The tail dolly for my new WalletWhomper II came without a handle on
top. I want to add one. I am betting that drilling holes and using flathead machine screws from inside will still endanger the fuse boom. Any hot tips? (Besides "If you have to ask, don't do it.") 2NO |
On Apr 25, 9:27*am, Tuno wrote:
The tail dolly for my new WalletWhomper II came without a handle on top. I want to add one. I am betting that drilling holes and using flathead machine screws from inside will still endanger the fuse boom. Any hot tips? (Besides "If you have to ask, don't do it.") 2NO Yeah, screws would probably be a bad thing. Fiberglass cloth and Polyester Resin*(adequate for dollies) are usually readily available and reasonably cheap. Cut/carve/sand a wooden handle to fit. Remove the paint from the dolly for a couple inches around where the handle will join it. Glue the handle to the dolly with some 5 minute epoxy (so you won't have to chase it around while trying to get glass on). After it sets, cut fiberglass to form a fillet joining the handle to the dolly. I would want no fewer than 3 layers, ( more, time permitting). Apply resin and cloth. Don't worry about the stray strands the will inevitably end up sticking out. They're easy to sand off. One trick for getting the cloth to stay where you want it (IN NON CRITICAL APPLICATIONS) is to dust the cut pieces of cloth with 3M 77 spray adhesive, wait a couple minutes, then rub them into place. The resin will usually wet out a couple layers easily. The resin at least partially dissolves the cement though, so 'working' it too much will have the pieces sliding around. * However, if you have epoxy resin handy, the working time is vastly longer, it's mechanically stronger, and you can clean up with white vinegar. |
On Apr 25, 9:27 am, Tuno wrote:
The tail dolly for my new WalletWhomper II came without a handle on top. I want to add one. I am betting that drilling holes and using flathead machine screws from inside will still endanger the fuse boom. Any hot tips? (Besides "If you have to ask, don't do it.") 2NO Another solution is to use T nuts, or rather Weld Nuts, mounted on the inside of course, (you have to peal the padding back from that area), and a quick solution to make it even more load-worthy would be to epoxy a rectangle of .050 aluminum sheet (it will easily conform to the contour) before drilling the holes, then use the weld nuts fed from the inside. I am doing the same operation on my dolly right now, but my ship being an SZD-59 the dolly is rather interesting were a handle would mount (strake at base of vertical...). I am going to use a cast aluminum oval x-section handle form McMaster Carr that is made to through-bolt from the top, making it ideal to use with 1/4-20 weldnuts (after reeming the .250" holes to .315" or so... http://www.mcmaster.com/ , pg 2925, pull handle style 21, pick your own size) . Naturally ake sure your cap screws are short enough not to protrude. This particular handle feels very comfortable in the hand (I have the same type on my Sisu trailer tongue) pulling/pushing all directions, and stays surprizingly cool even after sitting in direct sunlight. Just a suggestion, there are a million ways to go about this one. Paul |
I have pealed the felt back and pop-riveted on a handle with the rivet
head on the inside and a washer on the outside, using 1/8" aluminum rivets. Then contact cement the felt back in place. Worked for me. JJ Tuno wrote: The tail dolly for my new WalletWhomper II came without a handle on top. I want to add one. I am betting that drilling holes and using flathead machine screws from inside will still endanger the fuse boom. Any hot tips? (Besides "If you have to ask, don't do it.") 2NO |
On Apr 25, 12:45*pm, JJ Sinclair wrote:
I have pealed the felt back and pop-riveted on a handle with the rivet head on the inside and a washer on the outside, using 1/8" aluminum rivets. Then contact cement the felt back in place. Worked for me. JJ Tuno wrote: The tail dolly for my new WalletWhomper II came without a handle on top. I want to add one. I am betting that drilling holes and using flathead machine screws from inside will still endanger the fuse boom. Any hot tips? (Besides "If you have to ask, don't do it.") 2NO- Hide quoted text - - Show quoted text - Now see, that's why JJ's a professional. Simple, quick and effective. Disregard my earlier reply! |
Tuno wrote:
The tail dolly for my new WalletWhomper II came without a handle on top. I want to add one. I am betting that drilling holes and using flathead machine screws from inside will still endanger the fuse boom. Any hot tips? (Besides "If you have to ask, don't do it.") 2NO I bought from SH a dolly "shell" since the shell itself was WAY less expensive than the complete dolly. I'd recommend you peel back the padding and invest in a decent countersink. Match drill the holes and install flat head screws AFTER you countersink the inside of the dolly so that the head of the screw is flush with the inside surface. Then use some contact cement and put the felt back in place. Gary |
I like simple and effective, and I have all the tools and materials
necessary! Thanks JJ!!! |
I did this mod. last year. I went to a good hardware store and bought
a concrete float, used for smoothing out concrete. It is a very hefty handle with a metal plate attached to it with screws, the plate is countersunk so that the screws don't contact the concrete. I pulled the padding away, managed to bend the metal plate into the curve of the dolly, screwed it all back together, and used 3M HS-90 spray adhesive to glue the felt back on. I wanted the plate so the screws wouldn't pull through the fiberglass. Very simple, cheap, looks really good. |
| ASK-21 - is a tail dolly necessary? | Dave Springford | Soaring | 7 | December 31st 07 09:43 AM |
| FS: ASW-24 Tail Dolly | [email protected] | Soaring | 0 | December 26th 06 03:40 PM |
| WTB: used tail dolly | David Campbell | Soaring | 5 | April 17th 06 04:19 PM |
| Tail Dolly Tire | Albert Gold | Soaring | 7 | May 19th 05 02:36 PM |
| L-23 tail dolly | Mark Zivley | Soaring | 1 | November 27th 04 12:16 PM |
