On May 10, 11:19*am, Ralph Jones wrote:
On Fri, 9 May 2008 18:15:51 -0700 (PDT), wrote: I know, I know. *BTDT. *Has anyone purchased a NEW sailplane lately, and been happy with the wheel brake? *The ONLY glider I've ever flown with a decent (not great, but decent) wheel brake is the LVVSA's G103 Twin Astir. For me, a GREAT brake will REQUIRE moderation on my part to keep from grinding the nose. *I'm used to relatively modern motorcycles, that will lock the front wheel with 2 or 3 fingers. *I would vastly rather scrape my nose, than hit the barbed wire at the far end of a landout. My partners and I used to have an Astir-CS. A careful brake adjustment would buy you one, maybe two, firm stops, and the next stop would get more help from the tailskid than from the brake. We tried grooving the brake shoes which our mechanic recommended, but that had no effect. The real problem was in the linkage. It was actuated by a motorcycle squeeze grip on the stick, and there just wasn't enough travel available. If the handle moved more than an inch before the shoe made contact, the rest of its travel would be used up in stretching the cable, and the handle would hit the stick grip before any real force got to the shoes. So we decided to try replacing the cable with something stiffer. An extensive parts search disclosed that the existing cable was precisely identical to a Bultaco clutch cable...we were trying to stop a 600-pound sailplane with a cable meant to work the CLUTCH on a 200-pound motorcycle. We eventually found something that worked a bit better, but still had to adjust pretty frequently. rj Yes, I've replaced the original cable on my Speed Astir with more substantial cable, running in a Teflon sleeved outer. Some improvement, but lets face it, the mass of the glider and the size of that single leading shoe brake make it stop, quite predictiably, just as well as an early 60's Harley. |
On May 10, 7:21*pm, Doug Hoffman no.spam wrote:
wrote: I know, I know. *BTDT. *Has anyone purchased a NEW sailplane lately, and been happy with the wheel brake? *The ONLY glider I've ever flown with a decent (not great, but decent) wheel brake is the LVVSA's G103 Twin Astir. For me, a GREAT brake will REQUIRE moderation on my part to keep from grinding the nose. *I'm used to relatively modern motorcycles, that will lock the front wheel with 2 or 3 fingers. *I would vastly rather scrape my nose, than hit the barbed wire at the far end of a landout. I agree completely with that last sentence! I had an RS-15 in which the builder had installed a standard 4" Tost drum brake (better than the kit's band-on-tire brake I suppose). *The brake was essentially useless. *I've posted this before. *I applied the Tillmann Steckner brake modification (March 1998 Soaring) with superb results. *The new owner of the RS commented on how great the wheel brake function is. *But then this isn't a new glider. *Sorry. Regards, -Doug Thanks for the reference Doug. I'm sure someone in our club has that issue. I'll look into it. Your 4" tost wasn't the 'Lilliput" as used on the Libelle, was it? Those are fairly hopeless. The brake on my Speed Astir is the same as the LS-4. Both are marginal. At least the Speed Astir doesn't have the undercarriage issues the LS-4 does! |
James,
If your brake is properly adjusted and still doesn't work, I would check the drum for cracks which can occur from attempted hard breaking. I tried to stop my LS-6 with a load of water and cracked the drum in 3 places. Google Vintage Brake, they will install a soft shoe and true up the system (turn the drum, spike the shoe) and give you the best shot of reasonable breaking. Make sure your hard points are secure, I once saw an ASW-15 where the bulkhead that mounted the wheel hard-point, was moving just a tad, but enough to prevent the force from being transmitted to the brake. Hope this helps, JJ wrote: On May 10, 7:21�pm, Doug Hoffman no.spam wrote: wrote: I know, I know. �BTDT. �Has anyone purchased a NEW sailplane lately, and been happy with the wheel brake? �The ONLY glider I've ever flown with a decent (not great, but decent) wheel brake is the LVVSA's G103 Twin Astir. For me, a GREAT brake will REQUIRE moderation on my part to keep from grinding the nose. �I'm used to relatively modern motorcycles, that will lock the front wheel with 2 or 3 fingers. �I would vastly rather scrape my nose, than hit the barbed wire at the far end of a landout. I agree completely with that last sentence! I had an RS-15 in which the builder had installed a standard 4" Tost drum brake (better than the kit's band-on-tire brake I suppose). �The brake was essentially useless. �I've posted this before. �I applied the Tillmann Steckner brake modification (March 1998 Soaring) with superb results. �The new owner of the RS commented on how great the wheel brake function is. �But then this isn't a new glider. �Sorry. Regards, -Doug Thanks for the reference Doug. I'm sure someone in our club has that issue. I'll look into it. Your 4" tost wasn't the 'Lilliput" as used on the Libelle, was it? Those are fairly hopeless. The brake on my Speed Astir is the same as the LS-4. Both are marginal. At least the Speed Astir doesn't have the undercarriage issues the LS-4 does! |
