PZL compass question
Old August 22nd 08, 10:15 PM posted to rec.aviation.soaring
Default PZL compass question
When I bought my glider a year ago there was a PZL Warszawa ll compass
that came with it but was not installed. Looking at it I found that
ther was no fluid in the unit. Looks like a nice little so I thought
I'd refill it an mount it. The problem is that I dodn't know what
type of fluid to use. The PZL website states that it uses "ligroin"
but don't have a clue where to find any of that stuff. Any ideas?
Thanks
Mike Ziaskas, San Diego, CA
Old August 23rd 08, 12:02 AM posted to rec.aviation.soaring
Martin Gregorie[_4_]
that came with it but was not installed. Looking at it I found that ther
was no fluid in the unit. Looks like a nice little so I thought I'd
refill it an mount it. The problem is that I dodn't know what type of
fluid to use. The PZL website states that it uses "ligroin" but don't
have a clue where to find any of that stuff. Any ideas? Thanks
I just looked up Ligroin in a chemical engineering dictionary. It seems
to be about as non-specific a term as you can find. It can mean anything
from petroleum ether to kerosene as well as everything in between.
Airpath compass fluid is similar. Its a C10-C13 alkane, which sounds to
me remarkably like good quality kerosene or paraffin, so I'd suggest you
use that. Looked and smelt like paraffin too, when we refilled my Ludolph
compass with it last winter.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old August 23rd 08, 12:24 AM posted to rec.aviation.soaring
sisu1a
The Airpath fluid should do nicely, but you really should get a gasket
kit for it because if it had good gasket(s) it would probably not be
empty and if it were just drained and left empty for no reason, the
seal is probably beat by now anyhow. I have not opened up a PZL
compass, so I can't offer any insight to fabricating a gasket if one
can't be procured. Just a thought...
-Paul
Thanks
Old August 23rd 08, 12:28 AM posted to rec.aviation.soaring
5Z
Also, be sure to leave a pretty big air bubble inside. Without that
it WILL blow the gasket at altitude.
-Tom
Old August 23rd 08, 02:10 AM posted to rec.aviation.soaring
Darryl Ramm
On Aug 22, 4:28*pm, 5Z wrote:
Also, be sure to leave a pretty big air bubble inside. *Without that
-Tom
It might blow a gasket if filled all the way due to hot temperatures
and no expansion space. If it was altitude related leaving a larger
air bubble would make problems due to pressure differential at
altitude worse not better. Right?
Darryl
Old August 23rd 08, 02:28 AM posted to rec.aviation.soaring
ZZ
Prior to a contest, my compass puked all of its fluid. I had a new
gasket kit but no white kerosene, the fluid recommended by the compass
manufacturer. So I filled it with Bar-B-Q lighter fluid. (The can said
it was kerosene). It was a bit red in color but lasted about 10 years. I
eventually replaced the compass with a new one.
Paul
ZZ
Thanks
Old August 23rd 08, 03:07 AM posted to rec.aviation.soaring
5Z
That makes sense, but since I've refilled mine, leaving the air bubble
in there, it hasn't leaked. Go figure.
-Tom
Old August 23rd 08, 03:09 AM posted to rec.aviation.soaring
Nyal Williams[_2_]
Early on, compasses were filled with alcohol and they were referred to as
"spirit" compasses -- a common descriptor for volatile substances.
This, together with the word "spirits" used for distilled liquor, led to
using the phrase "whiskey compass." (My guess is as good as yours.)
Paul
ZZ
Thanks
Old August 23rd 08, 03:21 AM posted to rec.aviation.soaring
GM
ther was no fluid in the unit. *Looks like a nice little so I thought
I'd refill it an mount it. *The problem is that I dodn't know what
type of fluid to use. *The PZL website states that it uses "ligroin"
but don't have a clue where to find any of that stuff. *Any ideas?
Thanks
Mike,
check the online catalog of Aircraft Spruce:
http://www.aircraftspruce.com/menus/...es_repair.html
They have the correct fluid but only gaskets sets for Airpass
compasses.
Uli Neumann
Old August 23rd 08, 03:44 AM posted to rec.aviation.soaring
Darryl Ramm
in there, it hasn't leaked. *Go figure.
-Tom
Tom, I was not disagreeing with your instructions, just the reasons
you gave for doing so. My understanding is the air bubble is critical
for fluid thermal expansion on the PZL since unlike some compasses
they have no form of pressure relief diaphragm etc.
Darryl
Compass [email protected] Soaring 33 February 27th 08 01:43 AM
Compass for SZD-55 Steve Freeman Soaring 3 July 24th 07 02:13 AM
PZL Compass Dave Springford Soaring 3 December 7th 05 04:05 AM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 07:39 AM
mag-compass for a B55 JerryK Owning 3 July 11th 03 06:18 AM
