radio interference with transmission/reception with Solo 2625-01running
Old October 25th 08, 06:55 PM posted to rec.aviation.soaring
November Bravo
Default radio interference with transmission/reception with Solo 2625-01running
I own a Ventus 2CXM built 2007 with a factory installed Walter Dittle
FSG 2T radio. I use the Sennheiser headphones (factory installation)
during the engine running procedures. Unfortunately, I have always
had severe interference with the radio tramsmission/reception during
the engine run. During the engine run, whether idle or full power,
the reception is weak and garbled with a great deal of backround white
noise. My transmissions are totally garbled, weak, and
uninterpretable even to other aircraft 50 yards away. When the engine
is not running I have not problems and my fellow pilots report that my
transmissions are strong and clear. This is becoming a safety problem
while taxing onto the active runway, as our glider airport is now very
busy with power traffic and a new flight school. Has anyone
encountered this problem and know of a list of things to check before
sending the aircraft to an aviation radio specialist?
John Iacobucci
Grand Rapids, Michigan USA
+1 (616) 485-3980
Old October 25th 08, 08:41 PM posted to rec.aviation.soaring
Vaughn Simon
Default radio interference with transmission/reception with Solo 2625-01 running
"November Bravo" wrote in message
Has anyone
Off the top of my head, you are probably receiving interference via the power
system or your engine is radiating interference that being picked up by the
antenna and drowning out reception.
The first problem might be solved with some filtering and careful attention to
your aircraft's ground system, and the second problem might respond to an
antenna relocation and/or engine electrical shielding. Make sure that the
antenna coaxial cable is not accidentally serving as the power ground for the
radio (unplug antenna and make sure that radio still has power)
Two things you can easily check that would provide important troubleshooting
clues:
1) If you use a portable radio inside the cockpit with the engine running, do
you have the same problem? and...
2) If you power the Dittle from a temporary battery (not connected to the
glider's electrical system) does it make any difference in the transmission
and/or reception?
Vaughn
Old October 26th 08, 03:59 AM posted to rec.aviation.soaring
Eric Greenwell
Have you tried one of the owners groups? Other people with Solo engine
self-launchers have had problems like yours. From the ASA website
(motorglider.org) "Links and Newsgroups":
http://groups.yahoo.com/group/DGSoloUsersGroup/
http://groups.yahoo.com/group/Ventus_2CM/
Ventus 2cxM Solo 2625 01 EGT Installation Chris Woolley Soaring 2 April 4th 08 04:09 AM
SOLO 2625-02 engine drawings Maciek Soaring 2 April 5th 07 01:15 PM
FM radio interference from planes rb Piloting 34 July 19th 06 05:53 PM
GPS / radio interference Cub Driver Piloting 2 October 31st 04 10:57 PM
radio / vario interference - HELP! Chris Davison Soaring 13 November 3rd 03 06:09 AM