On May 9, 9:15 pm, wrote:
I know, I know. BTDT. Has anyone purchased a NEW sailplane lately, and been happy with the wheel brake? The ONLY glider I've ever flown with a decent (not great, but decent) wheel brake is the LVVSA's G103 Twin Astir. For me, a GREAT brake will REQUIRE moderation on my part to keep from grinding the nose. I'm used to relatively modern motorcycles, that will lock the front wheel with 2 or 3 fingers. I would vastly rather scrape my nose, than hit the barbed wire at the far end of a landout. The Antares gliders use a Beringer brake and master cylinder. These are very light, and stop this glider easily (I'm 550kg dry, 660kg at max gross). Only negative: remember not to touch down with spoilers out full or you may end up replacing a tire ! I'm extremely happy with this system. A good brake system is comprised of a lot of bits that need to all be done properly. Here are some of the screw-ups provided with existing offerings: - bicycle cables that stretch (even actuating hydraulics) - cable routing that shreds cables (sharp turns) - travel limited by badly designed mixing with spoiler mechanism - hydraulic reservoir below slave cylinder when gear retracted (siphon action pulls slave cylinders away from disc) - excess tension blocks open system from venting - fluid type change leading to corrosion - single leading shoe drums - inadequate support for actuating cam in side casting (wear and slop prevent proper actuation) - bearings sized inadequately for static load of glider at max gross (flats bearings which will burn out on Minden take-offs) I could go on... See ya, Dave "YO electric" |
RW wrote:
This topic was in vogue back in 2002. There was mention of a cycle brake shop in California called VINTAGE BRAKE. I contacted Mike Morse the owner, and eventually sent him my 5" Tost wheel. What he did was to install a set of 'advanced composition' brake shoes designed to minimize fading and to improve the overall performance of vintage motorcycle drum brakes. He needed my actual wheel so he could first true it and then 'arc in' the brake shoes to an exacting tolerance. My DG200's braking went from virtually non-existent to nose-scrapingly effective ![]() on these... I found the braking very very effective, yet progressive. I also changed out the stock 'bicycle brake" quality handbrake lever and cable, and installed a Harley clutch cable and a higher quality bicycle handbrake lever on the control stick. It's a must to minimize stretch in these cables if you want to deliver full force to your brake shoes. The brake is now overdue for a new set of shoes. It has been over 6 years since this overhaul was done, and I can tell that the effectiveness is slipping a bit. Even though I'm overdue, the braking is still much superior to the original 5" Tost. It was also very inexpensive as I recall. www.vintagebrake.com Mike Morse was very pleasant to work with. I've tried some of the other exotic drum brake fixes out there without success. One of these 'fixes" is downright dangerous, as it can induce a lockup of the brake....hopefully one would not accidentally touch the lever during a takeoff roll... Hope this will help someone. It has served me well. Makes one wonder how/why Tost built such poor brakes for so many years. -- Regards -Doug ** Posted from http://www.teranews.com ** |
On May 29, 2:22*pm, (Doug Hoffman) wrote:
Makes one wonder how/why Tost built such poor brakes for so many years. Maybe because glider manufacturers kept buying them? Maybe because a good brake is not much use on wet grass? Anyway they were not a bad as some people make out. I serviced mine (ASW-19b) at every annual inspection and it was good for a season unless called upon to do a max energy stop. Each year I dismantled the brake, cleaned the drum and gave it a light wipe with 600 grit, cleaned the shoes and busted any glaze with 600 grit, cleaned and greased the cam faces and shaft and the pivot point. Its important that the brake is applied as the wheel spindle nut is tightened to ensure the brake plate is properly aligned. It's also important that the cable and cam arm make an angle of about 85 deg to each other when the brake is full on to get maximum mechanical advantage. None of this was strange to me as I had years of experience dealing with British motorcycle drum brakes before I got into gliding. Andy |
issue. I'll look into it. Your 4" tost wasn't the 'Lilliput" as used on the Libelle, was it? Those are fairly hopeless. The brake on my Speed Astir is the same as the LS-4. Both are marginal. At least the Speed Astir doesn't have the undercarriage issues the LS-4 does! I would like to hear about the "undercarriage issues" with the LS-4. Bob |
Brakes? | WingFlaps | Piloting | 69 | March 4th 08 06:27 AM |
truck + 5th wheel RV + glider trailer ?? | Steve Koerner | Soaring | 16 | March 27th 07 03:44 AM |
Wheel, axles and brakes for sale. | [email protected] | Home Built | 0 | December 5th 05 02:51 PM |
BGA Tech. News, Wheel brakes. | W.J. \(Bill\) Dean \(U.K.\). | Soaring | 8 | May 31st 05 01:55 PM |
Wheel pants for 6.00 x 6 wheel/tire | Wallace Berry | Home Built | 2 | January 23rd 04 04:22 AM |
