Electric motor for hang glider
Old August 8th 08, 04:24 AM
Joe Faust Joe Faust is offline
Junior Member
First recorded activity by AviationBanter: Aug 2008
http://us.groups.yahoo.com/group/E-FLPHG/join
Focus group started on this topic.
All are invited.
Old August 27th 09, 02:14 AM
jason siig jason siig is offline
Junior Member
First recorded activity by AviationBanter: Aug 2009
Quote:
Originally Posted by Legend Length View Post
I have been trying to do some calculations of how much battery power
would be needed to keep a hang glider flying level. With some help I
arrived at about 1 or 2 kW (a few horse power) for a typical hang
glider with 10:1 glide ratio and 180 pound (80 kg) pilot. As a
comparison, gasoline engines for hang gliders are 10 kW and give 1 - 2
m/s climb for half an hour on 4 litres of fuel.
I am unable to find electric versions of those powered harnesses being
sold. Looking around for battery prices I found this site:
http://www.hobby-lobby.com/flightpower.htm . The last battery on the
page is 22.2 V, 7.4 Ah = 164 kWh. I thought it may be interesting to
see how they would hold up when powering a human aircraft.
Each battery weighs 500 grams so with 10 batteries it would be a 5 kg
pack. The cost would be $500 * 10 batteries = $5000. Electric motor
with propeller and harness may weigh 10 or 15 kg on top of that, I am
unsure and would like to know figures. I have tried to find out but am
unsure of some of the terminology for electric engines. Also I do not
know if you can just attach a propeller to any old electric engine.
So it appears from my very rough calculations that you can achieve
around 3 kW for half an hour of flight, for $5000 and 5 kg of
batteries. Is this an unrealistic base line for me to use, before
adding the weight of battery heat insulation and other things?
I have bin working on the same thing I got a neu brushless motor 2.6 kw with a 1-4 gear box turning a 30 inch 10 pich prop 44.4 volts at 60 amps
Electric Glider Mal Soaring 20 November 2nd 05 10:46 PM
Aerodynamics of carrying water Gene Whitt Soaring 54 October 19th 05 07:24 PM
Bad publicity David Starer Soaring 18 March 8th 04 03:57 PM
I wish I'd never got into this... Kevin Neave Soaring 32 September 19th 03 12:18 PM
