Built 5 February 27th 04 07:52 AM
Four Winds 192 Crash into the Miami Federal Reserve Building, a year ago today Billgran Home Built 3 December 6th 03 03:22 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
?s about building a gyrocopter John Normile Home Built 2 September 14th 03 02:01 AM
