On Oct 25, 10:55*am, November Bravo wrote:
I own a Ventus 2CXM built 2007 with a factory installed Walter Dittle FSG 2T radio. *I use the Sennheiser headphones (factory installation) during the engine running procedures. *Unfortunately, I have always had severe interference with the radio tramsmission/reception during the engine run. *During the engine run, whether idle or full power, the reception is weak and garbled with a great deal of backround white noise. *My transmissions are totally garbled, weak, and uninterpretable even to other aircraft 50 yards away. *When the engine is not running I have not problems and my fellow pilots report that my transmissions are strong and clear. *This is becoming a safety problem while taxing onto the active runway, as our glider airport is now very busy with power traffic and a new flight school. *Has anyone encountered this problem and know of a list of things to check before sending the aircraft to an aviation radio specialist? John Iacobucci Grand Rapids, Michigan USA +1 (616) 485-3980 Do you receive other aircraft clearly when the engine is running? With white or other noise? That is a good first test to see whether to suspect the antenna etc. (although it may still be). If you are not hearing a white noise sound and not an alternator whine or ignition noise type sound I'd tend to be more suspicious of the microphone. Are you using a headset microphone or the boom mike? Does that work when the engine is not running? Check that the headset mic and mic select switch are wired correctly (headset mic goes anywhere, both mic's are not wired in parallel etc.) and it's not just the boom mic picking up ambient noise. Test by unplugging the headset mic and testing (you should transmit no audio). How does the headset mic work without the engine running? If poorly, is it the type of mic the Dittel expects/is set to? Try borrowing another headset with mic. and test that. If this has been happening since delivery from the factory I'd hope their dealer or the factory will help you debug this. Darryl |
| Thread Tools | |
| Display Modes | |
| radio interference with transmission/reception with Solo 2625-01running | November Bravo | Soaring | 0 | October 26th 08 05:08 AM |
| radio interference with transmission/reception with Solo 2625-01running | November Bravo | Soaring | 2 | October 26th 08 04:59 AM |
| Ventus 2cxM Solo 2625 01 EGT Installation | Chris Woolley | Soaring | 2 | April 4th 08 05:09 AM |
| SOLO 2625-02 engine drawings | Maciek | Soaring | 2 | April 5th 07 02:15 PM |
| GPS / radio interference | Cub Driver | Piloting | 2 | October 31st 04 11:57 PM |
