negative dihedral
Old June 4th 08, 09:09 AM posted to rec.aviation.piloting
Tina
Default negative dihedral
On Jun 3, 11:35 pm, Bertie the Bunyip wrote:
Tina wrote in news:28472a75-654d-447f-9317-
On Jun 3, 10:25 pm, Bertie the Bunyip wrote:
Tina wrote in news:d9fb071f-4d30-45c3-916d-
I understand how positive dihedral helps dynamic stability in
airplanes, but some big ones, like the Russian An 124 Condor, has a
pronounced negative dihedral -- the wings have a noticeable
downward
slope.
That's called Anhedral..
Q1: Do those airplanes need active fly by wire controls to maintain
stability, or is something else at play that keeps them right side
up?
Nope.
Q2: Does anyone have a design rationalization for such a
configuration, as opposed to just zero dihedral? I can appreciate
why
fighters have it -- they exploit lack of aerodynamic stability for
rapid maneuvers -- but transports that spend their whole life
being
straight and level are another issue.
Well, the anhedral negates what can be excessive stability that comes
form the sweep of the wings. Sweep provides a very similar kind of
stability as does dihedral and the addition of anhedral negates some
of
this and keeps the airplane form becoming so stable that it can't
even
be maneuvered!
Most of the airplanes with pronounced anhedral are high wing and
would
have parasol stability as well. The anhedral helps neutralise some of
that. Some low wing Russian jets have anhedral, but it's quite small
Their sweep is quite marked and the anhedral is there to ammeliarate
that. The 727 had a fairly radical sweep and you will notice, that
though it has dihedral it's very little compared to the 737 or
similar.
Note: I have not morphed into an Mx clone!
We'll know for sure if you tell me this answer is completely wrong
because your MSFS 172 doesn't have anhedral.
Bertie
Only after a very hard landing would a 172 develop negative dihedral.
A Mooney, on the other hand, given the placement of the wheels, would
either increase its positive dihedral, or more likely, given how
strongly they are built, put a dent in the runway.
I think there have been a couple of straight wing airplanes wiht
anhedral, but I can't picture one off the top of my head. Surely
everything that can be tried, has been tried at this stage!
Bertie
The everything that can be tried had been tried notion is out of
fashion, I don't think the patent office will be closing anytime soon,
or that Ratan's Scaled Composites will be closing up his shop. You can
bet someone will be trying an airplane with one wing over the other
soon. What would you call such a thing -- a redundant winged airplane?
For sure, in these days of political correctness, it would not be
called bi, would it?
Where are my meds?
Old June 4th 08, 02:16 PM posted to rec.aviation.piloting
Tina
pronounced negative dihedral -- the wings have a noticeable downward
slope.
stability, or is something else at play that keeps them right side up?
configuration, as opposed to just zero dihedral? I can appreciate why
rapid maneuvers -- but transports that spend their whole life being
The AN124 does not have negative dihedral. It just looks that way when it's
on the ground because the weight of the engines bends the wings so they
look drooped down. Once it's in the air, the fuselage bends the wings the
other way, so it actually does have dihedral.
--http://onlinelogbook.net
Thanks -- didn't realize it was simply wing droop when they are not
developing lift. That's what happens when you fly in stiff winged
little airplanes, you start overlooking something as obvious as that.
Old June 4th 08, 04:19 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Tina wrote in news:d86791d1-d1cd-4256-8c9e-
916d-
has a
downward
slope.
maintain
side
up?
Nope.
appreciate
why
for
being
comes
some
of
even
be maneuvered!
would
of
small
ammeliarate
similar.
Bertie
dihedral.
would
Bertie
Well, years ago a hypersonic bipe was looked at, believe it or not, but
even Beurt Rutan will tell you that none of his creations were
completely original. Not to detract from his talent, whihc is monstrous,
but there's nothing on any of his airplanes that hadn't been done
before. Even that mad boomerang has precedants and quite a lot of them
dating back to the first world war (Caproni). Getting it all arranged
right to make it go better than anything before it is his gift. Having
said that, Spaceship one was pretty unique, but you'll probably find
that mad recovery system was done in boost glider in an old issue of
American Aircraft Modeler or similar. I never cease to be astounded at
the massive number of airplanes constructed in th elast century and the
variety. it hardly seems possible sometimes that there were enough
people to make them all!
