#121
On May 3, 4:15*am, wrote:
Gig 601Xl Builder wrote: wrote: Gig 601Xl Builder wrote: Steven P. McNicoll wrote: "Gig 601Xl Builder" wrote in message news:jqednZIj4dsLq4fVnZ2dnUVZ_u2dnZ2d@supernews .com... Are you asking about stoke or if it is a problem to ATC? I'm asking how TSA's view of things is a problem to ATC. If national security, a DHS issue, overlaps ATC, a DOT issue, don't count on DOT winning the argument. Yes one must concider the potential horror of fleets of all fiberglass gliders with no transponders coming across the Atlantic filled with terrorists and nuclear bombs. I didn't imply that there was such a threat. This as most conversations with Mr. McNicoll is an offshoot of the original conversation. Because he made some comment that while not really wrong isn't how the real world works. Didn't say you did. My point is that in a sane world (big leap of faith there) DHS wouldn't have any interest in gliders as one would be hard pressed to come up with a scenario involving national security and a glider. Not hard at all. It flies, it can carry a bomb and explosives. It is cheap and readily available. Cheers |
#122
![]() "Gig 601Xl Builder" wrote in message m... Steven P. McNicoll wrote: "Gig 601Xl Builder" wrote in message m... TSA is in DHS, DHS does not dictate ATC policy. No the POTUS does and he probably listens to DHS more than DOT. What ATC policies have been dictated by the POTUS? Why would the POTUS rely on DHS for ATC policy over DOT? Would he rely on DOT over DHS on security matters? And policy promulgated by DOT, DHS, DOD, is dictated by the POTUS. What ATC policies have been promulgated by DOT, DHS, or DOD? In most cases it is actually dictated by people he selects to handle those departments but the final authority rests on the desk of the POTUS. What ATC policies have been promulgated by the secretaries of DOT, DHS, or DOD? As for your other two questions think overlap. Why can't you just answer the questions? |
#123
Alan wrote:
Other factors include the output voltage under load at discharge -- a lead acid battery is rated to 10.2 to 10.5 volts for a "12 volt" battery at discharge. Powersonic uses 10.5 volts for 5 to 20 hour discharge rates. Unfortunately, most 12 volt radios and devices are designed for a charging electrical system, with a voltage of about 14 volts. Most panel mounted radios (definitely for Dittel and Becker radios) bought new in the last 20 years (and even some older ones) meet the current requirements to function properly to 10.5 volts, and at even lower voltages, but with reduced power output. "Very old" radios likely will have problems at 10.5 volts. I have no idea what the percentage of "old" and "new" are. When the battery is down to 75% of the expected voltage for the radio, not all of them work. I have had aircraft radios that would not transmit below about 11.5 volts, at which point the battery would be still above 50% charged. Powersonic shows it's batteries have only 25% capacity left at 11.5 volts. I haven't checked other brands, but believe they are the same for the batteries we use in our gliders. Lead acid batteries are normally rated for capacity at a 20 hour rate of discharge. A 7 AH battery would deliver 7000 / 20 = 350 mA for 20 hours. Faster discharge rates result in less capacity being available (look up Peukerts exponent for more details). Discharging faster than that, reduces the amp-hour capacity of the battery. At a current drain of 700 ma (10 hour rate) that you might have with transponder, radio, etc, Powersonic shows a capacity of 90% of the 20 hour rate. That's not a show-stopper, but worth taking into account. Lead acid batteries have less capacity when cold. One guide suggests that for every 10 degrees centigrade below room temperature, you should add 10% to the battery capacity needed. High altitude flight tends to get up into cold places. This corresponds with the Powersonic chart, so at -10C (15F), you have a 30% loss of capacity. For winter flying, and spring or fall flying in places where you can climb to, say, 10,000' agl, it's an important factor. Especially so, when you know your encoder will likely be using it's heater, adding 50-150 milliamps to your current drain. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#124
![]() "Eric Greenwell" wrote This corresponds with the Powersonic chart, so at -10C (15F), you have a 30% loss of capacity. For winter flying, and spring or fall flying in places where you can climb to, say, 10,000' agl, it's an important factor. Especially so, when you know your encoder will likely be using it's heater, adding 50-150 milliamps to your current drain. Put a insulated cover around the battery, and the heat of discharge will keep it warm and the capacity up, unless it is seriously freakin' cold. -- Jim in NC |
#125
Morgans wrote:
"Eric Greenwell" wrote This corresponds with the Powersonic chart, so at -10C (15F), you have a 30% loss of capacity. For winter flying, and spring or fall flying in places where you can climb to, say, 10,000' agl, it's an important factor. Especially so, when you know your encoder will likely be using it's heater, adding 50-150 milliamps to your current drain. Put a insulated cover around the battery, and the heat of discharge will keep it warm and the capacity up, unless it is seriously freakin' cold. Insulating it will keep if from cooling off as quickly, but I'm skeptical about the amount of self-heating. Do you know how much it is, or where I can find a reference to it that applies to the batteries we us? Insulating my battery is difficult due to it's location, so I'd like to know it's worth the effort before attempting it. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#126
WingFlaps wrote: How slow does a target need to be to be undisplayed -typically? I would have thought that even a glider is fast (45 knots) compared to usual clutter. Don't forget that it's the radial velocity that is detected by skin paint. -- Bob Noel (goodness, please trim replies!!!) |
#127
On May 4, 8:37*am, Bob Noel
wrote: In article , *WingFlaps wrote: How slow does a target need to be to be undisplayed -typically? I would have thought that even a glider is fast (45 knots) compared to usual clutter. Don't forget that it's the radial velocity that is detected by skin paint. Aha, someone who understands Dopplewho knows!. data from the secondary sites can fix that problem. Cheers |
#128
In rec.aviation.piloting WingFlaps wrote:
On May 4, 8:37?am, Bob Noel wrote: In article , ?WingFlaps wrote: How slow does a target need to be to be undisplayed -typically? I would have thought that even a glider is fast (45 knots) compared to usual clutter. Don't forget that it's the radial velocity that is detected by skin paint. Aha, someone who understands Dopplewho knows!. data from the secondary sites can fix that problem. The FAA radars are what they are. You can arm wave forever about what they could be, but that isn't going to change them. -- Jim Pennino Remove .spam.sux to reply. |
#129
#130
![]() Larry Dighera wrote: On Sat, 03 May 2008 23:15:03 GMT, wrote in : The FAA radars are what they are. You can arm wave forever about what they could be, but that isn't going to change them. But decommissioning them, as part of the ADS-B implementation, will make them moot. What is being lost? Primary radar is making a comeback after 2001, not going away. |
Gliders, transponders, and MOAs | Greg Arnold | Soaring | 2 | May 26th 06 05:13 PM |
Cessna forced down by the Feds | C J Campbell | Piloting | 51 | February 8th 05 01:29 PM |
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* | JStONGE123 | Military Aviation | 1 | May 11th 04 06:22 AM |
Transponders and Radios - USA | Ray Lovinggood | Soaring | 1 | February 27th 04 06:10 PM |
Transponders, Radios and other avionics procurement questions | Corky Scott | Home Built | 5 | July 2nd 03 11:27 PM |
