Does an experimental ASW20B require a compass to be legal. The
minimum equipment list in the amnual does not specify a compass? |
As best I can tell, the answer appears to be no. My ASW20 has one but
I don't think I have ever looked at it. A review of the FAR's turns up the following "compass" or "direction indicator" citations: 91.205 Powered civil aircraft with standard category U.S. airworthiness certificates: Instrument and equipment requirements. (a) General. Except as provided in paragraphs (c)(3) and (e) of this section, no person may operate a powered civil aircraft with a standard category U.S. airworthiness certificate in any operation described in paragraphs (b) through (f) of this section unless that aircraft contains the instruments and equipment specified in those paragraphs (or FAA-approved equivalents) for that type of operation, and those instruments and items of equipment are in operable condition. (b) Visual-flight rules (day). For VFR flight during the day, the following instruments and equipment are required: (1) Airspeed indicator. (2) Altimeter. (3) Magnetic direction indicator. But this section applies to POWERED AIRCRAFT ---OR--- PART 23--AIRWORTHINESS STANDARDS: NORMAL, UTILITY, ACROBATIC, AND COMMUTER CATEGORY AIRPLANES Subpart F--Equipment § 23.1303 Flight and navigation instruments. The following are the minimum required flight and navigation instruments: (a) An airspeed indicator. (b) An altimeter. (c) A direction indicator (nonstabilized magnetic compass). But this will not apply you are not an AIRPLANE So unless someone can come up with a reference to gliders or aircraft, my vote is that the "direction indicator" is not required, unless otherwise required by the manufacturer certification. The FAR's are searchable online he http://ecfr.gpoaccess.gov/cgi/t/text...4/14tab_02.tpl |
In Bob Carlton's Convention talk about ramp checks, he said that gliders
are not required to have a compass. However, sometimes the airworthiness document requires one. See, for example, the type certificate data sheet for the ASW-27 at http://tinyurl.com/2qpqhr. Todd wrote: As best I can tell, the answer appears to be no. My ASW20 has one but I don't think I have ever looked at it. A review of the FAR's turns up the following "compass" or "direction indicator" citations: 91.205 Powered civil aircraft with standard category U.S. airworthiness certificates: Instrument and equipment requirements. (a) General. Except as provided in paragraphs (c)(3) and (e) of this section, no person may operate a powered civil aircraft with a standard category U.S. airworthiness certificate in any operation described in paragraphs (b) through (f) of this section unless that aircraft contains the instruments and equipment specified in those paragraphs (or FAA-approved equivalents) for that type of operation, and those instruments and items of equipment are in operable condition. (b) Visual-flight rules (day). For VFR flight during the day, the following instruments and equipment are required: (1) Airspeed indicator. (2) Altimeter. (3) Magnetic direction indicator. But this section applies to POWERED AIRCRAFT ---OR--- PART 23--AIRWORTHINESS STANDARDS: NORMAL, UTILITY, ACROBATIC, AND COMMUTER CATEGORY AIRPLANES Subpart F--Equipment § 23.1303 Flight and navigation instruments. The following are the minimum required flight and navigation instruments: (a) An airspeed indicator. (b) An altimeter. (c) A direction indicator (nonstabilized magnetic compass). But this will not apply you are not an AIRPLANE So unless someone can come up with a reference to gliders or aircraft, my vote is that the "direction indicator" is not required, unless otherwise required by the manufacturer certification. The FAR's are searchable online he http://ecfr.gpoaccess.gov/cgi/t/text...4/14tab_02.tpl |
On Feb 18, 10:25*am, Greg Arnold wrote:
*However, sometimes the airworthiness document requires one. *See, for example, the type certificate data sheet for the ASW-27 athttp://tinyurl.com/2qpqhr. Interestingly the ASW-28 TCDS issued later does not list a compass in the equipment list. For an experimental glider, even if here is a standard type certificate and associated TCDS, I don't think the TCDS applies. Minimum equipment may be listed in the experimental certification docs (operational limitations) but that may depend the date of the airworthiness inspection and the region in which it was conducted. Recent experimental glider cert docs seem to be more standardized than they were when the ASW-20 was new. Andy |
On Feb 18, 12:03*pm, Andy wrote:
Minimum equipment may be listed in the experimental certification docs (operational limitations) but that may depend the date of the airworthiness inspection and the region in which it was conducted. When I got home I checked my ASW-28 (experimental exhibition/ air racing) operating limitations issued May 2002. They state: 37. After completion of the flight test phase, unless appropriately equipped for night and/or instrument flight in accordance with 91.205, this aircraft is to be operated under day/vfr. 38. Aircraft instruments and equipment installed and used under 91.205 must be inspected and maintained in accordance with the applicable requirments of Parts 43 and 91..... I found no other refence to required instruments. I conclude that I am not required to have a compass since it is not required by the TCDS, the operational limitations, or the LBA approved flight handbook. I do have a panel mounted compass but it will go if I need the space for an other instrument. Andy |
On Feb 17, 5:48*pm, wrote:
Does an experimental ASW20B require a compass to be legal. *The minimum equipment list in the amnual does not specify a compass? What does the POH say is the required minimum equipment? What does the Type Certificate say? |
On Feb 18, 11:33*am, Bullwinkle wrote:
Why would someone not want a compass? Because, except in the case of total GPS failure, or the rare case that a glider is given an ATC heading vector, they are a waste of panel space? Andy |
On Feb 18, 1:55*pm, Andy wrote:
On Feb 18, 11:33*am, Bullwinkle wrote: Why would someone not want a compass? Because, except in the case of total GPS failure, or the rare case that a glider is given an ATC heading vector, they are a waste of panel space? Andy You can fly wings level in IMC using a standard compass. Not with GPS. |
| Thread Tools | |
| Display Modes | |
| WTB: PZL KI-13 Compass | Romeo Delta | Soaring | 1 | October 30th 17 08:47 AM |
| Compass for SZD-55 | Steve Freeman | Soaring | 3 | July 24th 07 03:13 AM |
| compass turns with high mounted compass (Cessna 152) | Ray | Instrument Flight Rules | 22 | April 7th 05 08:39 AM |
| Looking for a PZL compass | Kirk Stant | Soaring | 8 | February 12th 04 10:27 PM |
| mag-compass for a B55 | JerryK | Owning | 3 | July 11th 03 07:18 AM |