Bertie
Bertie
Where are my meds?
Old June 4th 08, 04:20 PM posted to rec.aviation.piloting
HARRY POTTER wrote in
slope.
up?
That's right, it has anhedral.
it's on the ground because the weight of the engines bends the wings
so they look drooped down. Once it's in the air, the fuselage bends
the wings the other way, so it actually does have dihedral.#
Nope.
Bertie
Old June 4th 08, 04:23 PM posted to rec.aviation.piloting
Tina wrote in
downward slope.
up?
why fighters have it -- they exploit lack of aerodynamic stability
for rapid maneuvers -- but transports that spend their whole life
being straight and level are another issue.
when it's on the ground because the weight of the engines bends the
wings so they look drooped down. Once it's in the air, the fuselage
bends the wings the other way, so it actually does have dihedral.
http://www.youtube.com/watch?v=WJscAaKfr7A
Bertie
Old June 4th 08, 04:29 PM posted to rec.aviation.piloting
Bertie the Bunyip wrote in news:Xns9AB3A5306F330****upropeeh@
208.90.168.18:
Tina wrote in
a
downward slope.
maintain
up?
Ooops, that was a MSFS one.
Here's an actual aiplane taking off...
http://www.youtube.com/watch?v=BcyRy...eature=related
Which clarly shows the sockpuppet is wrong.
Bertie
  #28
Old June 4th 08, 04:48 PM posted to rec.aviation.piloting
Tina
downward slope.
up?
Bertie
OK, I see some of the downslope was washed out in flight, but it was
still obvious there. Thanks
I expect more is washed out when the airplane is at gross weight, but
your point is made, Bertie.
  #29
Old June 4th 08, 05:03 PM posted to rec.aviation.piloting
Tina wrote in
Tina wrote
innews:4cc0ec37-d80c-4006-9190-
m:
has a pronounced negative dihedral -- the wings have a
noticeable downward slope.
maintain stability, or is something else at play that keeps them
right side up?
appreciate why fighters have it -- they exploit lack of
aerodynamic stability for rapid maneuvers -- but transports
that spend their whole life being straight and level are another
issue.
the wings so they look drooped down. Once it's in the air, the
fuselage bends the wings the other way, so it actually does have
dihedral.
that.
Bertie
Um, washout is probably not the best term, being share with another
important wing feature, but yeah, it's still there even when the
airplane is very heavy. I've seen the 225 fly and it's the same. There'a
also the little BAe 146 and the C5 and the C141 and the other little bay
antonov etc. I also mentioned I had seen some striaght wing airplanes
with anhedral but couldn't remember where. Most of the turboprop
antonovs have anhedral, but not nearly as much as the jets. He obviously
liked his airplanes to be manueverable!
Even a lot of the low wing jets had anhedral. The IL 62, for
instance.and IIRC some of the Tupovlevs also had it.
  #30
Old June 4th 08, 05:16 PM posted to rec.aviation.piloting
Tina
On Jun 4, 12:03 pm, Bertie the Bunyip wrote:
m:
right side up?
issue.
dihedral.
that.
Bertie
There was a country music guy who had a Mitsubishi twin with what I
remember looked liked pronounced anhedral, but I did a web search and
couldn't find a photo of it. What I am remembering might have been in
the 1970s.
There's little doubt in my mind that a high wing configuration with
negative dihedral would be more stable than a low winged one -- the cg
being way under the center of lift would see to that -- but still
don't have a 'model' to explain why wing sweep is a factor: when I
have some time I'll think about that, or I suppose I could ask
Anthony.
As for new stuff in aviation? I'd say GPS, released to the general
public during the RR presidency because of the Koran jet shootdown in
Russia, is fairly new. And let us not forget the new and improved FAA.
I'm doing my part to add to the recreation in rec.aviation (and trying
to not have it be wreck.aviation).
Another old negative Don Pyeatt Aviation Photos 0 March 2nd 08 05:32 PM
"predator' dihedral Phil Rhodes Naval Aviation 5 May 25th 07 09:54 PM
Wing dihedral Dallas Piloting 35 March 20th 06 04:01 PM
how to cope with negative g´s? Markus Aerobatics 6 July 2nd 05 12:00 AM
Biplane wing dihedral vincent p. norris General Aviation 20 June 18th 05 02:58 AM
