ASK-21 - is a tail dolly necessary?
Old December 30th 07, 08:54 PM posted to rec.aviation.soaring
Dave Springford
Default ASK-21 - is a tail dolly necessary?
My club is buying a K-21 for student training and I am wondering if a
tail dolly is necessary for ground handling?
We plan to get the tail wheel option - not the tail skid.
Does the K21 balance like the Twin Astir so it is easy to turn on the
ground when towing it back to the launch point?
When empty, does it sit on the main and tail wheel, or main and nose
wheel.
Anyone with experience operating a K-21 please advise
thanks,
Dave Springford
Old December 30th 07, 09:04 PM posted to rec.aviation.soaring
Christian Ronge
Hi Dave,
a dolly is not necessary, the empty 21 does sit on the tail and main
wheel. It's easy to ballance on the main wheel with one person pushing
down the nose.
None the less a tail dolly always helps if there are only few people
there for ground handling.
Chirs
Old December 30th 07, 09:09 PM posted to rec.aviation.soaring
John Smith
It depends on what you call "necessary" and how your operation works. It
definitely makes ground handling easier. For me, it's worth the
(comparatively small amount of) money.
wheel.
Tail wheel.
Old December 30th 07, 09:10 PM posted to rec.aviation.soaring
Peter Thomas
we have 5 at LGC, they sit lightly on the tail when
empty, push down on the nose or cockpit rim with 1
hand to lift tail
Pete
am wondering if a
skid.
to turn on the
or main and nose
wheel.
thanks,
Dave Springford
Old December 30th 07, 09:40 PM posted to rec.aviation.soaring
HL Falbaum
Hi Dave---
Our club, Mid Georgia Soaring, has 2 K21's , with tail dollies.
If towing out to the launch line is on grass, the tailwheel can slide
sideways without extra wear. If on pavement, it is much easier on the
tailwheel tire if you use a tail dolly. It is certainly easier on the
structure. The tailwheel rests on the ground when the cockpit is not
occupied. If ground transporting, you can move the glider easily with a
driver, wingman and a dolly. Otherwise, you need to stop and maneuver the
fuse to make a turn, or drag the tailwheel sideways.
We have dollies and like them.
Hartley Falbaum
Georgia, USA , "KF"
"Dave Springford" wrote in message
wheel.
thanks,
Dave Springford
Old December 30th 07, 10:09 PM posted to rec.aviation.soaring
Mike Schumann
Our club has a K-21. We don't use a dolly and don't have a problem. If you
are towing on pavement and make sharp turns (we are on a grass strip), a
dolly might be nice. Otherwise, its absolutely not necessary (I would go as
far as saying that it would be an unnecessary pain in the.....)
Mike Schumann
wheel.
thanks,
Dave Springford
Posted via a free Usenet account from http://www.teranews.com
Old December 30th 07, 10:12 PM posted to rec.aviation.soaring
Michael Ash
wheel.
Just to add to the responses already present, my club has an ASK-21 and a
Twin II and I find them to be essentially identical in ground handling.
(Air too, but that's another subject.) It's certainly possible to manage
without a dolly, but it's much nicer with one. The fact that we don't have
one for our Grob is a small but continuing source of annoyance. It's
particularly handy when maneuvering behind the tow car with a single
person handling the glider.
Michael Ash
Rogue Amoeba Software
Old December 31st 07, 08:43 AM posted to rec.aviation.soaring
Cats
wheel.
thanks,
Dave Springford
We have two K21s without tail dollys and don't have any problems. The
CoG when empty is just behind the main wheel, so if one has to go
round a sharp corner it's easy for the person walking the nose to push
down and the wingman to turn the glider. However ours go straight
into their hanger bays. If you had to pack them into a conventional
hanger a tail dolly might be very useul. Our airfield is all grass
and the only place where there is a lot of wear that we have had to do
something about is right outside the hanger, where there is the most
traffic - where the launch point is depends on where the wind is so
that doesn't generate another worn patch. Also, if we had them some
bright spark would inevitably end up trying to put the K21 in the
hanger with the dolly on, leading to an expensive noise at elevator.
FS: ASW-24 Tail Dolly [email protected] Soaring 0 December 26th 06 02:40 PM
FS - Discus 2b Tail Dolly. Guy Byars Soaring 0 December 18th 06 06:01 PM
WTB: used tail dolly David Campbell Soaring 5 April 17th 06 03:19 PM
Lark tail dolly Gordon Schubert Soaring 0 September 6th 05 04:56 AM
L-23 tail dolly Mark Zivley Soaring 1 November 27th 04 11:16 AM
