truck + 5th wheel RV + glider trailer ??
Old March 26th 07, 02:45 PM posted to rec.aviation.soaring
Steve Koerner
Default truck + 5th wheel RV + glider trailer ??
Hello all,
I'm wondering if anyone had ever tried using a fifth wheel RV to pull
a glider trailer.
This would make an ideal setup for going to glider contests if the
trailing dynamics were workable. I did a cursory look on the web
yesterday and found a 30 ft fifth wheel that did come equipped with a
trailer hitch.
It also would seem to be a fairly economic plan in that you can buy a
lot more house for your money with a 5th wheel compared to a
motorhome. When you get there, the house is disconnected leaving a
4X4 truck to pull you out of farm fields and run around town.
I'd suspect that a shorter RV with wheels near the aft hitch would
give the best chance of working well.
Old March 26th 07, 03:00 PM posted to rec.aviation.soaring
Steve,
I believe you would exceed length restrictions. California's limits are
defined in the following link:
http://www.dot.ca.gov/hq/traffops/tr.../legalsize.htm
http://www.soaridaho.com/
"Steve Koerner" wrote in message
Hello all,
a glider trailer.
trailer hitch.
Old March 26th 07, 03:41 PM posted to rec.aviation.soaring
dwrobel
On Mar 26, 8:00 am, "Wayne Paul" wrote:
Steve,
defined in the following link:http://www.dot.ca.gov/hq/traffops/tr...guide/legalsiz...
Waynehttp://www.soaridaho.com/
Hello all,
a glider trailer.
trailer hitch.
give the best chance of working well.- Hide quoted text -
- Show quoted text -
Utah allows up to 65 ft without a permit and my truck, 5th wheel, and
16 ft ATV trailer combination is within this limit but a glider
trailer is a lot longer than 16 ft. Also, not all states allow
multiple trailers to be towed.
Old March 26th 07, 03:43 PM posted to rec.aviation.soaring
Tuno
Steve,
The crew and I looked at doing this before we bought our motorhome two
years ago. You can't do it, because you have a trailer pulling a
trailer, and you can't get a trailer hitch put on a 5th wheel.
2NO
Old March 26th 07, 07:16 PM posted to rec.aviation.soaring
Steve Koerner
Thanks for the input on the 65 ft limit. I'm thinking that still may
be workable though. The glider trailer is 29 ft and distance from the
nose of my truck to the center of the bed is 15 ft. That would leave
21 ft for RV measured from the center of the fifth wheel aft -- a
smallish RV trailer but not too bad.
The biggest question in my mind is how would this menagerie tow at
highway speed?
Old March 26th 07, 07:40 PM posted to rec.aviation.soaring
highway speed?
I have seen a photo of someone doing what the OP suggested. I believe
the pictures are in the photos section of the 1-26 associations
website.
Old March 26th 07, 07:57 PM posted to rec.aviation.soaring
rustynuts
Steve
Also along with the length law, you must have active brakes on all
trailing
units if more than one trailer. Not just surge brakes but something
like
electric brakes. I think the limit in western states for doubles is
30' per
unit. The longer the power unit's wheel base the better and lighter
trailer
to rear. I'd go with at least 3/4 ton or more.
Russ
highway speed?
Old March 26th 07, 08:39 PM posted to rec.aviation.soaring
Steve Koerner
No such pic is presently in the 1-26 association gallery. Lots of
nice 1-26 pictures though.
Old March 26th 07, 08:48 PM posted to rec.aviation.soaring
Steve Koerner
Russ,
Thank you for that input. Is this rule regarding brakes a national
standard of some sort or is this a rule that pertains to operation in
some partcular states? I wouldn't want to have to mess with my nice
surge brakes on the glider trailer unless I really have to.
Eberle trailer wheel rims Bob Soaring 7 November 25th 11 05:39 PM
Avionic trailer wheel needed qflyer1 Soaring 6 December 7th 06 03:30 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
Q about trailer wheel bearings Ken Ward Soaring 1 September 15th 06 02:40 AM
US source for wheel on the tongue of Cobra trailer? Mark Zivley Soaring 3 January 18th 05 03:51 AM
