Metric Fuse Question
Old August 21st 08, 09:24 PM posted to rec.aviation.soaring
Paul Foley
Default Metric Fuse Question
Our club Discus2b has 5mmX20mm fuses in the instrument panel labeled
F4/250V. Could someone tell me what the amp rating is of these fuses.
Old August 21st 08, 09:44 PM posted to rec.aviation.soaring
Darryl Ramm
F4/250V. *Could someone tell me what the amp rating is of these fuses.
That would almost certainly be fast blow 4 amp/250 volts.
Darryl
Old August 21st 08, 10:09 PM posted to rec.aviation.soaring
Peter Purdie[_3_]
Correct - fastblow 4A.
If you have any capacitive load (often some technically competent club
member puts a largish capacitor in to make sure power isn't interrupted
when switching batteries) then slow blow is a better option. The main
purpose of fuses is to protect the wiring, and slow blow will fulfil that
requirement.
Peter
At 20:44 21 August 2008, Darryl Ramm wrote:
F4/250V. =A0Could someone tell me what the amp rating is of these
fuses.
Darryl
Old August 21st 08, 10:54 PM posted to rec.aviation.soaring
Paul Foley
that
requirement.
Peter
fuses.
Darryl
Thanks All
Tube Fuse Oil Holes John[_17_] Home Built 8 March 21st 08 12:11 PM
KR-2 fuse for sale Turbo Tiger Home Built 3 December 17th 05 06:27 PM
The German proximity fuse. Eunometic Naval Aviation 35 May 11th 05 06:02 PM
Fuse the Wire or Fuse the Device? ContestID67 Soaring 11 April 27th 05 03:13 AM
Cambridge Fuse Question Brian Iten Soaring 9 January 4th 05 02:43 PM
