negative dihedral
Old June 3rd 08, 11:13 PM posted to rec.aviation.piloting
Tina
Default negative dihedral
I understand how positive dihedral helps dynamic stability in
airplanes, but some big ones, like the Russian An 124 Condor, has a
pronounced negative dihedral -- the wings have a noticeable downward
slope.
Q1: Do those airplanes need active fly by wire controls to maintain
stability, or is something else at play that keeps them right side up?
Q2: Does anyone have a design rationalization for such a
configuration, as opposed to just zero dihedral? I can appreciate why
fighters have it -- they exploit lack of aerodynamic stability for
rapid maneuvers -- but transports that spend their whole life being
straight and level are another issue.
Note: I have not morphed into an Mx clone!
Old June 4th 08, 12:52 AM posted to rec.aviation.piloting
Bob Noel
slope.
Don't know why, but don't those transports with negative dihedral also have
wings above the hull? So those aircraft have the CG below the wings.
Bob Noel
(goodness, please trim replies!!!)
Old June 4th 08, 12:59 AM posted to rec.aviation.piloting
Frank Olson
slope.
And large transport aircraft are amongst the most aerodynamically stable
aircraft to fly.
Old June 4th 08, 03:27 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Frank Olson wrote in
news:3Wk1k.4381$C12.2615@pd7urf3no:
Bob Noel wrote:
In article
slope.
up?
why fighters have it -- they exploit lack of aerodynamic stability
for rapid maneuvers -- but transports that spend their whole life
being straight and level are another issue.
also have wings above the hull? So those aircraft have the CG below
the wings.
stable aircraft to fly.
Actually, that's not the case in every sense. They're not very speed
stable, for instance and thye have other problems with two diferent
kinds of dutch roll, related to sweep, mostly.
Bertie
Old June 5th 08, 12:02 AM posted to rec.aviation.piloting
Maxwell[_2_]
Bertie
Keep guessing wannabe, got a link?
Old June 5th 08, 12:03 AM posted to rec.aviation.piloting,alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk
Bertie the Bunyip[_25_]
"Maxwell" luv2^fly99@cox.^net wrote in news:9aF1k.1876$nD3.800
@newsfe15.lga:
Bertie
Nope. Don't need one.
Bertie
Old June 4th 08, 12:56 AM posted to rec.aviation.piloting
Frank Olson
slope.
"Negative dihedral" may have more to do with keeping the landing gear
legs shorter. I know that's how they solved the problem they
encountered with the longer gear legs required on the Avro Arrow. On
the original mock-ups, when they first tried to retract the main gear
legs, they "crunched together" with each other at the point where they
entered the fuselage.
Dihedral (whether "positive" or "negative") does tend to *add*
stability, not take it away. Fighter jets and large airliners use "fly
by wire" because the stick forces required to move the control surfaces
may be too much for the average pilot (or might cause a good deal of
fatigue which, on longer flights, could be detrimental to the safe
operation of the aircraft). "Fly by wire" does little toward enhancing
the overall stability of an aircraft. "Stability" has more to do with
the overall design of the aircraft (and it's intended use).
Old June 4th 08, 01:30 AM posted to rec.aviation.piloting
Tina
On Jun 3, 7:56 pm, Frank Olson
slope.
well what occurred to me is, with negative dihedral, as one wing lifts
it generates MORE lift, while the wing going down generates less. I
thought that would encourage the roll, but maybe the wing design
itself somehow takes that into account..
Old June 4th 08, 01:35 AM posted to rec.aviation.piloting
Steven P. McNicoll[_2_]
"Tina" wrote in message
Why did that occur to you?
Old June 4th 08, 02:12 AM posted to rec.aviation.piloting
More_Flaps
slope.
Q2: Does anyone have a design rationalization *for such a
rapid *maneuvers -- but transports that spend their whole life being
legs shorter. *I know that's how they solved the problem they
encountered with the longer gear legs required on the Avro Arrow. *On
stability, not take it away. *Fighter jets and large airliners use "fly
operation of the aircraft). *"Fly by wire" does little toward enhancing
the overall stability of an aircraft. *"Stability" has more to do with
To pionts: The swept wing also add roll stability and for heavy low CG
airgraft with high swept wings the anhedral may be large to reduce
excessive stability.
Cheers
Another old negative Don Pyeatt Aviation Photos 0 March 2nd 08 05:32 PM
"predator' dihedral Phil Rhodes Naval Aviation 5 May 25th 07 09:54 PM
Wing dihedral Dallas Piloting 35 March 20th 06 04:01 PM
how to cope with negative g´s? Markus Aerobatics 6 July 2nd 05 12:00 AM
Biplane wing dihedral vincent p. norris General Aviation 20 June 18th 05 02:58 AM
